jinglixixi 发表于 2022-7-17 08:19
【N32G430开发板试用】 彩色OLED屏的显示驱动及图片显示
现在的显示器件实在是太丰富了,且价格也不很贵,这为应用带来了极大的方便。为了便于图片的显示,这里使用的是一款0.96寸的显示屏,其分辨率为160*80,别开其尺寸不大,但其显示的清晰度很高。为使用的灵活性,这里是采用GPIO模拟SPI的方式来驱动该显示屏。该显示屏与开发板的连接关系为:BLK-------PB8
CS--------PB7
RS--------PB6
RESET---PB5
SCL-------PA5
SDA------PA7实现高低电平的引脚定义为:#define OLED_SCLK_Set()   GPIO_Pins_Set(GPIOA, GPIO_PIN_5)   //CLK#define OLED_SCLK_Clr()   GPIO_Pins_Reset(GPIOA, GPIO_PIN_5)#define OLED_SDIN_Set()   GPIO_Pins_Set(GPIOA, GPIO_PIN_7)   //DIN#define OLED_SDIN_Clr()   GPIO_Pins_Reset(GPIOA, GPIO_PIN_7)#define OLED_RST_Set()    GPIO_Pins_Set(GPIOB, GPIO_PIN_5)   //RES#define OLED_RST_Clr()    GPIO_Pins_Reset(GPIOB, GPIO_PIN_5)#define OLED_DC_Set()   GPIO_Pins_Set(GPIOB, GPIO_PIN_6)   //DC#define OLED_DC_Clr()   GPIO_Pins_Reset(GPIOB, GPIO_PIN_6)#define OLED_CS_Set()   GPIO_Pins_Set(GPIOB, GPIO_PIN_7)   //CS#define OLED_CS_Clr()   GPIO_Pins_Reset(GPIOB, GPIO_PIN_7)#define OLED_BLK_Set()    GPIO_Pins_Set(GPIOB, GPIO_PIN_8)   //BLK#define OLED_BLK_Clr()    GPIO_Pins_Reset(GPIOB, GPIO_PIN_8)为显示屏所用引脚的配置函数为:void LCD_Initialize()
         GPIO_InitTypeGPIO_InitStructure;
         RCC_AHB_Peripheral_Clock_Enable(RCC_AHB_PERIPH_GPIOA);
         GPIO_Structure_Initialize(&GPIO_InitStructure);
         GPIO_InitStructure.Pin          = GPIO_PIN_5|GPIO_PIN_7;
         GPIO_InitStructure.GPIO_Mode    = GPIO_MODE_OUT_PP;
         GPIO_InitStructure.GPIO_Current= GPIO_DS_4MA;
         GPIO_Peripheral_Initialize(GPIOA,&GPIO_InitStructure);
         RCC_AHB_Peripheral_Clock_Enable(RCC_AHB_PERIPH_GPIOB);
         GPIO_InitStructure.Pin          = GPIO_PIN_5|GPIO_PIN_6|GPIO_PIN_7|GPIO_PIN_8;
         GPIO_Peripheral_Initialize(GPIOB,&GPIO_InitStructure);
模拟SPI方式发送字节数据的函数为:void LCD_Writ_Bus(u8 dat)
   u8 i;
   OLED_CS_Clr();
   for(i=0;i<8;i++)
       OLED_SCLK_Clr();
       if(dat&0x80)
          OLED_SDIN_Set();
       else
          OLED_SDIN_Clr();
       OLED_SCLK_Set();
       dat<<=1;
   OLED_CS_Set();
该显示屏的初始化函数为:void Lcd_Init(void)
OLED_RST_Clr();
SysTick_Delay_Ms(200);
OLED_RST_Set();
LCD_WR_REG(0x11);
SysTick_Delay_Ms(100);
LCD_WR_REG(0x21);
LCD_WR_REG(0xB1);
LCD_WR_DATA8(0x05);
LCD_WR_DATA8(0x3A);
LCD_WR_DATA8(0x3A);
LCD_WR_REG(0xB2);
LCD_WR_DATA8(0x05);
LCD_WR_DATA8(0x3A);
LCD_WR_DATA8(0x3A);
LCD_WR_REG(0xB3);
LCD_WR_DATA8(0x05);
