wallysJane 发表于 2022-7-11 11:29
Wallys ROUTERBOARD DR6018(CP01)
Wallys Communications (Suzhou ) Co., LTD(https://www.wallystech.com/)With over 15 years of experience in wireless industry and penetrating market olfaction, Wallys has designed and manufactured many high quality and cost-effective routerboards and wireless network cards. In the complex market, Wallys products stand out and are affirmed by partners. From 802.11 a - ax, Wallys always keeps up with the most cutting-edge wireless technology, aimed to help customers take the preemptive opportunities to occupy the market and lead a win-win cooperation.
IPQ6000/IPQ6018/IPQ6010/IPQ4019/IPQ4029/ipq4018/IPQ8072/IPQ8074/QCN9074/QCN9072/QCN9024/IPQ5018/AR9223/QCA9880/QCA9882/AR9582/AR9531/AR9344/AR9531
Contact:sales1@wallystech.com
Wallys ROUTERBOARD DR6018(CP01) IPQ6018 802.11ax   2x2 2.4GHz&5GHz 1xM.2 E key
FeaturesQualcomm-Atheros IPQ6018Quad-core ARM 64bit A53 @1.8GHz Processor 1GB DDRL3L System Memory 32MB NOR Flash, 256MB NAND Flash Supports Dynamic Frequency Selection (DFS) 2x2 On-board 2.4GHz radio, up to 573Mbps physical Data Rate 2x2 On-board 5GHz radio, up to 1201Mbps physical Data RateSample Price:200USD/pcs
Absolute Maximum Rating
Parameter
RatingUnit
Supply Voltage
24V~48V
Operating Temperature Range
-40 to +70ºC
Storage Temperature Range
-45 to +105ºC
Operating Humidity Range
5 to +95 (non-condensing)%
Hardware Specifications
Symbol
Parameter
CPU
CPU Frequency
Quad-core ARM 64 bit A53 @1.8 GHz processor
System Memory
1GB (2x 512MB) DDR3L 16-bit interface with 32-bit memory bus design
Ethernet Port
5x 1Gbps Ethernet Ports , 1x 2.5Gbps Ethernet Port
NGFF Slot
M.2 (NGFF) “E Key” Socket with MiniPCIe 3.0
SD Card Slot
1x SD Card Slot
USB /header
1x USB 2.0 Port, 1x USB 3.0 Type-C Port
POE
24V~48V passive POE
DC Jack
12V power supply
LED header
FFC/FPC Connector
Serial Port
1x Serial Port 12 Pin Connector
Wireless
On-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/g/n/ax, max 23dBm per chain
On-board 2x2 5GHz MU-MIMO OFDMA 802.11a/802.11n/802.11ac/802.11ax, max 20dBm per chain
4x U.FL Connectors
Nor Flash
32MB
Nand Flash
256MB
DDR
256MB~512MB
Dimension (W x H x D)
219mm x 150mm x 16.5mm (Without Heatsink)
页: [1]
查看完整版本: Wallys ROUTERBOARD DR6018(CP01)
