whereis 发表于 2007-1-27 20:12
[转贴]嵌入式处理器与外围的选择及其分销网络
这个是04年的综述,介绍了46家ic公司的处理器,原帖在ednchina,现在找不到出处了,抱歉。<br />当然,还是有被漏掉的公司,有公司已经易名,比如Philips&nbsp;Semiconductors。<br /><br />BTW:销售网点慢慢补充,也欢迎大家群策群力,买片子也就方面多了。<br />&nbsp;&nbsp;&nbsp;&nbsp;该处的分销网络为芯片原厂网站所提供,不包括独立的分销商。<br /><br />公司的列表:<br />01.Actel&nbsp;Corp<br />02.Advanced&nbsp;Micro&nbsp;Devices<br />03.Altera<br />04.Analog&nbsp;Devices<br />05.Applied&nbsp;Micro&nbsp;Circuits&nbsp;Corp<br />06.ARC&nbsp;International<br />07.ARM<br />08.Atmel<br />09.Cirrus&nbsp;Logic<br />10.Cyan&nbsp;Technology<br />11.Cybernetic&nbsp;MicroSystems<br />12.Cypress&nbsp;Microsystems<br />13.Dallas&nbsp;Semiconductor<br />14.Freescale&nbsp;Semiconductor<br />15.Fujitsu&nbsp;Microelectronics&nbsp;America<br />16.Hyperstone<br />17.Infineon&nbsp;Technologies<br />18.Integrated&nbsp;Device&nbsp;Technology<br />19.Intel<br />20.Microchip&nbsp;Technology<br />21.MIPS&nbsp;Technologies<br />22.National&nbsp;Semiconductor<br />23.NEC&nbsp;Electronics<br />24.NetSilicon<br />25.Oki&nbsp;Semiconductor<br />26.Philips&nbsp;Semiconductors<br />27.PMC-Sierra<br />28.QuickLogic<br />29.Rabbit&nbsp;Semiconductor<br />30.Renesas&nbsp;Technology<br />31.Samsung&nbsp;Electronics<br />32.Sharp&nbsp;Microelectronics<br />33.Silicon&nbsp;Laboratories<br />34.Silicon&nbsp;Storage&nbsp;Technology<br />35.ST&nbsp;Microelectronics<br />36.Stretch<br />37.SuperH<br />38.Tensilica<br />39.Texas&nbsp;Instruments<br />40.Toshiba&nbsp;America&nbsp;Electronic&nbsp;Components<br />41.Transmeta<br />42.Ubicom<br />43.Via&nbsp;Technologies<br />44.Xemics<br />45.Xilinx<br />46.Zilog
whereis 发表于 2007-1-27 20:22
