今天捣鼓了一下网口试验。
TCP客户端。
代码:
- /* Includes -----------------------------------------------------------------*/
- #include "at32_board.h"
- #include "main.h"
- #include "eth_config.h"
- /** @addtogroup AT32F407_StdPeriph_Examples
- /** @addtogroup ETH_TCP_Server
- /* Gloable variables ---------------------------------------------------------*/
- __IO uint32_t LocalTime = 0; /* this variable is used to create a time reference incremented by 10ms */
- uint32_t timingdelay;
- /* Gloable functions ---------------------------------------------------------*/
- * [url=home.php?mod=space&uid=247401]@brief[/url] Main Function.
- * @param None
- * @retval None
- int main(void)
- unsigned char tcp_data[] = "TCP client experiment!\n";
- struct tcp_pcb *pcb;
- uint32_t Status;
- /* --------BSP Init ------------------------------------------------*/
- AT32_Board_Init();
- UART_Print_Init(115200);
- /* Setup AT32 system (clocks, Ethernet, GPIO, NVIC)*/
- Status = System_Setup();
- while(Status == ETH_DRIVER_FAIL);
- /* Initilaize LwIP satck, IP configuration and MAC configuration*/
- LwIP_Init();
- /* Initialize TCP client module */
- TCP_Client_Init(TCP_LOCAL_PORT,TCP_SERVER_PORT,TCP_SERVER_IP); //Initialize TCP client
- while(1)
- pcb = Check_TCP_Connect();
- if(pcb != 0)
- TCP_Client_Send_Data(pcb,tcp_data,sizeof(tcp_data)); //Send data to TCP server actively
- Delay_s(0xfffff); //necessary delay
- System_Periodic_Handle(); //Update TCP timers
- * [url=home.php?mod=space&uid=247401]@brief[/url] Inserts a delay time.
- * @param nCount: number of 10ms periods to wait for.
- * @retval None
- void Delay(uint32_t nCount)
- /* Capture the current local time */
- timingdelay = LocalTime + nCount;
- /* wait until the desired delay finish */
- while(timingdelay > LocalTime)
- * @brief Updates the system local time
- * @param None
- * @retval None
- void Time_Update(void)
- LocalTime += SYSTEMTICK_PERIOD_MS;
- * @brief Handles the periodic tasks of the system
- * @param None
- * @retval None
- void System_Periodic_Handle(void)
- /* LwIP periodic services are done here */
- LwIP_Periodic_Handle(LocalTime);
- /* TCP server and client configuration*/
- #define TCP_LOCAL_PORT 1030
- #define TCP_SERVER_PORT 1031
- #define TCP_SERVER_IP 192,168,1,19 //server IP
- static uint8_t G_IP[ADDR_LENGTH] = {192, 168, 1, 37};
- static uint8_t G_GW[ADDR_LENGTH] = {192, 168, 1, 187};
- static uint8_t G_MASK[ADDR_LENGTH] = {255, 255, 255, 0};
效果图:
注意还要关闭防火墙。
