STM32F030启用内部晶振
在文件 system_stm32f0xx.c 里的函数static void SetSysClock(void)
if (HSEStatus == (uint32_t)0x01) // 存在外部时钟
else
// 这里添加配置48M代码
完整代码如下:
__IO uint32_t StartUpCounter = 0, HSEStatus = 0;
/* SYSCLK, HCLK, PCLK configuration ----------------------------------------*/
/* Enable HSE */
RCC->CR |= ((uint32_t)RCC_CR_HSEON);
/* Wait till HSE is ready and if Time out is reached exit */
do
HSEStatus = RCC->CR & RCC_CR_HSERDY;
StartUpCounter++;
} while ((HSEStatus == 0) && (StartUpCounter != HSE_STARTUP_TIMEOUT));
if ((RCC->CR & RCC_CR_HSERDY) != RESET)
HSEStatus = (uint32_t)0x01;
else
HSEStatus = (uint32_t)0x00;
/* Enable Prefetch Buffer and set Flash Latency */
FLASH->ACR = FLASH_ACR_PRFTBE | FLASH_ACR_LATENCY;
/* HCLK = SYSCLK */
RCC->CFGR |= (uint32_t)RCC_CFGR_HPRE_DIV1;
/* PCLK = HCLK */
RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE_DIV1;
/* PLL configuration = HSE * 6 = 48 MHz */
RCC->CFGR &= (uint32_t)((uint32_t) ~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLMULL));
RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_PREDIV1 | RCC_CFGR_PLLXTPRE_PREDIV1 | RCC_CFGR_PLLMULL6);
/* Enable PLL */
RCC->CR |= RCC_CR_PLLON;
/* Wait till PLL is ready */
while ((RCC->CR & RCC_CR_PLLRDY) == 0)
/* Select PLL as system clock source */
RCC->CFGR &= (uint32_t)((uint32_t) ~(RCC_CFGR_SW));
RCC->CFGR |= (uint32_t)RCC_CFGR_SW_PLL;
/* Wait till PLL is used as system clock source */
while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS) != (uint32_t)RCC_CFGR_SWS_PLL)
else
// HSI 内部时钟做为PLL时钟源并配置PLL 48M做为系统时钟
/* HCLK = SYSCLK */
/* PCLK = HCLK */
// PLL configuration = (HSI/2) * 12 = 48 MHz
RCC_PLLConfig(RCC_PLLSource_HSI_Div2, RCC_PLLMul_12); // 8M/2 * 12 = 48M
/* Enable PLL */
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK); // PLL 做系统时钟
这个方式不错,很方便, 同时开启内部晶振和外部晶振,在外部失效可自动启用内部时钟,很完善的方法,值得肯定 caosix 发表于 2022-3-13 10:50
谢谢 楼主,这个芯片 内部 8MHz外面 也 8MHz 【便于 切换】
内外相同也不是便于切换,时钟还是要自己处理,如果不处理,外部倍频,内部不倍频,使用内部就一直是8M 实用经验,感谢大佬分享 F0开启内部晶振比较好,毕竟低成本,如果用晶振的话 就贵了
页:
[1]