02.Advanced&nbsp;Micro&nbsp;Devices<br /> (http://www.amd.com/)<br /><br />  AMD提供基于x86的产品线,满足了嵌入式、移动和企业级服务器和工作站以及台式PC的需要。今年,AMD推出了AMD&nbsp;Opteron、AMD&nbsp;Athlon&nbsp;64、Mobile&nbsp;AMD&nbsp;Athlon&nbsp;64等型号处理器。AMD64处理器系列提供了EVP(增强病毒防护)能力,用于实现更安全的计算环境,并且它具有直接连接架构(Direct&nbsp;Connect&nbsp;Architecture),该架构把内存控制器和I/O直接连接到CPU,改善了总体系统性能和效率。<br /><br />  AMD64系列处理器在32和64位平台上延伸了x86&nbsp;ISA。AMD&nbsp;Opteron处理器的目标是服务器和工作站,AMD&nbsp;Athlon&nbsp;64处理器和Mobile&nbsp;AMD&nbsp;Athlon&nbsp;64处理器的目标分别是台式PC和移动PC。AMD&nbsp;Athlon&nbsp;XP和&nbsp;AMD&nbsp;Athlon&nbsp;XP-M处理器具有QuantiSpeed架构以及对AMD的3DNow!&nbsp;Professional指令的支持,这些指令用于增强多媒体。Athlon&nbsp;XP-M处理器采用较小的PGA封装,来支持“轻薄”设计。<br /><br />  AMD&nbsp;Geode处理器系列的目标是宽带多媒体、机顶盒和瘦客户机应用。开发人员可以通过运用“性能功率评级”术语来比较Geode处理器,以便选择具有适当性能和功耗组合的处理器。今年,AMD发布了一系列高性能嵌入式Geode处理器,它们基于该公司的AMD&nbsp;Athlon内核。<br /><br />ElanSC5220&nbsp;x86控制器涵盖了数据通信、电信和信息家电市场。<br /><br />  AMD基于MIPS的Alchemy微处理器的目标是PDA、网络浏览板(Web&nbsp;tablet)、便携式或有线互联网访问设备、网关应用。今年,该公司还推出了AMD&nbsp;Alchemy&nbsp;Au1550安全网络处理器。Au1550处理器的低功耗特性使它适合于电池供电应用和以太网供电应用。
whereis 发表于 2007-1-27 20:23
03.Altera<br /><br />  (http://www.altera.com/)<br /><br />  三种Nios&nbsp;II通用RISC处理器软内核设计用于Altera公司的Stratix、Stratix&nbsp;II、Cyclone和HardCopy器件系列。标准的Nios&nbsp;II/s内核提供了内核尺寸和性能之间的平衡,而Nios&nbsp;II/e和Nios&nbsp;II/f把这种平衡分别推向更小的内核或更快的性能。Nios&nbsp;II/e内核仅消耗价值35美分的逻辑电路,而Nios&nbsp;II/f可以达到200&nbsp;Dhrystone&nbsp;MIPS性能。所有三种内核共享一个共同的32位ISA,并且100%二进制代码兼容。设计人员使用Altera的Quartus&nbsp;II设计软件配备的SOPC(可编程片上系统)Builder工具。Altera继续支持它的第一代Nios嵌入式处理器。<br /><br />  Altera公司提供的Excalibur嵌入式处理器把ARM922T处理器子系统和该公司的可编程逻辑电路架构集成在一起。Excalibur器件使您能够在配置FPGA之前,以独立方式来操作该处理器。Altera的SOPC&nbsp;Builder系统集成工具利用智能开关结构来连接处理器、外设、用户自定义外设,它还能生成定制的软件开发工具包。
whereis 发表于 2007-1-27 20:24
04.Analog&nbsp;Devices<br /> (http://www.analog.com/)<br /><br />  Analog&nbsp;Devices公司的ADuC702x系列高精度模拟微控制器集成了一个32位ARM7TDMI内核和一些12位ADC。这些器件的目标是一些工业、光联网和汽车应用,控制和监视在这些应用中至关重要。它们支持多达16路快速12位精度的模数转换和4个12位DAC。ARM7TDMI具有一个基于闪存的&nbsp;16/32位RISC处理器内核,该内核集成了模拟外设,比如一个高精度的能带隙参考源(bandgap&nbsp;reference),该参考源的漂移性能好于10ppm/℃。其它外设包括一个比较器、一个用于胶合逻辑的可编程逻辑电路阵列、一个三相PWM发生器。<br /><br /><br />办事处与代理商<br />http://www.analog.com/intl/china/salesdir/distributors.html<br /><br />
