[应用相关] RL-TCPNet on AT32F407
1265|4
 楼主| muyichuan2012 发表于 2021-1-4 19:50 | 显示全部楼层 |阅读模式
RL-TCPNet实现的demo code, 自我验证可以ping通,默认的IP地址为192.168.1.100
若要修改该地址,请参考安福来的手册或是Keil官方的RL-ARM相关说明文件。
/* Includes -----------------------------------------------------------------*/
#include <stdio.h>
#include <stdbool.h>
#include "string.h"
#include "stdbool.h"
#include "at32f4xx.h"
#include "at32_board.h"
#include "main.h"
#include "eth_config.h"
#include "Net_Config.h"
/** @addtogroup AT32F407_StdPeriph_Examples
/** @addtogroup ETH_Telnet
/* Gloable variables ---------------------------------------------------------*/
__IO uint32_t LocalTime = 0; /* this variable is used to create a time reference incremented by 10ms */
uint32_t timingdelay;
unsigned char tcp_rec_flag = 0;
/* Gloable functions ---------------------------------------------------------*/
  * @brief  Main Function.
  * @param  None
  * @retval None
int main(void)
  /* --------BSP Init ------------------------------------------------*/
  AT32_Board_Init();
  UART_Print_Init(115200);
  /* Setup AT32 system (clocks, Ethernet, GPIO, NVIC) */
  System_Setup();
  Delay_init();
  init_TcpNet();
  while(1)
    timer_tick();
    main_TcpNet();
  * @brief  Inserts a delay time.
  * @param  nCount: number of 10ms periods to wait for.
  * @retval None
void Delay(uint32_t nCount)
  /* Capture the current local time */
  timingdelay = LocalTime + nCount;
  /* wait until the desired delay finish */
  while(timingdelay > LocalTime)
  * @brief  Updates the system local time
  * @param  None
  * @retval None
void Time_Update(void)
  LocalTime += SYSTEMTICK_PERIOD_MS;
RL-TCPNet demo.zip
3.38 MB, 下载次数: 52
pattywu 发表于 2021-1-4 20:31 | 显示全部楼层
只要是发资料的,都要顶一顶。说不定什么时候用得上呢。
lgwauthor 发表于 2022-2-11 16:47 | 显示全部楼层
这个可以,怎么官网上的下不了呢
weifeng90 发表于 2022-2-11 19:20 来自手机 | 显示全部楼层
谢谢分享,参考一下。
duo点 发表于 2022-2-13 10:36 来自手机 | 显示全部楼层
一楼说的有道理,知识在于积累,哈哈
