[技术问答] 使用DHCP来获取IP失败,只能用固定IP,以太网正常。
725|2
 楼主| fst20220608 发表于 2022-6-14 11:33 | 显示全部楼层 |阅读模式
使用的M487JIDAE开发板,使用的是LwIP_TCP_EchoClient例程
  1. /*
  2. * FreeRTOS Kernel V10.0.0
  3. * Copyright (C) 2017 Amazon.com, Inc. or its affiliates.  All Rights Reserved.
  4. *
  5. * Permission is hereby granted, free of charge, to any person obtaining a copy of
  6. * this software and associated documentation files (the "Software"), to deal in
  7. * the Software without restriction, including without limitation the rights to
  8. * use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies of
  9. * the Software, and to permit persons to whom the Software is furnished to do so,
  10. * subject to the following conditions:
  11. *
  12. * The above copyright notice and this permission notice shall be included in all
  13. * copies or substantial portions of the Software. If you wish to use our Amazon
  14. * FreeRTOS name, please do so in a fair use way that does not cause confusion.
  15. *
  16. * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
  17. * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS
  18. * FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR
  19. * COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER
  20. * IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN
  21. * CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
  22. *
  23. * http://www.FreeRTOS.org
  24. * http://aws.amazon.com/freertos
  25. *
  26. * 1 tab == 4 spaces!
  27. */
  28. /* A TCP echo client which is implemented with LwIP under FreeRTOS.
  29.    client send to 192.168.0.2:80, IP address could configure statically
  30.    to 192.168.0.3 or assign by DHCP server. */
  31. #include <stdio.h>
  32. /* Kernel includes. */
  33. #include "FreeRTOS.h"
  34. #include "task.h"
  35. #include "timers.h"
  36. #include "semphr.h"
  37. /* Demo application includes. */
  38. #include "partest.h"
  39. #include "flash.h"
  40. #include "flop.h"
  41. #include "integer.h"
  42. #include "PollQ.h"
  43. #include "semtest.h"
  44. #include "dynamic.h"
  45. #include "BlockQ.h"
  46. #include "blocktim.h"
  47. #include "countsem.h"
  48. #include "GenQTest.h"
  49. #include "QueueSet.h"
  50. #include "recmutex.h"
  51. #include "death.h"
  52. /* Hardware and starter kit includes. */
  53. #include "NuMicro.h"
  54. #include "led.h"
  55. #include "key.h"
  56. #include "lwip/netifapi.h"
  57. #include "lwip/tcpip.h"
  58. #include "netif/ethernetif.h"
  59. #include "tcp_echoclient-netconn.h"
  60. /* Priorities for the demo application tasks. */
  61. #if 0
  62. #define mainFLASH_TASK_PRIORITY            ( tskIDLE_PRIORITY + 1UL )
  63. #define mainQUEUE_POLL_PRIORITY            ( tskIDLE_PRIORITY + 2UL )
  64. #define mainSEM_TEST_PRIORITY              ( tskIDLE_PRIORITY + 1UL )
  65. #define mainBLOCK_Q_PRIORITY               ( tskIDLE_PRIORITY + 2UL )
  66. #define mainCHECK_TASK_PRIORITY            ( tskIDLE_PRIORITY + 3UL )
  67. #else
  68. #define mainFLASH_TASK_PRIORITY            ( tskIDLE_PRIORITY + 1UL )
  69. #define mainQUEUE_POLL_PRIORITY            ( tskIDLE_PRIORITY + 1UL )
  70. #define mainSEM_TEST_PRIORITY              ( tskIDLE_PRIORITY + 1UL )
  71. #define mainCHECK_TASK_PRIORITY            ( tskIDLE_PRIORITY + 3UL )
  72. #endif
  73. #define mainCHECK_TASK_STACK_SIZE            ( configMINIMAL_STACK_SIZE )
  74. /* The time between cycles of the 'check' task. */
  75. #define mainCHECK_DELAY                        ( ( portTickType ) 5000 / portTICK_RATE_MS )
  76. /* The LED used by the check timer. */
  77. #define mainCHECK_LED                         ( 3UL )
  78. /* A block time of zero simply means "don't block". */
  79. #define mainDONT_BLOCK                        ( 0UL )
  80. /* The period after which the check timer will expire, in ms, provided no errors
  81. have been reported by any of the standard demo tasks.  ms are converted to the
  82. equivalent in ticks using the portTICK_RATE_MS constant. */
  83. #define mainCHECK_TIMER_PERIOD_MS            ( 3000UL / portTICK_RATE_MS )
  84. /* The period at which the check timer will expire, in ms, if an error has been
  85. reported in one of the standard demo tasks.  ms are converted to the equivalent
  86. in ticks using the portTICK_RATE_MS constant. */
  87. #define mainERROR_CHECK_TIMER_PERIOD_MS     ( 200UL / portTICK_RATE_MS )
  88. /* Set mainCREATE_SIMPLE_LED_FLASHER_DEMO_ONLY to 1 to create a simple demo.