05.Applied&nbsp;Micro&nbsp;Circuits&nbsp;Corp<br /><br />  (http://www.amcc.com/)<br /><br />  在过去一年,AMCC公司获得了32位PowerPC&nbsp;400系列处理器。PowerPC&nbsp;405系列的目标是低成本、低功率应用,比如工作组交换机、无线接入点、工作于133MHz~400MHz的光纤通道交换机。PowerPC&nbsp;440系列器件工作于400MHz~800MHz,包括集成的TCP加速、千兆位以太网、DDR&nbsp;SRAM和PCI-X接口。通用PowerPC&nbsp;440GX处理器的目标是联网、存储和太空应用。PowerPC&nbsp;440EP的目标是成像和工业控制市场。对于那些需要额外性能或想改用DDR内存的客户,该组件可以作为升级路径。PowerPC&nbsp;440SP提供PowerPC处理器当中最宽的PCI带宽,这是因为它提供了两个64位PCI-X接口和一个32位PCI接口,这使它适合于存储市场。<br /><br />
whereis 发表于 2007-1-27 20:26
06.ARC&nbsp;International<br /><br />  (http://www.arc.com/)<br /><br />  ARC系列可综合、可由用户定制的32位RISC处理内核包括ARCtangent-A4、ARCtangent-A5、ARC600和ARC700。开发人员刚开始可以使用一个基本的ARC处理器内核,然后增加和定制各种功能,从而为各自的应用来平衡计算性能、面积和功耗。基本配置代表了最小的实现。每种处理器能支持可选的DSP指令和一个高吞吐率的XY内存接口。设计人员可以通过增加指令和内核寄存器来扩展处理器,以便进一步定制系统性能。<br /><br />  七级32位标量ARC700&nbsp;RISC处理器架构的目标是高数据速率应用。该处理器可作为可综合HDL,它可以移植到几乎任何芯片代工厂或综合库。ARC700使用ARCompact&nbsp;ISA,并向后兼容ARCtangent-A5和ARC&nbsp;600处理器。虽然ARC&nbsp;700提供了很高的时钟速率,但它在面积方面为性能做的折衷很少。<br /><br />  五级32位ARC600&nbsp;RISC架构包含各种低功耗功能,使它适合于便携式消费设备。设计人员使用ARChitect2处理器配置工具来改变内核的配置并定义定制的处理器扩展。&nbsp;ARCtangent-A5包含ARCompact16/32位ISA,与单纯的32位指令集架构相比,使用它可以使代码规模缩小40%。作为该系列中最小最快的内核之一,ARCtangent-A4非常适合于一系列联网应用。ARC提供了传统的可综合8位通用Intel&nbsp;8086/80186架构。
07.ARM<br /><br />  (http://www.arm.com/)<br /><br />  ARM公司进行知识产权(IP)的授权,这些IP用于开发基于32位RISC微处理器的系统芯片。ARM提供各种处理器内核,包括ARM7、ARM9、&nbsp;ARM10、ARM11和MPCore多处理器系列,它们基于共同的架构,该架构着重于低功耗和低系统成本情况下的性能。ARM提供SecurCore技术,目标是安全应用,比如智能卡和SIM(用户身份模块)。ARM还提供OptimoDE&nbsp;数据引擎单处理技术,以及它与Imagination&nbsp;Technologies公司合作开发的MBX&nbsp;2D和3D图形加速器内核。
