使用DHCP来获取IP失败,只能用固定IP,以太网正常。
使用的M487JIDAE开发板,使用的是LwIP_TCP_EchoClient例程/*
* FreeRTOS Kernel V10.0.0
* Copyright (C) 2017 Amazon.com, Inc. or its affiliates.All Rights Reserved.
* Permission is hereby granted, free of charge, to any person obtaining a copy of
* this software and associated documentation files (the "Software"), to deal in
* the Software without restriction, including without limitation the rights to
* use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies of
* the Software, and to permit persons to whom the Software is furnished to do so,
* subject to the following conditions:
* The above copyright notice and this permission notice shall be included in all
* copies or substantial portions of the Software. If you wish to use our Amazon
* FreeRTOS name, please do so in a fair use way that does not cause confusion.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
* IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS
* FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR
* COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER
* IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN
* CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
* http://www.FreeRTOS.org
* http://aws.amazon.com/freertos
* 1 tab == 4 spaces!
/* A TCP echo client which is implemented with LwIP under FreeRTOS.
client send to 192.168.0.2:80, IP address could configure statically
to 192.168.0.3 or assign by DHCP server. */
#include <stdio.h>
/* Kernel includes. */
#include "FreeRTOS.h"
#include "task.h"
#include "timers.h"
#include "semphr.h"
/* Demo application includes. */
#include "partest.h"
#include "flash.h"
#include "flop.h"
#include "integer.h"
#include "PollQ.h"
#include "semtest.h"
#include "dynamic.h"
#include "BlockQ.h"
#include "blocktim.h"
#include "countsem.h"
#include "GenQTest.h"
#include "QueueSet.h"
#include "recmutex.h"
#include "death.h"
/* Hardware and starter kit includes. */
#include "NuMicro.h"
#include "led.h"
#include "key.h"
#include "lwip/netifapi.h"
#include "lwip/tcpip.h"
#include "netif/ethernetif.h"
#include "tcp_echoclient-netconn.h"
/* Priorities for the demo application tasks. */
#if 0
#define mainFLASH_TASK_PRIORITY ( tskIDLE_PRIORITY + 1UL )
#define mainQUEUE_POLL_PRIORITY ( tskIDLE_PRIORITY + 2UL )
#define mainSEM_TEST_PRIORITY ( tskIDLE_PRIORITY + 1UL )
#define mainBLOCK_Q_PRIORITY ( tskIDLE_PRIORITY + 2UL )
#define mainCHECK_TASK_PRIORITY ( tskIDLE_PRIORITY + 3UL )
#else
#define mainQUEUE_POLL_PRIORITY ( tskIDLE_PRIORITY + 1UL )
#endif
#define mainCHECK_TASK_STACK_SIZE ( configMINIMAL_STACK_SIZE )
/* The time between cycles of the 'check' task. */
#define mainCHECK_DELAY ( ( portTickType ) 5000 / portTICK_RATE_MS )
/* The LED used by the check timer. */
#define mainCHECK_LED ( 3UL )
/* A block time of zero simply means "don't block". */
#define mainDONT_BLOCK ( 0UL )
/* The period after which the check timer will expire, in ms, provided no errors
have been reported by any of the standard demo tasks.ms are converted to the
equivalent in ticks using the portTICK_RATE_MS constant. */
#define mainCHECK_TIMER_PERIOD_MS ( 3000UL / portTICK_RATE_MS )
/* The period at which the check timer will expire, in ms, if an error has been
reported in one of the standard demo tasks.ms are converted to the equivalent
#define mainERROR_CHECK_TIMER_PERIOD_MS ( 200UL / portTICK_RATE_MS )
/* Set mainCREATE_SIMPLE_LED_FLASHER_DEMO_ONLY to 1 to create a simple demo.
