RL-TCPNet on AT32F407
RL-TCPNet on AT32F407以RL-TCPNet实现的demo code, 自我验证可以ping通,默认的IP地址为192.168.1.100若要修改该地址,请参考安福来的手册或是Keil官方的RL-ARM相关说明文件。/* Includes -----------------------------------------------------------------*/#include <stdio.h>#include <stdbool.h>#include "string.h"#include "stdbool.h"#include "at32f4xx.h"#include "at32_board.h"#include "main.h"#include "eth_config.h"#include "Net_Config.h"
/** @addtogroup AT32F407_StdPeriph_Examples* @{*/
/** @addtogroup ETH_Telnet* @{*/ /* Gloable variables ---------------------------------------------------------*/__IO uint32_t LocalTime = 0; /* this variable is used to create a time reference incremented by 10ms */uint32_t timingdelay;unsigned char tcp_rec_flag = 0;
/* Gloable functions ---------------------------------------------------------*//*** @briefMain Function.* @paramNone* @retval None*/int main(void){/* --------BSP Init ------------------------------------------------*/AT32_Board_Init();UART_Print_Init(115200);/* Setup AT32 system (clocks, Ethernet, GPIO, NVIC) */System_Setup();Delay_init();init_TcpNet();while(1) { timer_tick(); main_TcpNet();}}
/*** @briefInserts a delay time.* @paramnCount: number of 10ms periods to wait for.* @retval None*/void Delay(uint32_t nCount){/* Capture the current local time */timingdelay = LocalTime + nCount;
/* wait until the desired delay finish */while(timingdelay > LocalTime){ }}
/*** @briefUpdates the system local time * @paramNone* @retval None*/void Time_Update(void){LocalTime += SYSTEMTICK_PERIOD_MS;
只要是发资料的,都要顶一顶。说不定什么时候用得上呢。 这个可以,怎么官网上的下不了呢 谢谢分享,参考一下。 一楼说的有道理,知识在于积累,哈哈
页:
[1]