08.Atmel<br /><br />  (http://www.atmel.com/)<br /><br />  Atmel公司利用7种微控制器或微处理器架构提供面向嵌入式产品市场的各种标准产品、ASIC和专用选件。这些架构包括4位Marc4(目标是低功率汽车应用)、8位AVR和8051、16位ARM&nbsp;Thumb、32位ARM和MIPS、32位Sparc(适合于能承受辐射的航天设计)。Atmel提供各种基于ARM公司先进的RISC内核的32位微控制器。该系列产品提供多种内存大小和面向高性能应用的片上功能。Atmel还提供一系列可靠性高的微控制器,它们基于Motorola&nbsp;PowerPC架构,用于军事和空间应用。<br /><br />  Atmel公司的AVR&nbsp;RISC微控制器执行单周期指令。AVR器件的特点包括片上、系统内可编程闪存和EEPROM、内部振荡器、定时器、上拉电阻、脉宽调制、ADC、模拟比较器、看门狗定时器。该系列的范围是从tinyAVR(1KB片上闪存)到megaAVR(128KB片上闪存)。megaAVR支持一种100nA省电方式。<br /><br />  8051系列包括具有系统内编程能力的MCS-51插槽插入器件,以及各种小面积20引脚派生器件,这些派生器件的形式为ROMless、ROM、一次可编程、闪存。其中一些器件实现了X2模式,该模式为CPU和外设把内部时钟频率增倍。8051派生器件还包括一些专用产品,这些产品的目标是CAN、&nbsp;MP3应用、智能卡读卡器、USB应用、万维网嵌入式TCP/IP。<br /><br />  在过去一年,Atmel推出了具有更多CAN功能的8位AVR&nbsp;AT90CAN128闪存控制器。AT90CAN128集成了mega128和V2.0A/V2.0BCAN控制器的功能,Atmel&nbsp;CANary微控制器系列使用这些功能。该CAN控制器能处理15个独立的消息对象,可以在运行中对它们编程。AT90CAN128配备一个16&nbsp;MIPS&nbsp;AVR&nbsp;RISC引擎、128KB闪存程序存储器、4KBRAM、4KB片上EEPROM,适合于工业控制应用。<br /><br />
whereis 发表于 2007-1-27 20:27
09.Cirrus&nbsp;Logic<br /><br />  (http://www.cirrus.com/)<br /><br />  Cirrus&nbsp;Logic公司基于ARM9的新型EP9301、EP9302和EP9315嵌入式处理器和以前推出的EP9312的目标是销售点终端、医疗仪器、安全和监视、工艺监视、数字娱乐等应用。这些处理器包括WinCE.NET电路板支持包和Linux内核端口。<br /><br />  基于ARM的入门级EP9301的工作频率高达166MHz,外部总线速度达66MHz,集成了1/10/100-BaseT以太网MAC(媒体访问控制器),配有两个USB2.0主机端口。200MHz&nbsp;EP9302联网SOC集成了一个以太网接口和各种外设。EP9307图形和人机接口的目标是各种联网应用,它们需要一个图形加速器以及各种显示功能和音频功能来创建一个丰富的人机接口。EP9312SOC配备一个200&nbsp;MHz&nbsp;ARM9处理器和100MHz系统总线。它包括MaverickCrunch数学引擎、MaverickKey技术,以及各种集成的外设,比如两个&nbsp;EIDE器件、一个1/10/100-Mb/s以太网MAC、三个USB2.0主机端口、LCD接口和触摸屏接口。<br /><br />  高度集成的EP9315处理器的基础是EP9312的各种功能,面向下一代消费应用和工业应用。EP9315的处理器速度高达200MHz,总线速度为&nbsp;100MHz,并集成了以太网MAC、PCMCIA支持、双通道IDE、三个USB2.0主机端口。EP9315还支持一个18位显示器、一个触摸屏、一个袖珍键盘,并且增加了一个单独的图形加速器来加速块复制等基本的图形功能。EP9315支持多种音频选择以及6声道24位I2S音频,并且能编解码各种音频算法,比如AAC、MP3、Windows&nbsp;Media&nbsp;Audio。<br /><br />  MaverickKey技术是Cirrus除EP9301之外所有基于ARM9的嵌入式处理器上的标准技术,包括MaverickKey数字版权管理工具和先进的MaverickCrunch混合模式数学协处理器。MaverickKey技术使设计人员能够为数字版权管理实现分配硬件ID。该技术能在产品进入制造阶段时防止设计盗版。MaverickCrunch引擎大大加快了&nbsp;ARM920T处理器内核的单精度和双精度整数和浮点处理功能。<br /><br />
