STM32F2——ADC多通道DMA采集时AD值大于4095的问题解决方法
前言最近在调试STM32F2XX系列ADC多通道DMA采集时,发现采集的AD值大于4095,有的65000多了,这是什么节奏?adc不是12位吗,最大才0xfff,即4095,怎么会出现这种情况呢?难到是adc数据对齐方式出现问题了,adc的对齐明明设置的是右对齐啊,神马情况?
ADC结构体参数分析 百思不得adc之姐,只能keil单步调试,一步一步查看adc结构体的参数。我使用的是adc dma方式采集,共9个通道。初始化程序如下:
void ADC_DMA_Config(void)
ADC_InitTypeDef ADC_InitStructure;
ADC_CommonInitTypeDef ADC_CommonInitStructure;
DMA_InitTypeDef DMA_InitStructure;
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2 | RCC_AHB1Periph_GPIOA | RCC_AHB1Periph_GPIOC, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
DMA_InitStructure.DMA_Channel = DMA_Channel_0;
DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)&ADC1->DR;
DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)&ADC_ConvertedValue;
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;
DMA_InitStructure.DMA_BufferSize = Sample_Num*Channel_Num;
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
DMA_InitStructure.DMA_Priority = DMA_Priority_High;
DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;
DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;
DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
DMA_Init(DMA2_Stream0, &DMA_InitStructure);
DMA_Cmd(DMA2_Stream0, ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 |GPIO_Pin_2 | GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_7;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ;
GPIO_Init(GPIOA, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1 | GPIO_Pin_3 | GPIO_Pin_5;
GPIO_Init(GPIOC, &GPIO_InitStructure);
/* ADC Common Init **********************************************************/
ADC_CommonInitStructure.ADC_Mode = ADC_Mode_Independent;
ADC_CommonInitStructure.ADC_Prescaler = ADC_Prescaler_Div2;
ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_Disabled;
ADC_CommonInitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_5Cycles;
ADC_CommonInit(&ADC_CommonInitStructure);
ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;
ADC_InitStructure.ADC_ScanConvMode = ENABLE;
ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None;
ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
ADC_InitStructure.ADC_NbrOfConversion = 9;
ADC_Init(ADC1, &ADC_InitStructure);
ADC_RegularChannelConfig(ADC1, ADC_Channel_0, 1, ADC_SampleTime_3Cycles);
ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 2, ADC_SampleTime_3Cycles);
ADC_RegularChannelConfig(ADC1, ADC_Channel_2, 3, ADC_SampleTime_3Cycles);
ADC_RegularChannelConfig(ADC1, ADC_Channel_4, 4, ADC_SampleTime_3Cycles);
ADC_RegularChannelConfig(ADC1, ADC_Channel_5, 5, ADC_SampleTime_3Cycles);
ADC_RegularChannelConfig(ADC1, ADC_Channel_7, 6, ADC_SampleTime_3Cycles);
ADC_RegularChannelConfig(ADC1, ADC_Channel_11, 7, ADC_SampleTime_3Cycles);
ADC_RegularChannelConfig(ADC1, ADC_Channel_13, 8, ADC_SampleTime_3Cycles);
ADC_RegularChannelConfig(ADC1, ADC_Channel_15, 9, ADC_SampleTime_3Cycles);
ADC_DMARequestAfterLastTransferCmd(ADC1, ENABLE);
ADC_DMACmd(ADC1, ENABLE);
ADC_Cmd(ADC1, ENABLE);
