jinglixixi 发表于 2022-8-1 07:35
【N32G430开发板试用】 带中文菜单式MP3音乐播放器
#申请原创#
MP3音频模块是一种可以串口进行控制的器件,在设计中文菜单式MP3播放器时,用该模块可提高MCU处理的并行性,该设计的整体构成如图1所示。图1 整体构成图2 模块构成在运行过程中,其处理流程图3所示。图3处理流程图在使用过程中,通过板上的4个按键可进行歌曲的选取及音量调整等。此外,为了能扩展菜单的容量,还增添了边界自动换页的处理功能,其页面形式如图4所示。图4界面效果1. TFT显示屏驱动与界面设计在该设计中,是采用2.2寸TFT彩屏,它采用SPI接口来工作。1)引脚配置TFT屏与开发板连接关系为:BLK-------PB8CS---------PB7RS---------PB6RST-------PB5SCL------- PB3SDA------ PB4为便于控制引脚输出高低电平,其语句定义为:#define LCD_SCK_Low()   GPIO_Pins_Reset(GPIOB, GPIO_PIN_3)   //CLK#define LCD_SCK_High()GPIO_Pins_Set(GPIOB, GPIO_PIN_3)#define LCD_SDI_Low()   GPIO_Pins_Reset(GPIOB, GPIO_PIN_4)   //DIN#define LCD_SDI_High()   GPIO_Pins_Set(GPIOB,GPIO_PIN_4)#define LCD_REST_Low()   GPIO_Pins_Reset(GPIOB, GPIO_PIN_5)   //RES#define LCD_REST_High()GPIO_Pins_Set(GPIOB, GPIO_PIN_5)#define LCD_DC_Low()    GPIO_Pins_Reset(GPIOB, GPIO_PIN_6)   //DC#define LCD_DC_High()    GPIO_Pins_Set(GPIOB,GPIO_PIN_6)#define LCD_CS_Low()    GPIO_Pins_Reset(GPIOB, GPIO_PIN_7)   //CS#define LCD_CS_High()    GPIO_Pins_Set(GPIOB,GPIO_PIN_7)#define LCD_LED_High()   GPIO_Pins_Set(GPIOB,GPIO_PIN_8)    //BLK对TFT屏所用引脚的配置函数为:void app_tft_init(void)
         GPIO_InitType GPIO_InitStructure;
         RCC_AHB_Peripheral_Clock_Enable(RCC_AHB_PERIPH_GPIOA);
         GPIO_Structure_Initialize(&GPIO_InitStructure);
         GPIO_InitStructure.Pin= GPIO_PIN_5|GPIO_PIN_7;
         GPIO_InitStructure.GPIO_Mode = GPIO_MODE_OUT_PP;
         GPIO_InitStructure.GPIO_Current = GPIO_DS_4MA;
         GPIO_Peripheral_Initialize(GPIOA, &GPIO_InitStructure);
         RCC_AHB_Peripheral_Clock_Enable(RCC_AHB_PERIPH_GPIOB);
         GPIO_InitStructure.Pin = GPIO_PIN_5|GPIO_PIN_6|GPIO_PIN_7|GPIO_PIN_8;
         GPIO_Peripheral_Initialize(GPIOB, &GPIO_InitStructure);
         LCD_LED_High();
2)初始化为使TFT屏工作,其初始化函数为:void tft_Init(void)
         LCD_REST_Low();
         SysTick_Delay_Ms(20);
         LCD_REST_High();
      LCD_CS_Low();
      LCD_WR_REG(0xCB);
      LCD_WR_DATA8(0x39);
      LCD_WR_DATA8(0x2C);
      LCD_WR_DATA8(0x00);
      LCD_WR_DATA8(0x34);
      LCD_WR_DATA8(0x02);
      LCD_WR_REG(0xCF);
      LCD_WR_DATA8(0x00);
      LCD_WR_DATA8(0XC1);
      LCD_WR_DATA8(0X30);
      LCD_WR_REG(0xE8);
      LCD_WR_DATA8(0x85);
      LCD_WR_DATA8(0x00);
      LCD_WR_DATA8(0x78);
      LCD_WR_REG(0xEA);
      LCD_WR_DATA8(0x00);
      LCD_WR_DATA8(0x00);
      LCD_WR_REG(0xED);
      LCD_WR_DATA8(0x64);
      LCD_WR_DATA8(0x03);
      LCD_WR_DATA8(0X12);
      LCD_WR_DATA8(0X81);
      LCD_WR_REG(0xF7);
      LCD_WR_DATA8(0x20);
      LCD_WR_REG(0xC0);
      LCD_WR_DATA8(0x23);
      LCD_WR_REG(0xC1);
      LCD_WR_DATA8(0x10);
      LCD_WR_REG(0xC5);
      LCD_WR_DATA8(0x3e);
      LCD_WR_DATA8(0x28);
      LCD_WR_REG(0xC7);
      LCD_WR_DATA8(0x86);
      LCD_WR_REG(0x36);
      LCD_WR_DATA8(0x48);
      LCD_WR_REG(0x3A);
      LCD_WR_DATA8(0x55);
      LCD_WR_REG(0xB1);
      LCD_WR_DATA8(0x00);
      LCD_WR_DATA8(0x18);
      LCD_WR_REG(0xB6);
      LCD_WR_DATA8(0x08);
      LCD_WR_DATA8(0x82);
      LCD_WR_DATA8(0x27);
      LCD_WR_REG(0xF2);
