菜鸟的第一步 发表于 2022-2-28 12:20
MM32SPIN422C PWM配置,驱动无刷电机
这个芯片的驱动控制有一个使能脚,驱动无刷电机的时候需要打开这个引脚:
PB12使能驱动口
* @name   : initGPIO_Timer1
* @brief: Init GPIO Timer1
* @param: void
* @retval : void
void initPWM_EN(void)
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOB, ENABLE);//开启GPIOA、GPIOB时钟
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;//推挽输出
        GPIO_Init(GPIOB, &GPIO_InitStructure);
        GPIOB->BSRR = GPIO_Pin_12;//使能栅极驱动器
菜鸟的第一步 发表于 2022-2-28 12:21
然后正常配置互补PWM
GPIO口配置和互补PWM配置
//PWM输出初始化
//arr:自动重装值
//psc:时钟预分频数
void TIM1_PWM_Init(u16 arr,u16 psc)
        TIM_TimeBaseInitTypeDefTIM_TimeBaseStructure;
        TIM_OCInitTypeDefTIM_OCInitStructure;
    TIM_BDTRInitTypeDef TIM_BDTRInitStruct;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1,ENABLE);
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA|RCC_AHBPeriph_GPIOB, ENABLE);//开启GPIOA、GPIOB时钟
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10; //TIM1_CH1,TIM1_CH2
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;//复用推挽输出
        GPIO_Init(GPIOA, &GPIO_InitStructure);
        GPIO_PinAFConfig(GPIOA, GPIO_PinSource8,GPIO_AF_2);
        GPIO_PinAFConfig(GPIOA, GPIO_PinSource9,GPIO_AF_2);
        GPIO_PinAFConfig(GPIOA, GPIO_PinSource10,GPIO_AF_2);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15; //TIM1_CH1N,TIM1_CH2N
        GPIO_PinAFConfig(GPIOB, GPIO_PinSource13,GPIO_AF_2);
        GPIO_PinAFConfig(GPIOB, GPIO_PinSource14,GPIO_AF_2);
        GPIO_PinAFConfig(GPIOB, GPIO_PinSource15,GPIO_AF_2);
        TIM_TimeBaseStructure.TIM_Period = arr; //设置在下一个更新事件装入活动的自动重装载寄存器周期的值       80K
        TIM_TimeBaseStructure.TIM_Prescaler =psc; //设置用来作为TIMx时钟频率除数的预分频值不分频
        TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1; //设置时钟分割:TDTS = Tck_tim
        TIM_TimeBaseStructure.TIM_RepetitionCounter =0;
        TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;//TIM向上计数模式
        TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure); //根据TIM_TimeBaseInitStruct中指定的参数初始化TIMx的时间基数单位
    /* Set the default configuration */
        TIM_BDTRInitStruct.TIM_OSSRState = TIM_OSSRState_Enable;//运行模式下关闭状态选择
        TIM_BDTRInitStruct.TIM_OSSIState = TIM_OSSIState_Enable;//空闲模式下关闭状态选择
        TIM_BDTRInitStruct.TIM_LOCKLevel = TIM_LOCKLevel_OFF;//软件错误锁定配置:锁定关闭无保护
        TIM_BDTRInitStruct.TIM_DeadTime = 0x5;//DTG死区发生器配置:(死区时间DT),注意死区时间要设成100ns左右,否则过大会导致MOS栅极PWM波形异常,太小导致上下臂短路
        //TDTS = 125nS(8MHz)
        //DTG = 0xx => DT = DTG * Tdtg, Tdtg = TDTS;
        //DTG = 10x => DT =(64+DTG) * Tdtg, Tdtg = 2 * TDTS;
        //DTG = 110 => DT =(32+DTG) * Tdtg, Tdtg = 8 * TDTS;
        //DTG = 111=> DT =(32 + DTG) *Tdtg, Tdtg = 16 * TDTS;
        TIM_BDTRInitStruct.TIM_Break = TIM_Break_Disable;//刹车配置:使能刹车
        TIM_BDTRInitStruct.TIM_BreakPolarity = TIM_BreakPolarity_High;//刹车输入极性选择:高电平有效