Set mainCREATE_SIMPLE_LED_FLASHER_DEMO_ONLY to 0 to create a much more
comprehensive test application.See the comments at the top of this file, and
the documentation page on the http://www.FreeRTOS.org web site for more
information. */
#define mainCREATE_SIMPLE_LED_FLASHER_DEMO_ONLY 0
//#define USE_DHCP
//#ifdef USE_DHCP
#include "lwip/dhcp.h"
//#endif
* Set up the hardware ready to run this demo.
static void prvSetupHardware( void );
unsigned char my_mac_addr = {0x00, 0x00, 0x00, 0x55, 0x66, 0x77};
struct netif netif;
static void vTcpTask( void *pvParameters );
int main(void)
/* Configure the hardware ready to run the test. */
prvSetupHardware();
Led_init();
key_init();
TIM_init();
xTaskCreate( vTcpTask, "TcpTask", TCPIP_THREAD_STACKSIZE, NULL, mainCHECK_TASK_PRIORITY, NULL );
//vStartBlockingQueueTasks( mainBLOCK_Q_PRIORITY );
vStartPolledQueueTasks( mainQUEUE_POLL_PRIORITY );
vStartSemaphoreTasks( mainSEM_TEST_PRIORITY );
vStartGenericQueueTasks( tskIDLE_PRIORITY );
vStartQueueSetTasks();
printf("FreeRTOS is starting ...\n");
/* Start the scheduler. */
vTaskStartScheduler();
/* If all is well, the scheduler will now be running, and the following line
will never be reached.If the following line does execute, then there was
insufficient FreeRTOS heap memory available for the idle and/or timer tasks
to be created.See the memory management section on the FreeRTOS web site
for more details. */
for( ;; );
/* Unlock protected registers */
SYS_UnlockReg();
/* Set XT1_OUT(PF.2) and XT1_IN(PF.3) to input mode */
PF->MODE &= ~(GPIO_MODE_MODE2_Msk | GPIO_MODE_MODE3_Msk);
/* Enable External XTAL (4~24 MHz) */
CLK_EnableXtalRC(CLK_PWRCTL_HXTEN_Msk);
/* Waiting for 12MHz clock ready */
CLK_WaitClockReady( CLK_STATUS_HXTSTB_Msk);
/* Set core clock as PLL_CLOCK from PLL */
CLK_SetCoreClock(FREQ_192MHZ);
/* Set both PCLK0 and PCLK1 as HCLK/2 */
CLK->PCLKDIV = CLK_PCLKDIV_APB0DIV_DIV2 | CLK_PCLKDIV_APB1DIV_DIV2;
/* Enable IP clock */
CLK_EnableModuleClock(UART0_MODULE);
/* Enable TIM module clock */
CLK_EnableModuleClock(TMR1_MODULE);
CLK_EnableModuleClock(EMAC_MODULE);
/* Select IP clock source */
CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART0SEL_HXT, CLK_CLKDIV0_UART0(1));
CLK_SetModuleClock(TMR1_MODULE, CLK_CLKSEL1_TMR1SEL_HXT, 0);
// Configure MDC clock rate to HCLK / (127 + 1) = 1.5 MHz if system is running at 192 MHz
CLK_SetModuleClock(EMAC_MODULE, 0, CLK_CLKDIV3_EMAC(127));
/* Update System Core Clock */
/* User can use SystemCoreClockUpdate() to calculate SystemCoreClock. */
SystemCoreClockUpdate();
/* Set GPB multi-function pins for UART0 RXD and TXD */
SYS->GPB_MFPH &= ~(SYS_GPB_MFPH_PB12MFP_Msk | SYS_GPB_MFPH_PB13MFP_Msk);
SYS->GPB_MFPH |= (SYS_GPB_MFPH_PB12MFP_UART0_RXD | SYS_GPB_MFPH_PB13MFP_UART0_TXD);
// Configure RMII pins
SYS->GPA_MFPL |= SYS_GPA_MFPL_PA6MFP_EMAC_RMII_RXERR | SYS_GPA_MFPL_PA7MFP_EMAC_RMII_CRSDV;
SYS->GPC_MFPL |= SYS_GPC_MFPL_PC6MFP_EMAC_RMII_RXD1 | SYS_GPC_MFPL_PC7MFP_EMAC_RMII_RXD0;
SYS->GPC_MFPH |= SYS_GPC_MFPH_PC8MFP_EMAC_RMII_REFCLK;
SYS->GPE_MFPH |= SYS_GPE_MFPH_PE8MFP_EMAC_RMII_MDC |
SYS_GPE_MFPH_PE9MFP_EMAC_RMII_MDIO |
SYS_GPE_MFPH_PE10MFP_EMAC_RMII_TXD0 |
SYS_GPE_MFPH_PE11MFP_EMAC_RMII_TXD1 |
SYS_GPE_MFPH_PE12MFP_EMAC_RMII_TXEN;
// Enable high slew rate on all RMII TX output pins
PE->SLEWCTL = (GPIO_SLEWCTL_HIGH << GPIO_SLEWCTL_HSREN10_Pos) |
(GPIO_SLEWCTL_HIGH << GPIO_SLEWCTL_HSREN11_Pos) |
(GPIO_SLEWCTL_HIGH << GPIO_SLEWCTL_HSREN12_Pos);
/* Lock protected registers */
SYS_LockReg();
/* Init UART to 115200-8n1 for print message */
UART_Open(UART0, 115200);
void vApplicationMallocFailedHook( void )
/* vApplicationMallocFailedHook() will only be called if
configUSE_MALLOC_FAILED_HOOK is set to 1 in FreeRTOSConfig.h.It is a hook
function that will get called if a call to pvPortMalloc() fails.