  89. Set mainCREATE_SIMPLE_LED_FLASHER_DEMO_ONLY to 0 to create a much more
  90. comprehensive test application.  See the comments at the top of this file, and
  91. the documentation page on the http://www.FreeRTOS.org web site for more
  92. information. */
  93. #define mainCREATE_SIMPLE_LED_FLASHER_DEMO_ONLY        0
  94. //#define USE_DHCP
  95. //#ifdef USE_DHCP
  96. #include "lwip/dhcp.h"
  97. //#endif
  98. /*-----------------------------------------------------------*/
  99. /*
  100. * Set up the hardware ready to run this demo.
  101. */
  102. static void prvSetupHardware( void );
  103. /*-----------------------------------------------------------*/
  104. unsigned char my_mac_addr[6] = {0x00, 0x00, 0x00, 0x55, 0x66, 0x77};
  105. struct netif netif;
  106. static void vTcpTask( void *pvParameters );
  107. int main(void)
  108. {
  109.     /* Configure the hardware ready to run the test. */
  110.     prvSetupHardware();
  111.     Led_init();
  112.
  113.     key_init();
  114.
  115.     TIM_init();
  116.     xTaskCreate( vTcpTask, "TcpTask", TCPIP_THREAD_STACKSIZE, NULL, mainCHECK_TASK_PRIORITY, NULL );
  117.     //vStartBlockingQueueTasks( mainBLOCK_Q_PRIORITY );
  118.     vStartPolledQueueTasks( mainQUEUE_POLL_PRIORITY );
  119.     vStartSemaphoreTasks( mainSEM_TEST_PRIORITY );
  120.     vStartGenericQueueTasks( tskIDLE_PRIORITY );
  121.     vStartQueueSetTasks();
  122.     printf("FreeRTOS is starting ...\n");
  123.     /* Start the scheduler. */
  124.     vTaskStartScheduler();
  125.     /* If all is well, the scheduler will now be running, and the following line
  126.     will never be reached.  If the following line does execute, then there was
  127.     insufficient FreeRTOS heap memory available for the idle and/or timer tasks
  128.     to be created.  See the memory management section on the FreeRTOS web site
  129.     for more details. */
  130.     for( ;; );
  131. }
  132. /*-----------------------------------------------------------*/
  133. static void prvSetupHardware( void )
  134. {
  135.     /* Unlock protected registers */
  136.     SYS_UnlockReg();
  137.     /* Set XT1_OUT(PF.2) and XT1_IN(PF.3) to input mode */
  138.     PF->MODE &= ~(GPIO_MODE_MODE2_Msk | GPIO_MODE_MODE3_Msk);
  139.     /* Enable External XTAL (4~24 MHz) */
  140.     CLK_EnableXtalRC(CLK_PWRCTL_HXTEN_Msk);
  141.     /* Waiting for 12MHz clock ready */
  142.     CLK_WaitClockReady( CLK_STATUS_HXTSTB_Msk);
  143.     /* Set core clock as PLL_CLOCK from PLL */
  144.     CLK_SetCoreClock(FREQ_192MHZ);
  145.     /* Set both PCLK0 and PCLK1 as HCLK/2 */
  146.     CLK->PCLKDIV = CLK_PCLKDIV_APB0DIV_DIV2 | CLK_PCLKDIV_APB1DIV_DIV2;
  147.     /* Enable IP clock */
  148.     CLK_EnableModuleClock(UART0_MODULE);
  149.