        TIM_BDTRInitStruct.TIM_AutomaticOutput = TIM_AutomaticOutput_Enable;//自动输出使能配置:MOE只能软件置1
        TIM_BDTRConfig( TIM1, &TIM_BDTRInitStruct); //配置互补输出死区时间
        TIM_OCStructInit(&TIM_OCInitStructure);
        TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2; //选择定时器模式:TIM脉冲宽度调制模式1
        TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; //比较输出使能
        TIM_OCInitStructure.TIM_OutputNState=TIM_OutputNState_Enable;
        TIM_OCInitStructure.TIM_Pulse = 500; //设置待装入捕获比较寄存器的脉冲值
        TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High; //输出极性:TIM输出比较极性高
        TIM_OCInitStructure.TIM_OCNPolarity=TIM_OCNPolarity_High;
        TIM_OCInitStructure.TIM_OCIdleState=TIM_OCIdleState_Reset;
        TIM_OCInitStructure.TIM_OCNIdleState=TIM_OCNIdleState_Reset;
        TIM_OC1Init(TIM1, &TIM_OCInitStructure);//根据TIM_OCInitStruct中指定的参数初始化外设TIMx
        TIM_OC2Init(TIM1, &TIM_OCInitStructure);//根据TIM_OCInitStruct中指定的参数初始化外设TIMx
        TIM_OC3Init(TIM1, &TIM_OCInitStructure);
        TIM_OC1PreloadConfig(TIM1, TIM_OCPreload_Enable);//CH1预装载使能
        TIM_OC2PreloadConfig(TIM1, TIM_OCPreload_Enable);//CH2预装载使能
        TIM_OC3PreloadConfig(TIM1, TIM_OCPreload_Enable);//CH2预装载使能
        TIM_ARRPreloadConfig(TIM1, ENABLE); //使能TIMx在ARR上的预装载寄存器TIM_CCMR1_IC1F_1
        TIM_ITConfig(TIM1, TIM_IT_CC1, ENABLE);
        TIM_CtrlPWMOutputs(TIM1,ENABLE);
        TIM_Cmd(TIM1, ENABLE);//使能TIM1
* @name   : initNVIC_TIM1
* @brief: PWM中断配置
* @param: void
* @retval : void
void initNVIC_TIM1(void)
    NVIC_InitTypeDef NVIC_InitStructure;
    // Config TIM1_CC_IRQn NVIC config
    NVIC_InitStructure.NVIC_IRQChannel = TIM1_CC_IRQn;
    NVIC_InitStructure.NVIC_IRQChannelPriority = 0;
    NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
    NVIC_Init(&NVIC_InitStructure);
* @name   : OnTIM1
* @brief: Enable TIM1 使能定时器
* @param: void
* @retval : void
void OnTIM1(void)
* @name   : TIM1_CC_IRQHandler
* @brief: TIM1 Compare/Capture IRQHandler 定时器中断处理函数
* @param: void
* @retval : void
volatile uint32_t TIMER0_Count = 0;
void TIM1_CC_IRQHandler()//43us
    if (TIM_GetITStatus(TIM1, TIM_IT_CC1) != RESET)
      // Clear the CC1 flag
      TIM_ClearITPendingBit(TIM1, TIM_IT_CC1);
                        TIMER0_Count ++;
//PWM初始化配置
void PWM_INIT_ALL(void)
        initPWM_EN();
        //config TIM to PWM output
        TIM1_PWM_Init(1999,0);
        initNVIC_TIM1();
        OnTIM1();
//占空比配置
TIM1->CCR1 = w_time_ph_a;
TIM1->CCR2 = w_time_ph_b;
TIM1->CCR3 = w_time_ph_c;
tpgf 发表于 2022-3-8 09:17
这个是芯片的规定吗
drer 发表于 2022-3-8 09:30
手册上有相关说明吗
qcliu 发表于 2022-3-8 09:39
一般是不是都用来驱动无刷电机啊
zljiu 发表于 2022-3-8 09:47
必须要进行使能一下吗
nawu 发表于 2022-3-8 09:58
是否可以上传一下整个工程呢
tfqi 发表于 2022-3-8 10:07
如何提高精度呢
sxy4517 发表于 2022-3-8 10:10
能简单说一下程序流程吗?
(1)PWM频率是多少?
(2)电机带霍尔吗?
(3)电流检测是怎么实现的?
(4)霍尔的信号是扫描还是中断,如果是扫描的话,频率是多少?
页: [1]
查看完整版本: MM32SPIN422C PWM配置,驱动无刷电机
