求一个HC32F460 TIM6或TIMA TRIG引脚PWM捕获例子
如题,求TIM6_TRIGA/B或者TIMA_x_TRIG PWM输入捕获例程,谢谢了本帖最后由 sf116 于 2021-8-6 11:18 编辑
配置TIM6_TRIGA PWM捕获
1.Timer6_Init,应该配置哪个单元基础定时器?M4_TMR61\2\3?
2.Timer6_SetPeriod,Period register应该选择A\B\C?
3.PORT_SetFunc(PortE, Pin07, Func_Tim6, Disable);,Timer6_PortInputConfig, enPortSel选择Timer6TrigA,定时器应该选择哪个单元?4.Timer6_ConfigHwCaptureA(M4_TMR61, Timer6HwTrigTimTriARise);Timer6_ConfigHwClear(M4_TMR62, Timer6HwTrigTimTriARise); Timer6_EnableHwClear(M4_TMR61);
5.Timer6_ConfigIrq,中断类型和中断远应该选哪个?
Timer6INTENA = 0u, ///< Interrupt of count equal to GCMA (or capture input A)
Timer6INTENB = 1u, ///< Interrupt of count equal to GCMB (or capture input B)
Timer6INTENC = 2u, ///< Interrupt of count equal to GCMC
Timer6INTEND = 3u, ///< Interrupt of count equal to GCMD
Timer6INTENE = 4u, ///< Interrupt of count equal to GCME
Timer6INTENF = 5u, ///< Interrupt of count equal to GCMF
Timer6INTENOVF= 6u, ///< Interrupt of over flow of sawtooth wave mode or peak point of triangular wave mode
Timer6INTENUDF= 7u, ///< Interrupt of under flow of sawtooth wave mode or valley point of triangular wave mode
Timer6INTENDTE= 8u, ///< Interrupt of dead timer error
Timer6INTENSAU= 16u, ///< Interrupt of count up equally compared with SCMA
Timer6INTENSAD= 17u, ///< Interrupt of count down equally compared with SCMA
Timer6INTENSBU= 18u, ///< Interrupt of count up equally compared with SCMB
Timer6INTENSBD= 19u, ///< Interrupt of count down equally compared with SCMB
6.以上配置完成,硬件启动即可?
Timer6_ConfigHwStart(M4_TMR61, Timer6HwTrigTimTriARise);
Timer6_EnableHwStart(M4_TMR61);
版主大佬帮个忙?
页:
[1]