LCD_WR_DATA8(0x3A);
LCD_WR_DATA8(0x3A);
LCD_WR_DATA8(0x05);
LCD_WR_DATA8(0x3A);
LCD_WR_DATA8(0x3A);
LCD_WR_REG(0xB4);
LCD_WR_DATA8(0x03);
LCD_WR_REG(0xC0);
LCD_WR_DATA8(0x62);
LCD_WR_DATA8(0x02);
LCD_WR_DATA8(0x04);
LCD_WR_REG(0xC1);
LCD_WR_DATA8(0xC0);
LCD_WR_REG(0xC2);
LCD_WR_DATA8(0x0D);
LCD_WR_DATA8(0x00);
LCD_WR_REG(0xC3);
LCD_WR_DATA8(0x8D);
LCD_WR_DATA8(0x6A);
LCD_WR_REG(0xC4);
LCD_WR_DATA8(0x8D);
LCD_WR_DATA8(0xEE);
LCD_WR_REG(0xC5);
LCD_WR_DATA8(0x0E);
LCD_WR_REG(0xE0);
LCD_WR_DATA8(0x10);
LCD_WR_DATA8(0x0E);
LCD_WR_DATA8(0x02);
LCD_WR_DATA8(0x03);
LCD_WR_DATA8(0x0E);
LCD_WR_DATA8(0x07);
LCD_WR_DATA8(0x02);
LCD_WR_DATA8(0x07);
LCD_WR_DATA8(0x0A);
LCD_WR_DATA8(0x12);
LCD_WR_DATA8(0x27);
LCD_WR_DATA8(0x37);
LCD_WR_DATA8(0x00);
LCD_WR_DATA8(0x0D);
LCD_WR_DATA8(0x0E);
LCD_WR_DATA8(0x10);
LCD_WR_REG(0xE1);
LCD_WR_DATA8(0x10);
LCD_WR_DATA8(0x0E);
LCD_WR_DATA8(0x03);
LCD_WR_DATA8(0x03);
LCD_WR_DATA8(0x0F);
LCD_WR_DATA8(0x06);
LCD_WR_DATA8(0x02);
LCD_WR_DATA8(0x08);
LCD_WR_DATA8(0x0A);
LCD_WR_DATA8(0x13);
LCD_WR_DATA8(0x26);
LCD_WR_DATA8(0x36);
LCD_WR_DATA8(0x00);
LCD_WR_DATA8(0x0D);
LCD_WR_DATA8(0x0E);
LCD_WR_DATA8(0x10);
LCD_WR_REG(0x3A);
LCD_WR_DATA8(0x05);
LCD_WR_REG(0x36);
LCD_WR_DATA8(0x78);
LCD_WR_REG(0x29);
OLED_BLK_Set();
以色彩清屏的函数为:void LCD_Clear(u16 Color)
    u16 i,j;
    LCD_Address_Set(0,0,LCD_W-1,LCD_H-1);
    for(i=0;i<LCD_W;i++)
       for (j=0;j<LCD_H;j++)
          LCD_WR_DATA(Color);
实现字符串显示的函数为:void LCD_ShowString(u16 x,u16 y,const u8 *p,u16 color)
    while(*p!='\0')
      if(x>LCD_W-16)
         x=0;
         y+=16;
      if(y>LCD_H-16)
         y=x=0;
         LCD_Clear(RED);
      LCD_ShowChar(x,y,*p,0,color);
      x+=8;
      p++;
进行图片显示的函数为:void LCD_ShowPicturea(u16 x1,u16 y1,u16 x2,u16 y2)
      int i;
      LCD_Address_Set(x1,y1,x2,y2);
      for(i=0;i<12800;i++)
            LCD_WR_DATA8(gImage_FJ);
实现图1至图3所示效果的主程序为:int main(void)
         LCD_Initialize();
         Lcd_Init();
         LCD_Clear(BLACK);
         LCD_ShowString(20,10,"N32G430 TEST",RED);
         LCD_ShowString(20,30,"0.96'OLED",YELLOW);
         SysTick_Delay_Ms(2000);
         LCD_ShowPicturea(0,0,159,79);
         LCD_ShowPictureb(0,0,159,79);
         while(1);
经程序的编译与下载,其显示效果如下:图1显示字符串图2显示风景图片 图3显示人物图片
页: [1]
查看完整版本: 【N32G430开发板试用】 彩色OLED屏的显示驱动及图片显示