10.Cyan&nbsp;Technology<br /><br />  (http://www.cyantechnology.com/)<br /><br />  Cyan&nbsp;Technology公司基于闪存的低功率16位嵌入式通信eCOG1k微控制器实现了25MHz&nbsp;RISC&nbsp;Harvard架构,该架构包括64KB内部闪存、4KB&nbsp;RAM及2KB高速缓存,来降低它与闪存联合使用时的功耗。外部存储器接口支持32MB外部存储器的寻址能力。其它特点包括IrDA、一个智能卡接口、一个4通道12位ADC、一个温度传感器、一个24位长的内部定时器、DMA、一个MMU、一个专有端口配置器。Cyan的开发软件包括CyanIDE,它包含一个完整的ANSI无限C编译器、仿真器、调试器、外设配置软件。外设配置软件使用户能选择他们需要的那些外设,并把它们连接到选定的引脚。外设寄存器设置代码在汇编语言中自动生成。所有Cyan开发软件都可免费下载。
whereis 发表于 2007-1-27 20:28
11.Cybernetic&nbsp;MicroSystems<br /><br />  (http://www.controlchips.com/)<br /><br />  Cybernetic&nbsp;MicroSystems公司的ASIC连接到各种很难从通用计算机控制的外设。这些芯片提供了一个高度可编程的接口,连接到外设的低层功能。这种100&nbsp;引脚的8位P-51微控制器或者位于计算机主机和外设之间,或者本身就成为外设。P-51配备一个主机端的双端口RAM接口(PC104/ISA格式),看起来像是主机的存储器,但它具有8051的智能和功能,比如定时器、计数器、若干I/O端口、若干中断,以及一个特殊的平方根函数,用于外设应用。<br /><br />  P-51可链接,因此您能复制它,用于单个主机上的多任务处理。它能处理那些针对PC104嵌入式系统应用的通用操作系统不能处理的实时外设硬件和中断。它具有复位时的电路内可编程能力,因此您能轻松下载和升级8051代码。它包括内置的调试功能,比如断点和单步调试,从而在没有ICE的情况下实现电路内代码开发。
whereis 发表于 2007-1-27 20:29
12.Cypress&nbsp;Microsystems<br /><br />  (http://www.cypressmicro.com/)<br /><br />  Cypress&nbsp;MicroSystems公司的现场可编程混合信号PSOC(可编程片上系统)阵列的目标是消费、工业、办公自动化、电信、汽车应用中的嵌入式控制功能。&nbsp;PSOC器件把一个8位处理器内核和一些可编程模拟和数字逻辑块、16KB闪存、256B&nbsp;SRAM,以及一个MAC(乘法累加)单元集成在一起。所有PSOC器件都是可动态重新配置的,使得设计人员能在运行中创建系统功能,这能使裸片的使用率超过120%。例如,汽车PSOC&nbsp;LIN(本地互连网络)总线参考设计四次重复使用同样的晶体管来支持LIN通信方式,这样,这些晶体管消耗不到10%的PSOC硬件资源。<br /><br />  新一代CY8C27x器件系列改善了较早的PSOC器件的模拟支持,具有仪器质量的模拟性能,包括满摆幅输入、可编程增益,以及低噪声、输入泄漏和电压偏移,用于4个14位ADC的外设块。它包括12个片上模拟块、8个数字块、一个配备32位累加器的8×8乘法器、16KB闪存、256B&nbsp;SRAM。CY8C24xxx系列包括6个模拟块、4个数字块,它适合于电机控制和运动控制应用。CY8C22xxx系列配备3个模拟块、4个数字块,目标是传感器应用,包括火情检测设备和入侵检测设备。<br /><br />  PSOC系列包括一些预先编程的专门版本,用于照明、能源、电机控制、通信、汽车、电池应用。系列中的各个型号都配备一个参考设计和广泛的应用说明,用于加快应用开发。PSOC器件采用节省空间的MLF封装,该封装具有优秀的散热和电性能,是手持便携设备的理想选择。