  150.     /* Enable TIM module clock */
  151.     CLK_EnableModuleClock(TMR1_MODULE);
  152.
  153.     CLK_EnableModuleClock(EMAC_MODULE);
  154.     /* Select IP clock source */
  155.     CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART0SEL_HXT, CLK_CLKDIV0_UART0(1));
  156.
  157.     CLK_SetModuleClock(TMR1_MODULE, CLK_CLKSEL1_TMR1SEL_HXT, 0);
  158.     // Configure MDC clock rate to HCLK / (127 + 1) = 1.5 MHz if system is running at 192 MHz
  159.     CLK_SetModuleClock(EMAC_MODULE, 0, CLK_CLKDIV3_EMAC(127));
  160.     /* Update System Core Clock */
  161.     /* User can use SystemCoreClockUpdate() to calculate SystemCoreClock. */
  162.     SystemCoreClockUpdate();
  163.     /* Set GPB multi-function pins for UART0 RXD and TXD */
  164.     SYS->GPB_MFPH &= ~(SYS_GPB_MFPH_PB12MFP_Msk | SYS_GPB_MFPH_PB13MFP_Msk);
  165.     SYS->GPB_MFPH |= (SYS_GPB_MFPH_PB12MFP_UART0_RXD | SYS_GPB_MFPH_PB13MFP_UART0_TXD);
  166.     // Configure RMII pins
  167.     SYS->GPA_MFPL |= SYS_GPA_MFPL_PA6MFP_EMAC_RMII_RXERR | SYS_GPA_MFPL_PA7MFP_EMAC_RMII_CRSDV;
  168.     SYS->GPC_MFPL |= SYS_GPC_MFPL_PC6MFP_EMAC_RMII_RXD1 | SYS_GPC_MFPL_PC7MFP_EMAC_RMII_RXD0;
  169.     SYS->GPC_MFPH |= SYS_GPC_MFPH_PC8MFP_EMAC_RMII_REFCLK;
  170.     SYS->GPE_MFPH |= SYS_GPE_MFPH_PE8MFP_EMAC_RMII_MDC |
  171.                      SYS_GPE_MFPH_PE9MFP_EMAC_RMII_MDIO |
  172.                      SYS_GPE_MFPH_PE10MFP_EMAC_RMII_TXD0 |
  173.                      SYS_GPE_MFPH_PE11MFP_EMAC_RMII_TXD1 |
  174.                      SYS_GPE_MFPH_PE12MFP_EMAC_RMII_TXEN;
  175.     // Enable high slew rate on all RMII TX output pins
  176.     PE->SLEWCTL = (GPIO_SLEWCTL_HIGH << GPIO_SLEWCTL_HSREN10_Pos) |
  177.                   (GPIO_SLEWCTL_HIGH << GPIO_SLEWCTL_HSREN11_Pos) |
  178.                   (GPIO_SLEWCTL_HIGH << GPIO_SLEWCTL_HSREN12_Pos);
  179.     /* Lock protected registers */
  180.     SYS_LockReg();
  181.     /* Init UART to 115200-8n1 for print message */
  182.     UART_Open(UART0, 115200);
  183. }
  184. /*-----------------------------------------------------------*/
  185. void vApplicationMallocFailedHook( void )
  186. {
  187.     /* vApplicationMallocFailedHook() will only be called if
  188.     configUSE_MALLOC_FAILED_HOOK is set to 1 in FreeRTOSConfig.h.  It is a hook
  189.     function that will get called if a call to pvPortMalloc() fails.
