[活动专区] 【N32G430开发板试用】 彩色OLED屏的显示驱动及图片显示
12951|0
 楼主| jinglixixi 发表于 2022-7-17 08:19 | 显示全部楼层 |阅读模式
现在的显示器件实在是太丰富了,且价格也不很贵,这为应用带来了极大的方便。
为了便于图片的显示,这里使用的是一款0.96寸的显示屏,其分辨率为160*80,别开其尺寸不大,但其显示的清晰度很高。
为使用的灵活性,这里是采用GPIO模拟SPI的方式来驱动该显示屏。
该显示屏与开发板的连接关系为:
BLK-------PB8
CS--------PB7
RS--------PB6
RESET---PB5
SCL-------PA5
SDA------PA7
实现高低电平的引脚定义为:
#define OLED_SCLK_Set()   GPIO_Pins_Set(GPIOA, GPIO_PIN_5)   //CLK
#define OLED_SCLK_Clr()   GPIO_Pins_Reset(GPIOA, GPIO_PIN_5)
#define OLED_SDIN_Set()   GPIO_Pins_Set(GPIOA, GPIO_PIN_7)   //DIN
#define OLED_SDIN_Clr()   GPIO_Pins_Reset(GPIOA, GPIO_PIN_7)
#define OLED_RST_Set()    GPIO_Pins_Set(GPIOB, GPIO_PIN_5)   //RES
#define OLED_RST_Clr()    GPIO_Pins_Reset(GPIOB, GPIO_PIN_5)
#define OLED_DC_Set()     GPIO_Pins_Set(GPIOB, GPIO_PIN_6)   //DC
#define OLED_DC_Clr()     GPIO_Pins_Reset(GPIOB, GPIO_PIN_6)
#define OLED_CS_Set()     GPIO_Pins_Set(GPIOB, GPIO_PIN_7)   //CS
#define OLED_CS_Clr()     GPIO_Pins_Reset(GPIOB, GPIO_PIN_7)
#define OLED_BLK_Set()    GPIO_Pins_Set(GPIOB, GPIO_PIN_8)   //BLK
#define OLED_BLK_Clr()    GPIO_Pins_Reset(GPIOB, GPIO_PIN_8)
为显示屏所用引脚的配置函数为:
  1. void LCD_Initialize()
  3.          GPIO_InitTypeGPIO_InitStructure;
  4.          RCC_AHB_Peripheral_Clock_Enable(RCC_AHB_PERIPH_GPIOA);
  5.          GPIO_Structure_Initialize(&GPIO_InitStructure);
  6.          GPIO_InitStructure.Pin          = GPIO_PIN_5|GPIO_PIN_7;
  7.          GPIO_InitStructure.GPIO_Mode    = GPIO_MODE_OUT_PP;
  8.          GPIO_InitStructure.GPIO_Current= GPIO_DS_4MA;
  9.          GPIO_Peripheral_Initialize(GPIOA,&GPIO_InitStructure);
  10.          RCC_AHB_Peripheral_Clock_Enable(RCC_AHB_PERIPH_GPIOB);
  11.          GPIO_Structure_Initialize(&GPIO_InitStructure);
  12.          GPIO_InitStructure.Pin          = GPIO_PIN_5|GPIO_PIN_6|GPIO_PIN_7|GPIO_PIN_8;
  13.          GPIO_InitStructure.GPIO_Mode    = GPIO_MODE_OUT_PP;
  14.          GPIO_InitStructure.GPIO_Current= GPIO_DS_4MA;
  15.          GPIO_Peripheral_Initialize(GPIOB,&GPIO_InitStructure);
  16. }
模拟SPI方式发送字节数据的函数为:
  1. void LCD_Writ_Bus(u8 dat)
  3.    u8 i;
  4.    OLED_CS_Clr();
  5.    for(i=0;i<8;i++)
  6.     {
  7.        OLED_SCLK_Clr();
  8.        if(dat&0x80)
  9.           OLED_SDIN_Set();
  10.        else
  11.           OLED_SDIN_Clr();
  12.        OLED_SCLK_Set();
  13.        dat<<=1;
  14.     }
  15.    OLED_CS_Set();
  16. }
该显示屏的初始化函数为:
  1. void Lcd_Init(void)
  3.   OLED_RST_Clr();
  4.   SysTick_Delay_Ms(200);
  5.   OLED_RST_Set();
  6.   SysTick_Delay_Ms(200);
  7.   LCD_WR_REG(0x11);
  8.   SysTick_Delay_Ms(100);
  9.   LCD_WR_REG(0x21);
  10.   LCD_WR_REG(0xB1);
  11.   LCD_WR_DATA8(0x05);
  12.   LCD_WR_DATA8(0x3A);
  13.   LCD_WR_DATA8(0x3A);
  14.   LCD_WR_REG(0xB2);
  15.   LCD_WR_DATA8(0x05);
  16.   LCD_WR_DATA8(0x3A);
  17.   LCD_WR_DATA8(0x3A);
  18.   LCD_WR_REG(0xB3);
  19.   LCD_WR_DATA8(0x05);
  20.   LCD_WR_DATA8(0x3A);
  21.   LCD_WR_DATA8(0x3A);
  22.   LCD_WR_DATA8(0x05);
  23.   LCD_WR_DATA8(0x3A);
  24.   LCD_WR_DATA8(0x3A);
  25.   LCD_WR_REG(0xB4);
  26.   LCD_WR_DATA8(0x03);