      LCD_WR_DATA8(0x00);
      LCD_WR_REG(0x26);
      LCD_WR_DATA8(0x01);
      LCD_WR_REG(0xE0);
      LCD_WR_DATA8(0x0F);
      LCD_WR_DATA8(0x31);
      LCD_WR_DATA8(0x2B);
      LCD_WR_DATA8(0x0C);
      LCD_WR_DATA8(0x0E);
      LCD_WR_DATA8(0x08);
      LCD_WR_DATA8(0x4E);
      LCD_WR_DATA8(0xF1);
      LCD_WR_DATA8(0x37);
      LCD_WR_DATA8(0x07);
      LCD_WR_DATA8(0x10);
      LCD_WR_DATA8(0x03);
      LCD_WR_DATA8(0x0E);
      LCD_WR_DATA8(0x09);
      LCD_WR_DATA8(0x00);
      LCD_WR_REG(0XE1);
      LCD_WR_DATA8(0x00);
      LCD_WR_DATA8(0x0E);
      LCD_WR_DATA8(0x14);
      LCD_WR_DATA8(0x03);
      LCD_WR_DATA8(0x11);
      LCD_WR_DATA8(0x07);
      LCD_WR_DATA8(0x31);
      LCD_WR_DATA8(0xC1);
      LCD_WR_DATA8(0x48);
      LCD_WR_DATA8(0x08);
      LCD_WR_DATA8(0x0F);
      LCD_WR_DATA8(0x0C);
      LCD_WR_DATA8(0x31);
      LCD_WR_DATA8(0x36);
      LCD_WR_DATA8(0x0F);
      LCD_WR_REG(0x11);
      SysTick_Delay_Ms(120);
      LCD_WR_REG(0x29);
      LCD_WR_REG(0x2c);
3)界面实现该播放控制器的界面由图案和菜单构成,为便于控制,是按界面结构显示和菜单显示两部分来完成。实现图案显示的函数为:void show_tb(unsigned int x,unsigned int y)
         unsigned int i,j,k;
         unsigned int da;
         k=0;
         for(i=0;i<50;i++)
                   for(j=0;j<50;j++)
                            da=gImage_tb;
                            da<<=8;
                            da|=gImage_tb;
            POINT_COLOR=da;
            LCD_DrawPoint(x-j,y+i);
                            k++;
实现界面结构显示的函数为:void LCD_JM()
    LCD_Clear(RED);
    LCD_Fill(0,0,239,50,WHITE);
         show_tb(60,0);
         BACK_COLOR=WHITE;
         POINT_COLOR=RED;
         LCD_ShowChar(80,16,'M',1);
         LCD_ShowChar(90,16,'P',1);
         LCD_ShowChar(100,16,'3',1);
         showhanzi16(115,16,32);
         showhanzi16(135,16,33);
         showhanzi16(155,16,34);
         showhanzi16(175,16,35);
         showhanzi16(195,16,36);
         LCD_Fill(0,287,239,319,WHITE);
         BACK_COLOR=WHITE;
         POINT_COLOR=RED;
         LCD_ShowString(60,294,"BY: jinglixixi");
2. 中文菜单与选择处理由于在菜单中是实现中文歌单,故需按菜单内容来构建中文字库。1)字模提取使用图5所示的字模提取软件,可辅助完成中文字库的构建,其提取格式见图6所示。图5字模提取图6字模格式相应的字模存储结构为:unsigned char hanzi16[]=
0x80,0x20,0x82,0x20,0xF4,0x17,0x84,0x08,0x80,0x00,0xE1,0x23,0x02,0x20,0xEA,0x13,
0x28,0x0A,0x24,0x42,0xE7,0x43,0x24,0x22,0x44,0x21,0x04,0x17,0xF4,0x08,0x20,0x04,/*"澎",0*/
0x80,0x00,0x84,0x78,0x88,0x48,0xE8,0x4B,0x81,0x48,0x82,0x78,0x82,0x48,0xE8,0x4B,
0x28,0x4A,0x24,0x7A,0x27,0x4A,0xE4,0x4B,0x24,0x4A,0x04,0x44,0x04,0x54,0x00,0x22,/*"湖",1*/
0x80,0x00,0x04,0x01,0xF8,0x3F,0x88,0x04,0xA1,0x14,0x92,0x24,0x02,0x00,0xE8,0x0F,
0x08,0x08,0xE4,0x0F,0x27,0x00,0xE4,0x1F,0x04,0x10,0x04,0x10,0x04,0x0A,0x00,0x04,/*"湾",2*/
配合上面的字库结构,其汉字显示函数为:void showhanzi16(unsigned int x,unsigned int y,unsigned char index)
         unsigned char i,j,k;
         const unsigned char *temp=hanzi16;
         temp+=index*32;
         Address_set(x,y,x+16-1,y+16-1);
         for(j=0;j<16;j++)
                   for(k=0;k<2;k++)
                            for(i=0;i<8;i++)
