| 2、I2C 硬件驱动 (a)、 根据官方提供源码修改,并且将其封装在 HAL_i2c 库文件内;
 (b)、 该OLED 仅需要 写操作;
 (c)、 在发送 STOP 停止信号前需延时 5us 才能正常显示(后续再找原因)。
 * @brief  Writes buffer of data to the I2C EEPROM.
 * @param  pxIO :typedef struct { GPIO_TypeDef* xPort; uint16_t usScl; uint16_t usSda; }I2C_GPIO_t;
 * @param  pBuffer : pointer to the buffer  containing the data to be written
 *         to the EEPROM.
 * @param  WriteAddr : EEPROM's internal address to write to.
 * @param  NumByteToWrite : number of bytes to write to the EEPROM.
 * @retval None
 ErrorStatus I2C_WriteBuffer( const I2C_GPIO_t* pxIO, I2C_TypeDef* I2Cx, uint8_t DeviceAddr, uint8_t WriteAddr, uint16_t NumByteToWrite, uint8_t* pBuffer)
 uint32_t I2C_Timeout;
 uint16_t write_Num;
 GPIO_InitTypeDef xGPIO_InitStruct;
 xGPIO_InitStruct.GPIO_Pin  = pxIO->usScl | pxIO->usSda;
 xGPIO_InitStruct.GPIO_Speed = GPIO_Speed_10MHz;
 xGPIO_InitStruct.GPIO_Mode = GPIO_Mode_IPU;
 GPIO_Init( pxIO->xPort, &xGPIO_InitStruct );
 I2C_Cmd(I2Cx, DISABLE);
 I2C_Send7bitAddress( I2Cx, DeviceAddr, I2C_Direction_Transmitter );
 I2C_Cmd(I2Cx, ENABLE);
 xGPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF_OD;
 I2C_SendData( I2Cx, WriteAddr );
 I2C_Timeout = 0x1000;
 while ( ( I2C_GetFlagStatus( I2Cx, I2C_STATUS_FLAG_TFE ) ) == RESET ) {
 if ( ( I2C_Timeout-- ) == 0 ) {
 return ERROR;
 for ( write_Num=0; write_Num<NumByteToWrite; write_Num++ ) {
 return ERROR;
 I2C_SendData( I2Cx, *( pBuffer + write_Num ) );
 /* 96MHz 工作频率下,延时5us. */
 for ( uint16_t i=480; i>0; i-- );
 I2C_GenerateSTOP( I2Cx, ENABLE );
 while ( ( I2C_GetITStatus( I2Cx, I2C_IT_STOP_DET ) ) == RESET ) {
 return ERROR;
 /* If all operations OK, return sEE_OK (0) */
 return SUCCESS;
 3、OLED 程序模块
 仅提供 Cmd & Data 部分,大部分和网络上的大同小异,可参考(正点原子、中景园电子、etc)。这篇**主要是 MM32 的 I2C,完整驱动代码下载链接在文末。
 * @brief  Write commands to the screen.
 * @param  ucCmd    Write command to be written.
 * @retval None.
 static void Screen_WriteCmd( uint8_t ucCmd )
 I2C_WriteBuffer( &xConfig, I2C_DEVICE, I2C_ADDR, 0x00, 1, &ucCmd );
 * @brief  Write data to the screen.
 * @param  ucCmd    Write data to be written.
 * @retval None.
 static void Screen_WriteDat( uint8_t ucDat )
 I2C_WriteBuffer( &xConfig, I2C_DEVICE, I2C_ADDR, 0x40, 1, &ucDat );
