STM32库函数个人浅析实现之以void GPIO_Init()开始
void GPIO_Init(GPIO_TypeDef* GPIOx, GPIO_InitTypeDef* GPIO_InitStruct){
uint32_t currentmode = 0x00, currentpin = 0x00, pinpos = 0x00, pos = 0x00;
uint32_t tmpreg = 0x00, pinmask = 0x00; //currentmode当前IO配置模式 ; currentpin 当前pin脚; tmpreg目标寄存器;
/* Check the parameters */
assert_param(IS_GPIO_ALL_PERIPH(GPIOx)); // 断言检测机制
assert_param(IS_GPIO_MODE(GPIO_InitStruct->GPIO_Mode));
assert_param(IS_GPIO_PIN(GPIO_InitStruct->GPIO_Pin));
typedef enum
{ GPIO_Mode_AIN = 0x0, // 0000 0000 模拟输入
GPIO_Mode_IN_FLOATING = 0x04, // 0000 0100 浮空输入
GPIO_Mode_IPD = 0x28, // 0010 1000 下拉输入
GPIO_Mode_IPU = 0x48, // 0100 1000 上拉输入
GPIO_Mode_Out_OD = 0x14, // 0001 0100 通用开漏输出
GPIO_Mode_Out_PP = 0x10, // 0001 0000 通用推挽输出
GPIO_Mode_AF_OD = 0x1C, // 0001 1100 复用开漏输出
GPIO_Mode_AF_PP = 0x18 // 0001 1000 复用推挽输出
}GPIOMode_TypeDef;
/*---------------------------- GPIO Mode Configuration -----------------------*/
currentmode = ((uint32_t)GPIO_InitStruct->GPIO_Mode) & ((uint32_t)0x0F);
//cureenmode = 0000 xx00 ; 00 为 mode值, xx 为CNF值;
// GPIO_InitStruct->GPIO_Mode 为输入模式时(GPIO_Mode_AIN,GPIO_Mode_IN_FLOATING,GPIO_Mode_IPD,GPIO_Mode_IPU),xx00 为设置数据;
//00表明输入模式,xx 为具体输入模式;
if ((((uint32_t)GPIO_InitStruct->GPIO_Mode) & ((uint32_t)0x10)) != 0x00)//判断是否是输出模式;
// GPIO_InitStruct->GPIO_Mode 的 bit4 为 1时,即为 输出模式 时,进入if
assert_param(IS_GPIO_SPEED(GPIO_InitStruct->GPIO_Speed));
/* Output mode */
currentmode |= (uint32_t)GPIO_InitStruct->GPIO_Speed; //currentmode =0000 xxyy ;xx 与 yy 分别取决于初始化 GPIO_Mode 设置 与 speed设置; //即 GPIO_InitStruct 结构体 初始化数据 ; yy 表明为输出 ,xx为具体输出模式;
/*---------------------------- GPIO CRL Configuration ------------------------*/
/* Configure the eight low port pins */
if (((uint32_t)GPIO_InitStruct->GPIO_Pin & ((uint32_t)0x00FF)) != 0x00)//GPIO_Pin 为 0~7 时,使用CRL 寄存器;
tmpreg = GPIOx->CRL;//当前 CRL数据放到 tmpreg中;
页:
[1]