其中涉及adc的初始化结构体代码部分如下:
ADC_Init(ADC1, &ADC_InitStructure); 一步一步调式发现结构体有一项ADC_ExternalTrigConv是0x08002d54,这一项并没有初始化对其赋值,忘记给结构体的这一项赋值了。最后这个值通过ADC_Init函数赋值给CR2的时候,第11位(也就是数据对其位)是1了,左对齐了!!!!! 下面来重点分析下adc初始化结构体中的各项参数的意义:
对于STM32,在使用ADC的时候需要配置几个参数。 (1) 第一个参数是ADC_Mode,这里设置为独立模式:
ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
在这个模式下,双ADC不能同步,每个ADC接口独立工作。所以如果不需要ADC同步或者只是用了一个ADC的时候,就应该设成独立模式了。 (2) 第二个参数是ADC_ScanConvMode,这里设置为DISABLE。
如果只是用了一个通道的话,DISABLE就可以了,如果使用了多个通道的话,则必须将其设置为ENABLE。 (3) 第三个参数是ADC_ContinuousConvMode,这里设置为ENABLE,即连续转换。
如果设置为DISABLE,则是单次转换。两者的区别在于连续转换直到所有的数据转换完成后才停止转换,而单次转换则只转换一次数据就停止,要再次触发转换才可以。所以如果需要一次性采集1024个数据或者更多,则采用连续转换。
(4) 第四个参数是ADC_ExternalTrigConv,即选择外部触发模式。这里只讲三种:
1、第一种是最简单的软件触发,参数一般为ADC_ExternalTrigConv_None(注意STM32F2XX系列这个有点蹊跷,后面会讲这个)。设置好后还要记得调用库函数: ADC_SoftwareStartConvCmd(ADC1, ENABLE);
void ADC_SoftwareStartConv(ADC_TypeDef* ADCx)
/* Check the parameters */
assert_param(IS_ADC_ALL_PERIPH(ADCx));
/* Enable the selected ADC conversion for regular group */
ADCx->CR2 |= (uint32_t)ADC_CR2_SWSTART;
#defineADC_CR2_SWSTART ((uint32_t)0x40000000)
/*!<Start Conversion of regular channels */
ADC_SoftwareStartConv函数里直接置位CR2的ADC_CR2_SWSTART位,这样触发就启动了。 2、第二种是定时器通道输出触发。共有这几种:ADC_ExternalTrigConv_T1_CC1、ADC_ExternalTrigConv_T1_CC2、ADC_ExternalTrigConv_T2_CC2、
ADC_ExternalTrigConv_T3_T以及ADC_ExternalTrigConv_T4_CC4。定时器输出触发比较麻烦,还需要设置相应的定时器。 以ADC_ExternalTrigConv_T2_CC2触发为例设置相应的定时器:
void TIM2_Configuration(void)
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
TIM_OCInitTypeDef TIM_OCInitStructure;
TIM_TimeBaseStructure.TIM_Prescaler = 4;
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
TIM_TimeBaseStructure.TIM_Period = 0XFF;
TIM_TimeBaseStructure.TIM_ClockDivision = 0;
TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
TIM_OCInitStructure.TIM_Pulse = 0X7F;
TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;
TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
//配置CC2的属性。若CC3作为ADC的触发源,则应改为TIM_OC3Init(TIM2, &TIM_OCInitStructure);
TIM_OC2Init(TIM2, &TIM_OCInitStructure);
TIM_Cmd(TIM2, ENABLE);
TIM_CtrlPWMOutputs(TIM2, ENABLE);
这样设置之后就可以用定时器2的输出触发了,至于触发的周期,设置TIM2的时间即可。这里不再赘述。 3、第三种是外部引脚触发,对于规则通道,选择EXTI线11和TIM8_TRGO作为外部触发事件;而注入通道组则选择EXTI线15和TIM8_CC4作为外部触发事件。 (5) 第五个参数是ADC_DataAlign,这里设置为ADC_DataAlign_Right右对齐方式。建议采用右对齐方式,因为这样处理数据会比较方便。当然如果要从高位开始传输数据,那么采用左对齐优势就明显了。 (6) 第六个参数是ADC_NbrOfChannel,顾名思义:通道的数量。要是到多个通道采集数据的话就得设置一下这个参数。
ADC_RegularChannelConfig(ADC1,ADC_Channel_13,1,ADC_SampleTime_13Cycles5);
ADC_RegularChannelConfig(ADC1,ADC_Channel_14,2,ADC_SampleTime_13Cycles5); 多通道数据传输时有一点还要注意:若一个数组为ADC_ValueTab,且设置了两个通道:通道1和通道2,则转换结束后,ADC_ValueTab和ADC_ValueTab存储的是通道1的数据,而ADC_ValueTab和ADC_ValueTab存储的是通道2的数据。如果数组容量大则依次类推。 补充一点:在使用DMA传输数据的时候,需要设置外设地址和存储器地址,外设地址当然就是ADC的地址了,而存储器的地址如果使用8位数据的话,存储器必须定义为8位缓冲区;如果使用16位数据格式的话,存储器则为16位缓冲器,不可定义为32位或更多,否则,数据将出错。 问题的解决方法
上面分析了adc结构体的参数,下面再来单独看看ADC_ExternalTrigConv这一项。
在stm32f2xx_adc.h文件中有这个成员的参数定义,发现里面并没有ADC_ExternalTrigConv_None这个常见的定义。
