kxsi 发表于 2021-6-7 18:40
灵动 MM32 + I2C驱动 OLED
一、硬件资源
(1)主控:灵动微 MM32F103CxT6;
(2)屏幕: [灵动MM32 + I2C驱动 OLED];
二、代码设计
1、I2C 初始化
* @briefConfigures I2C Device port.
* @paramulSpeed I2C baudrate.
* @retval None
static void Config_I2cDevice ( uint32_t ulSpeed )
        GPIO_InitTypeDef xGPIO_InitStruct;
        I2C_InitTypeDef xI2C_InitStruct;
        /* Enable clock. */
        RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOB, ENABLE );
        RCC_APB1PeriphClockCmd( RCC_APB1Periph_I2C1, ENABLE );
        /* Configure scl & sda GPIO parameters. */
        xGPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF_OD;
        xGPIO_InitStruct.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7;
        xGPIO_InitStruct.GPIO_Speed = GPIO_Speed_10MHz;
        GPIO_Init( GPIOB, &xGPIO_InitStruct );
        /* Configure I2C parameters. */
        xI2C_InitStruct.I2C_ClockSpeed = ulSpeed;
        xI2C_InitStruct.I2C_Mode = I2C_Mode_MASTER;
        xI2C_InitStruct.I2C_OwnAddress = 0x0;
        if ( ulSpeed <= 100000 ) { /* Configure speed in standard mode */
                xI2C_InitStruct.I2C_Speed = I2C_Speed_STANDARD;
        } else { /* Configure speed in fast mode */
                xI2C_InitStruct.I2C_Speed = I2C_Speed_FAST;
        I2C_Init( I2C1, &xI2C_InitStruct );
        /* Enable i2c1 port. */
        I2C_Cmd( I2C1, ENABLE );
kxsi 发表于 2021-6-7 18:41
2、I2C 硬件驱动
(a)、 根据官方提供源码修改,并且将其封装在 HAL_i2c 库文件内;
(b)、 该OLED 仅需要 写操作;
(c)、 在发送 STOP 停止信号前需延时 5us 才能正常显示(后续再找原因)。
* @briefWrites buffer of data to the I2C EEPROM.
* @parampxIO :typedef struct { GPIO_TypeDef* xPort; uint16_t usScl; uint16_t usSda; }I2C_GPIO_t;
* @parampBuffer : pointer to the buffercontaining the data to be written
*         to the EEPROM.
* @paramWriteAddr : EEPROM's internal address to write to.
* @paramNumByteToWrite : number of bytes to write to the EEPROM.
* @retval None
ErrorStatus I2C_WriteBuffer( const I2C_GPIO_t* pxIO, I2C_TypeDef* I2Cx, uint8_t DeviceAddr, uint8_t WriteAddr, uint16_t NumByteToWrite, uint8_t* pBuffer)
        uint32_t I2C_Timeout;
        uint16_t write_Num;
        xGPIO_InitStruct.GPIO_Pin= pxIO->usScl | pxIO->usSda;
        xGPIO_InitStruct.GPIO_Mode = GPIO_Mode_IPU;
        GPIO_Init( pxIO->xPort, &xGPIO_InitStruct );
        I2C_Cmd(I2Cx, DISABLE);
        I2C_Send7bitAddress( I2Cx, DeviceAddr, I2C_Direction_Transmitter );
        I2C_Cmd(I2Cx, ENABLE);
        I2C_SendData( I2Cx, WriteAddr );
        I2C_Timeout = 0x1000;
        while ( ( I2C_GetFlagStatus( I2Cx, I2C_STATUS_FLAG_TFE ) ) == RESET ) {
                if ( ( I2C_Timeout-- ) == 0 ) {
                        return ERROR;
        for ( write_Num=0; write_Num<NumByteToWrite; write_Num++ ) {
                                return ERROR;
                I2C_SendData( I2Cx, *( pBuffer + write_Num ) );
        /* 96MHz 工作频率下,延时5us. */
        for ( uint16_t i=480; i>0; i-- );
        I2C_GenerateSTOP( I2Cx, ENABLE );
        while ( ( I2C_GetITStatus( I2Cx, I2C_IT_STOP_DET ) ) == RESET ) {
                        return ERROR;
        /* If all operations OK, return sEE_OK (0) */
return SUCCESS;
3、OLED 程序模块
仅提供 Cmd & Data 部分,大部分和网络上的大同小异,可参考(正点原子、中景园电子、etc)。这篇**主要是 MM32 的 I2C,完整驱动代码下载链接在文末。
* @briefWrite commands to the screen.
* @paramucCmd    Write command to be written.
* @retval None.
static void Screen_WriteCmd( uint8_t ucCmd )
        I2C_WriteBuffer( &xConfig, I2C_DEVICE, I2C_ADDR, 0x00, 1, &ucCmd );
* @briefWrite data to the screen.
* @paramucCmd    Write data to be written.
* @retval None.
static void Screen_WriteDat( uint8_t ucDat )
        I2C_WriteBuffer( &xConfig, I2C_DEVICE, I2C_ADDR, 0x40, 1, &ucDat );
match007 发表于 2021-6-14 16:31
我要不要把IO模拟的方法给抛弃呢?
先MARK,哪天加班的时候,玩一玩
chenqianqian 发表于 2021-6-15 07:29
用硬件IIC吧
HuangHongLun 发表于 2021-6-15 09:06
硬件I2C的驱动确实比软件模拟要方便快捷多了,以后应该多使用硬件,不使用软件。
菜鸟的第一步 发表于 2021-6-15 13:27
果然还是硬件香,软件模拟的虽然方便简单,但是太弱了。
页: [1]
查看完整版本: 灵动 MM32 + I2C驱动 OLED