14.Freescale&nbsp;Semiconductor<br /><br />  (http://www.freescale.com/)<br /><br />  Freescale&nbsp;Semiconductor公司以前是Motorola公司的半导体产品部,提供多种微处理器和微控制器,它们面向汽车、通信和联网、消费、工业、普适计算等市场。Freescale提供一系列8位、16位、32位微控制器和微处理器,目标是各种消费应用,包括遥控无密钥开关(remote-&nbsp;keyless-entry)设备、计步器、MP3播放器、白色家电;工业控制设备,比如机器人技术、诊断仪器、工厂自动化工具;汽车应用,包括防抱死系统、气囊、传动系系统。<br /><br />  Freescale基于32位PowerPC内核的PowerQuicc系列提供数据面和控制面处理,用于无线基础设施、企业路由和交换、网络接入和聚合、SOHO和零售访问、普适计算设计。它的PowerPC处理器提供千兆赫兹性能,而功率不足10W。<br /><br />
whereis 发表于 2007-1-27 20:31
16.Hyperstone<br /><br />  (http://www.hyperstone.com/)<br /><br />  Hyperstone公司基于RISC的32位单内核处理器能执行RISC指令和DSP指令,并行度很高。RISC指令和DSP指令使用一个ALU用于正常的RISC指令执行,还使用一个单独的DSP指令执行单元。ALU指令单元和DSP指令单元共享一套寄存器,并且执行对于用户而言是透明的。所有指令,包括执行DSP功能的那些指令,都采用基于一种加载/存储架构的RISC原则。指令的长度是可变的,以便提高内存和速度效率。E1-32XSR内核是一种静态设计,工作频率快达220MHz,每秒执行多达8.80亿次操作。220MHz时,耗电量是40mA,并且在低功率模式时降低至100μA。提供一整套硬件和软件开发工具,包括一种实时内核。<br /><br />  Hyperstone公司提供专门的CompactFlash、SD闪存、MMC闪存控制器,它们基于E1-32XS内核。这些处理器配备一个闪存接口,可以连接到SamsungNAND闪存(或等效产品)或HitachiAND闪存(或等效产品)。这些控制器利用CompactFlash(F2-16X)、SD闪存(S2-16X)或MultiMedia闪存(M2-16X)连接到主机。它们能处理16个闪存设备。<br /><br />  Hyperstone公司高度集成的新型HyNet32XS联网处理器基于E132XSRRISC/DSP处理器内核。它可工作于最高达220MHz的时钟速率。HyNet32XS借助一个6通道DMA控制器来使用4条内部总线。它集成了两个配备MII(媒体无关接口)的10/100Mb/s以太网MAC、一个集成的10/100Mb/s以太网PHY、配备收发器的USB1.1、ATM&nbsp;Utopia&nbsp;Level2(支持连接3个外部PHY)、一个PCM接口(连接到一个外部IOM-2接口)、一个CAN总线接口(兼容CAN2.0和&nbsp;PhilipsSJA1000)、一个YuV接口(用于符合CCIR656的视频输入)。
whereis 发表于 2007-1-27 20:32
17.Infineon&nbsp;Technologies<br /><br />  (http://www.infineon.com/)<br /><br />  Infineon公司的处理器既可作为独立器件,又可作为嵌入式处理器内核。C500微控制器系列的器件在架构和软件方面完全兼容8051微控制器系列,在外设部件的数量和复杂性方面有区别,这是Infineon公司针对特定应用而做的调整。<br /><br />  C166系列微控制器提供高达40MHz的时钟速度、外设支持,以及可编程能力,面向工业控制设备、汽车电子设备、PC外设控制设备、消费电子设备。<br /><br />  除了C166系列CPU以外,C166S可综合内核可作为Synopsys公司的DesignWare&nbsp;Star&nbsp;IP计划中的内核。XC164CM在时钟速度与C166前几代产品相同的情况下,提供的性能是它们的两倍。XC164CM也采用小型封装,与同类方法相比,需要的电路板空间减少了20%。<br /><br />  TriCore统一微控制器/DSP架构用作单一多任务引擎,具有快速的上下文切换。基于TriCore的TC-1MP微处理器可作为&nbsp;SynopsysDesignWareStarIP计划中的一种硬内核及可完全综合的宏。该内核的应用包括伺服控制、音频域DSP(比如语音处理)、数据通信、调制解调器、汽车系统、手机和互联网家电等便携应用。<br /><br />  Infineon公司支持Linux的32位TC1130微控制器基于&nbsp;TriCore统一处理器架构,并运行Linux操作系统,用于工业应用和通信应用。TC1130设计用于PLC系统、高性能电机驱动系统、工业通信设备(如交换机、集线器、路由器),以及机顶盒等消费应用。<br /><br />