  27.   LCD_WR_REG(0xC0);
  28.   LCD_WR_DATA8(0x62);
  29.   LCD_WR_DATA8(0x02);
  30.   LCD_WR_DATA8(0x04);
  31.   LCD_WR_REG(0xC1);
  32.   LCD_WR_DATA8(0xC0);
  33.   LCD_WR_REG(0xC2);
  34.   LCD_WR_DATA8(0x0D);
  35.   LCD_WR_DATA8(0x00);
  36.   LCD_WR_REG(0xC3);
  37.   LCD_WR_DATA8(0x8D);
  38.   LCD_WR_DATA8(0x6A);
  39.   LCD_WR_REG(0xC4);
  40.   LCD_WR_DATA8(0x8D);
  41.   LCD_WR_DATA8(0xEE);
  42.   LCD_WR_REG(0xC5);
  43.   LCD_WR_DATA8(0x0E);
  44.   LCD_WR_REG(0xE0);
  45.   LCD_WR_DATA8(0x10);
  46.   LCD_WR_DATA8(0x0E);
  47.   LCD_WR_DATA8(0x02);
  48.   LCD_WR_DATA8(0x03);
  49.   LCD_WR_DATA8(0x0E);
  50.   LCD_WR_DATA8(0x07);
  51.   LCD_WR_DATA8(0x02);
  52.   LCD_WR_DATA8(0x07);
  53.   LCD_WR_DATA8(0x0A);
  54.   LCD_WR_DATA8(0x12);
  55.   LCD_WR_DATA8(0x27);
  56.   LCD_WR_DATA8(0x37);
  57.   LCD_WR_DATA8(0x00);
  58.   LCD_WR_DATA8(0x0D);
  59.   LCD_WR_DATA8(0x0E);
  60.   LCD_WR_DATA8(0x10);
  61.   LCD_WR_REG(0xE1);
  62.   LCD_WR_DATA8(0x10);
  63.   LCD_WR_DATA8(0x0E);
  64.   LCD_WR_DATA8(0x03);
  65.   LCD_WR_DATA8(0x03);
  66.   LCD_WR_DATA8(0x0F);
  67.   LCD_WR_DATA8(0x06);
  68.   LCD_WR_DATA8(0x02);
  69.   LCD_WR_DATA8(0x08);
  70.   LCD_WR_DATA8(0x0A);
  71.   LCD_WR_DATA8(0x13);
  72.   LCD_WR_DATA8(0x26);
  73.   LCD_WR_DATA8(0x36);
  74.   LCD_WR_DATA8(0x00);
  75.   LCD_WR_DATA8(0x0D);
  76.   LCD_WR_DATA8(0x0E);
  77.   LCD_WR_DATA8(0x10);
  78.   LCD_WR_REG(0x3A);
  79.   LCD_WR_DATA8(0x05);
  80.   LCD_WR_REG(0x36);
  81.   LCD_WR_DATA8(0x78);
  82.   LCD_WR_REG(0x29);
  83.   OLED_BLK_Set();
  84. }
以色彩清屏的函数为:
  1. void LCD_Clear(u16 Color)
  3.     u16 i,j;
  4.     LCD_Address_Set(0,0,LCD_W-1,LCD_H-1);
  5.     for(i=0;i<LCD_W;i++)
  6.     {
  7.        for (j=0;j<LCD_H;j++)
  8.        {
  9.           LCD_WR_DATA(Color);
  10.        }
  11.     }
  12. }
实现字符串显示的函数为:
  1. void LCD_ShowString(u16 x,u16 y,const u8 *p,u16 color)
  3.     while(*p!='\0')
  4.     {
  5.         if(x>LCD_W-16)
  6.         {
  7.            x=0;
  8.            y+=16;
  9.         }
  10.         if(y>LCD_H-16)
  11.         {
  12.            y=x=0;
  13.            LCD_Clear(RED);
  14.         }
  15.         LCD_ShowChar(x,y,*p,0,color);
  16.         x+=8;
  17.         p++;
  18.     }
  19. }
进行图片显示的函数为:
  1. void LCD_ShowPicturea(u16 x1,u16 y1,u16 x2,u16 y2)
  3.       int i;
  4.       LCD_Address_Set(x1,y1,x2,y2);
  5.       for(i=0;i<12800;i++)
  6.       {
  7.             LCD_WR_DATA8(gImage_FJ[i*2]);
  8.             LCD_WR_DATA8(gImage_FJ[i*2+1]);
  9.       }
  10. }
实现图1至图3所示效果的主程序为:
  1. int main(void)
  3.          LCD_Initialize();
  4.          Lcd_Init();
  5.          LCD_Clear(BLACK);
  6.          LCD_ShowString(20,10,"N32G430 TEST",RED);
  7.          LCD_ShowString(20,30,"0.96'  OLED",YELLOW);
  8.          SysTick_Delay_Ms(2000);
  9.          LCD_ShowPicturea(0,0,159,79);
  10.          SysTick_Delay_Ms(2000);
  11.          LCD_ShowPictureb(0,0,159,79);
  12.          while(1);
  13. }
经程序的编译与下载,其显示效果如下:
1显示字符串
2显示风景图片
3显示人物图片