  190.     pvPortMalloc() is called internally by the kernel whenever a task, queue,
  191.     timer or semaphore is created.  It is also called by various parts of the
  192.     demo application.  If heap_1.c or heap_2.c are used, then the size of the
  193.     heap available to pvPortMalloc() is defined by configTOTAL_HEAP_SIZE in
  194.     FreeRTOSConfig.h, and the xPortGetFreeHeapSize() API function can be used
  195.     to query the size of free heap space that remains (although it does not
  196.     provide information on how the remaining heap might be fragmented). */
  197.     taskDISABLE_INTERRUPTS();
  198.     for( ;; );
  199. }
  200. /*-----------------------------------------------------------*/
  201. void vApplicationIdleHook( void )
  202. {
  203.     /* vApplicationIdleHook() will only be called if configUSE_IDLE_HOOK is set
  204.     to 1 in FreeRTOSConfig.h.  It will be called on each iteration of the idle
  205.     task.  It is essential that code added to this hook function never attempts
  206.     to block in any way (for example, call xQueueReceive() with a block time
  207.     specified, or call vTaskDelay()).  If the application makes use of the
  208.     vTaskDelete() API function (as this demo application does) then it is also
  209.     important that vApplicationIdleHook() is permitted to return to its calling
  210.     function, because it is the responsibility of the idle task to clean up
  211.     memory allocated by the kernel to any task that has since been deleted. */
  212. }
  213. /*-----------------------------------------------------------*/
  214. void vApplicationStackOverflowHook( xTaskHandle pxTask, signed char *pcTaskName )
  215. {
  216.     ( void ) pcTaskName;
  217.     ( void ) pxTask;
  218.     /* Run time stack overflow checking is performed if
  219.     configCHECK_FOR_STACK_OVERFLOW is defined to 1 or 2.  This hook
  220.     function is called if a stack overflow is detected. */
  221.     taskDISABLE_INTERRUPTS();
  222.     for( ;; );
  223. }
  224. /*-----------------------------------------------------------*/
  225. void vApplicationTickHook( void )
  226. {
  227.     /* This function will be called by each tick interrupt if
  228.     configUSE_TICK_HOOK is set to 1 in FreeRTOSConfig.h.  User code can be
  229.     added here, but the tick hook is called from an interrupt context, so
  230.     code must not attempt to block, and only the interrupt safe FreeRTOS API
  231.     functions can be used (those that end in FromISR()).  */
  232. #if ( mainCREATE_SIMPLE_BLINKY_DEMO_ONLY == 0 )
  233.     {
  234.         /* In this case the tick hook is used as part of the queue set test. */
  235.         vQueueSetAccessQueueSetFromISR();
  236.     }
  237. #endif /* mainCREATE_SIMPLE_BLINKY_DEMO_ONLY */
  238. }
  239. static void vTcpTask( void *pvParameters )
  240. {
  241.     ip_addr_t ipaddr;
  242.     ip_addr_t netmask;
  243.     ip_addr_t gw;
  244.
  245.     IP4_ADDR(&gw, 0,0,0,0);
  246.     IP4_ADDR(&ipaddr, 0,0,0,0);
  247.     IP4_ADDR(&netmask, 0,0,0,0);
  248.
  249. //    IP4_ADDR(&gw, 192,168,10,1);
  250. //    IP4_ADDR(&ipaddr, 192,168,10,123);
  251. //    IP4_ADDR(&netmask, 255,255,255,0);
  252.     printf("Local IP...............\n");
  253.     tcpip_init(NULL, NULL);
  254.     netif_add(&netif, &ipaddr, &netmask, &gw, NULL, ethernetif_init, tcpip_input);
  255.     netif_set_default(&netif);
  256.     netif_set_up(&netif);
  257. //#ifdef USE_DHCP
  258.     dhcp_start(&netif);
  259. //#endif
  260.     NVIC_SetPriority(EMAC_TX_IRQn, configLIBRARY_MAX_SYSCALL_INTERRUPT_PRIORITY + 1);
  261.     NVIC_EnableIRQ(EMAC_TX_IRQn);
  262.     NVIC_SetPriority(EMAC_RX_IRQn, configLIBRARY_MAX_SYSCALL_INTERRUPT_PRIORITY + 1);
  263.     NVIC_EnableIRQ(EMAC_RX_IRQn);
  264.     tcp_echoclient_netconn_init();
  265.     vTaskSuspend( NULL );
  266. }
asmine 发表于 2022-7-4 20:57 | 显示全部楼层
就是不能自动获取呗
koala889 发表于 2022-7-8 21:30 | 显示全部楼层
自动获取,需要配置什么吗