whereis 发表于 2007-1-27 20:33
19.Intel<br /><br />  (http://www.intel.com/)<br /><br />  Intel&nbsp;IXP4XX产品线的目标是多种应用,比如高端住宅网关,中小型企业路由器、交换机和安全设备,无线访问点,工业控制系统,网络打印机。IXP4XX产品线包括IXP425、IXP422、IXP421和IXP420网络处理器。Intel的IXC1100控制平面处理器基于与IXP4XX处理器相同的硬件和软件架构。它的目标是有线或无线电信设备以及其它联网的嵌入式设备中的控制平面功能。<br /><br />  Intel&nbsp;Architecture系列处理器的目标是传统的嵌入式系统应用,比如销售点、信息亭、ATM、NAS(网络连接存储)、高端SAN(存储区域网络)、工业控制、工厂自动化、医疗成像、支持无线和有线基础设施的通信应用。Architecture处理器包括Celeron、超低压Celeron、&nbsp;Pentium4、PentiumM、Xeon和低压Xeon处理器。今年,Intel推出了Intel&nbsp;PentiumM、Pentium4、低压Xeon、Xeon处理器系列中性能更高的处理器。这一系列处理器的速度高达3GHz,功耗更低,具有超线程功能、双处理、高I/O带宽。
whereis 发表于 2007-1-27 20:34
20.Microchip&nbsp;Technology<br /><br />  (http://www.microchip.com/)<br /><br />  Microchip&nbsp;Technology公司的PIC&nbsp;RISC微控制器平衡了性能、成本和紧凑的封装。PIC微控制器架构为用户在所有系列当中提供了从8根引脚到84根引脚的迁移途径,并且代码几乎或根本没有变化。先进的特性包括尖端的定时外设、ADC、处理器间通信外设(包括I2C、SPI、USB和CAN端口以及USART)、电路内串行编程,以及内存技术——其中包括PEEC(PMOS电可擦除单元)闪存,它在整个工作温度范围,在每个内存位置都能执行100万个擦/写周期。先进特性还包括&nbsp;EEPROM、一次可编程存储器、ROM。<br /><br />  Microchip&nbsp;Technology公司的PIC&nbsp;8位微控制器推出活动包括其CAN产品组合的扩充,该组合增加了PIC18F860系列,它配备新型ECAN(增强型CAN)模块。CAN2.0B&nbsp;ECAN接口提供了对DeviceNet协议的硬件支持以及可配置收发缓冲器,这些缓冲器可用于标准的CAN操作,或用作FIFO寄存器。该公司还发布了&nbsp;PIC16F684/688/12F683器件,它们采用8引脚和14引脚封装,目标是家电、电池供电产品和手持产品、传感器、接口、汽车控制、通用控制等应用。PIC18F4431系列配备多种外设,用于汽车、工业、家电、消费应用中的电子电机控制。<br /><br />  dsPIC系列DSC(数字信号控制器)配备一个完全实现的DSP引擎,并具有30&nbsp;MIPS非流水线性能、对C编译器友好的设计、一个用户熟悉的微控制器架构和设计环境。20&nbsp;dsPIC30FXXXX&nbsp;16位闪存DSC的目标是电机控制、功率转换、传感器、通用应用。MPlabC30C编译器支持dsPIC&nbsp;DSC基础结构。针对dsPIC30F架构,第三方支持以及19种硬件及软件支持工具和库可供使用。<br /><br />
whereis 发表于 2007-1-27 20:35