pvPortMalloc() is called internally by the kernel whenever a task, queue,
timer or semaphore is created.It is also called by various parts of the
demo application.If heap_1.c or heap_2.c are used, then the size of the
heap available to pvPortMalloc() is defined by configTOTAL_HEAP_SIZE in
FreeRTOSConfig.h, and the xPortGetFreeHeapSize() API function can be used
to query the size of free heap space that remains (although it does not
provide information on how the remaining heap might be fragmented). */
taskDISABLE_INTERRUPTS();
for( ;; );
void vApplicationIdleHook( void )
/* vApplicationIdleHook() will only be called if configUSE_IDLE_HOOK is set
to 1 in FreeRTOSConfig.h.It will be called on each iteration of the idle
task.It is essential that code added to this hook function never attempts
to block in any way (for example, call xQueueReceive() with a block time
specified, or call vTaskDelay()).If the application makes use of the
vTaskDelete() API function (as this demo application does) then it is also
important that vApplicationIdleHook() is permitted to return to its calling
function, because it is the responsibility of the idle task to clean up
memory allocated by the kernel to any task that has since been deleted. */
void vApplicationStackOverflowHook( xTaskHandle pxTask, signed char *pcTaskName )
( void ) pcTaskName;
( void ) pxTask;
/* Run time stack overflow checking is performed if
configCHECK_FOR_STACK_OVERFLOW is defined to 1 or 2.This hook
function is called if a stack overflow is detected. */
for( ;; );
void vApplicationTickHook( void )
/* This function will be called by each tick interrupt if
configUSE_TICK_HOOK is set to 1 in FreeRTOSConfig.h.User code can be
added here, but the tick hook is called from an interrupt context, so
code must not attempt to block, and only the interrupt safe FreeRTOS API
functions can be used (those that end in FromISR()).*/
#if ( mainCREATE_SIMPLE_BLINKY_DEMO_ONLY == 0 )
/* In this case the tick hook is used as part of the queue set test. */
vQueueSetAccessQueueSetFromISR();
#endif /* mainCREATE_SIMPLE_BLINKY_DEMO_ONLY */
ip_addr_t ipaddr;
ip_addr_t netmask;
ip_addr_t gw;
IP4_ADDR(&gw, 0,0,0,0);
IP4_ADDR(&ipaddr, 0,0,0,0);
IP4_ADDR(&netmask, 0,0,0,0);
// IP4_ADDR(&gw, 192,168,10,1);
// IP4_ADDR(&ipaddr, 192,168,10,123);
// IP4_ADDR(&netmask, 255,255,255,0);
printf("Local IP...............\n");
tcpip_init(NULL, NULL);
netif_add(&netif, &ipaddr, &netmask, &gw, NULL, ethernetif_init, tcpip_input);
netif_set_default(&netif);
netif_set_up(&netif);
//#ifdef USE_DHCP
dhcp_start(&netif);
//#endif
NVIC_SetPriority(EMAC_TX_IRQn, configLIBRARY_MAX_SYSCALL_INTERRUPT_PRIORITY + 1);
NVIC_EnableIRQ(EMAC_TX_IRQn);
NVIC_SetPriority(EMAC_RX_IRQn, configLIBRARY_MAX_SYSCALL_INTERRUPT_PRIORITY + 1);
NVIC_EnableIRQ(EMAC_RX_IRQn);
tcp_echoclient_netconn_init();
vTaskSuspend( NULL );
就是不能自动获取呗 自动获取,需要配置什么吗
页:
[1]
