【AT-START-F407测评】+ 网口试验
本帖最后由 比神乐 于 2021-1-31 13:50 编辑今天捣鼓了一下网口试验。
TCP客户端。
代码:
/* Includes -----------------------------------------------------------------*/
#include "at32_board.h"
#include "main.h"
#include "eth_config.h"
/** @addtogroup AT32F407_StdPeriph_Examples
/** @addtogroup ETH_TCP_Server
/* Gloable variables ---------------------------------------------------------*/
__IO uint32_t LocalTime = 0; /* this variable is used to create a time reference incremented by 10ms */
uint32_t timingdelay;
/* Gloable functions ---------------------------------------------------------*/
* @briefMain Function.
* @paramNone
* @retval None
int main(void)
unsigned char tcp_data[] = "TCP client experiment!\n";
struct tcp_pcb *pcb;
uint32_t Status;
/* --------BSP Init ------------------------------------------------*/
AT32_Board_Init();
UART_Print_Init(115200);
/* Setup AT32 system (clocks, Ethernet, GPIO, NVIC)*/
Status = System_Setup();
while(Status == ETH_DRIVER_FAIL);
/* Initilaize LwIP satck, IP configuration and MAC configuration*/
LwIP_Init();
/* Initialize TCP client module */
TCP_Client_Init(TCP_LOCAL_PORT,TCP_SERVER_PORT,TCP_SERVER_IP);//Initialize TCP client
while(1)
pcb = Check_TCP_Connect();
if(pcb != 0)
TCP_Client_Send_Data(pcb,tcp_data,sizeof(tcp_data)); //Send data to TCP server actively
Delay_s(0xfffff); //necessary delay
System_Periodic_Handle(); //Update TCP timers
* @briefInserts a delay time.
* @paramnCount: number of 10ms periods to wait for.
* @retval None
void Delay(uint32_t nCount)
/* Capture the current local time */
timingdelay = LocalTime + nCount;
/* wait until the desired delay finish */
while(timingdelay > LocalTime)
* @briefUpdates the system local time
* @paramNone
* @retval None
void Time_Update(void)
LocalTime += SYSTEMTICK_PERIOD_MS;
* @briefHandles the periodic tasks of the system
* @paramNone
* @retval None
void System_Periodic_Handle(void)
/* LwIP periodic services are done here */
LwIP_Periodic_Handle(LocalTime);
}/* TCP server and client configuration*/
#define TCP_LOCAL_PORT 1030
#define TCP_SERVER_PORT 1031
#define TCP_SERVER_IP 192,168,1,19 //server IPstatic uint8_t G_IP = {192, 168, 1, 37};
static uint8_t G_GW = {192, 168, 1, 187};
static uint8_t G_MASK = {255, 255, 255, 0};效果图:
注意还要关闭防火墙。
厉害 小辣椒哥哥~ 能分享代码吗 无所谓随意 发表于 2021-2-2 15:10
能分享代码吗
例程一点都没改 有空可以试试IPERF例程,测试一下看看网速多少。 可以分享一下代码吗?
页:
[1]