21.MIPS&nbsp;Technologies<br /><br />  (http://www.mips.com/)<br /><br />  MIPS&nbsp;Technologies公司为数字消费品、联网、安全等应用提供可综合的内核。该公司把它的知识产权授权给半导体公司、ASIC开发商、系统OEM。&nbsp;MIPS&nbsp;Technologies公司的32位可综合产品包括4K、M4K、4KE、4KS、24K系列内核。这些内核包括多种特性、代码压缩,具有低功耗和高性能。SOC设计者使用5K系列可综合处理器内核能够使各自的应用达到最高频率和性能,并能灵活选择任何加工厂工艺和配置来适合各自应用的需要。<br /><br />  Pro系列内核使专家级SOC设计者能够把自己的CorExtend指令扩展和函数写入内核,从而创造独特的产品。运用标准工具和软件,设计者能够实现CorExtend指令来提高性能、降低功耗、实现关键操作。<br /><br />  在过去一年,MIPS&nbsp;Technologies公司推出了MIPS32&nbsp;24K系列内核,它们支持定制的SOC设计方法、一种OCP(开放内核协议)互连结构、标准的库、片上内存。24K系列支持CorExtend功能,并包括多种特性,比如超快的乘法、智能高速缓存、浮点支持,使它适合于互动电视、机顶盒、DVD和其它由性能推动的应用。MIPS&nbsp;Technologies公司还推出了MIPS消费型音频平台,这是一种通用基础平台,使设计者能够实现音频编解码器,用于那些以高速发展的嵌入式系统市场为目标的设备。
22.National&nbsp;Semiconductor<br /><br />  (http://www.national.com/)<br /><br />  National&nbsp;Semiconductor公司的CP3000连接处理器系列结合了一种RISC内核、片上SRAM和闪存、硬件通信外设、可扩充外部总线,目标是嵌入式系统通信应用,比如汽车网络网关、免提轿车工具包,以及工业和医疗仪器和控制。蓝牙版本包括一个免NRE和专利使用费的蓝牙堆栈,以及蓝牙应用规范的源代码。National&nbsp;Semiconductor公司的单片CP3000处理器配备蓝压较低链路控制器、USB、CAN、Access总线、Microwire/Plus、&nbsp;SPI、UART、先进音频接口。<br /><br />  COP8闪存微控制器具有一个8位内核和32KB板上闪存,可把这些闪存当作数据存储器或程序存储器,可工作10万多次删除/写周期。这些器件提供虚拟EEPROM功能、系统内编程、集成的模拟功能和混合信号功能,用于独立应用和互联网控制的应用。National&nbsp;Semiconductor公司的Webench在线设计环境支持针对COP8闪存器件的开发工作,它使设计者能够预先配置微控制器和接收应用的源代码。
whereis 发表于 2007-1-27 20:36
23.NEC&nbsp;Electronics<br /><br />  (http://www.necelam.com/)<br /><br />  NEC&nbsp;Electronics&nbsp;America公司制造并销售各种高度集成的低功率嵌入式微处理器和微控制器,目标是从消费电子产品到高端计算、通信、汽车、无线、联网的各种应用。8位的K0和K0S系列配备闪存,并集成了各种外设,比如LCD驱动器和控制器。这些微控制器的目标是消费电器和工业控制应用。32位V850系列提供32位处理性能、低压操作、DSP功能、片上外设,目标是消费电子产品和其它嵌入式系统应用。基于MIPS的64位VR系列微处理器提供高性能的可伸缩性,目标是各种嵌入式系统,从互联网设备和数字消费电子设备到服务器和交换机。该公司提供多种开发系统,包括硬件平台和软件包。<br /><br />  在过去一年,NEC&nbsp;Electronics&nbsp;America公司发布了配备FPU的32位V850E/CG25-CAN网关微控制器,以及32位V850/RS1微控制器,用于高端汽车安全应用。通过推出32位V850E/IA3和V850E/IA4微控制器,该公司扩大了它的电机控制和逆变器控制产品组合,还推出了8位uPD78F0714和32&nbsp;位V850ES/IK1,用于电子家庭应用。V850ES/IK1是该公司第一种采用V850ES&nbsp;CPU内核的逆变器应用产品。
页: [1] 2 3 4
查看完整版本: [转贴]嵌入式处理器与外围的选择及其分销网络