                                    if((*temp&(1<<i))!=0)
                                             LCD_WR_DATA(POINT_COLOR);
                                     else
                                             LCD_WR_DATA(BACK_COLOR);
                            temp++;
2)中文菜单利用中文字库,实现中文菜单显示的函数为:void LCD_MENU()
         BACK_COLOR=RED;
         POINT_COLOR=YELLOW;
         showhanzi16(60,75,0);
         showhanzi16(80,75,1);
         showhanzi16(100,75,2);
         showhanzi16(30,75,37);
         showhanzi16(60,105,3);
         showhanzi16(80,105,4);
         showhanzi16(100,105,5);
         showhanzi16(120,105,6);
         showhanzi16(60,135,7);
         showhanzi16(80,135,8);
         showhanzi16(60,165,9);
         showhanzi16(80,165,10);
         showhanzi16(60,195,11);
         showhanzi16(80,195,12);
         showhanzi16(100,195,13);
         showhanzi16(120,195,14);
         showhanzi16(60,225,15);
         showhanzi16(80,225,16);
         showhanzi16(100,225,17);
         showhanzi16(120,225,18);
         showhanzi16(140,225,19);
         showhanzi16(60,255,20);
         showhanzi16(80,255,21);
         showhanzi16(100,255,22);
         showhanzi16(120,255,23);
         showhanzi16(140,255,24);
         showhanzi16(160,255,25);
         showhanzi16(180,255,26);
3)选择处理与指示在开发板上,共有5个按键,除复位键外,皆可用于程序控制,其原理图见图7所示。图7LED与KEY电路为便于MP3的控制,其中各键的功能分配如下:S1------PA4----下一首S2------PA5----上一首S3------PA6----确认S6------PA0----音量此外,为了便于观察还使用D1和D2来指示S1和S2键的操作状态。在歌曲选择时,是通过星型的光标来指示的,在确认后即可播放选择的歌曲。实现按键选择及播放的测试程序如下:void sele()
         BACK_COLOR=RED;
         POINT_COLOR=YELLOW;
         h=75;
         i=0;
         while(1)
               if(GPIO_Input_Pin_Data_Get(GPIOA, GPIO_PIN_4)==0)
                                     GPIO_Pins_Set(GPIOA, GPIO_PIN_1);
                                     if(i<6)
                                             i++;
                                          LCD_Fill(30,h,50,h+20,RED);
                                          h=h+30;
                                          showhanzi16(30,h,37);
            else
                                     GPIO_Pins_Reset(GPIOA, GPIO_PIN_1);
                            if(GPIO_Input_Pin_Data_Get(GPIOA, GPIO_PIN_5)==0)
                                     GPIO_Pins_Set(GPIOA, GPIO_PIN_7);
                if(i>0)
                                                i--;
                                          h=h-30;
            else
                                     GPIO_Pins_Reset(GPIOA, GPIO_PIN_7);
                            if(GPIO_Input_Pin_Data_Get(GPIOA, GPIO_PIN_6)==0)
                                     playn(i);
                                     TxCounter=0;
                                     while (TxCounter < 10)
                                                USART_Data_Send(USARTy, cmd3);
                                     TxCounter++;
                                                while(USART_Flag_Status_Get(USARTy, USART_FLAG_TXDE) == RESET);
            SysTick_Delay_Ms(200);
3. MP3播放模块控制MP3播放模块是一款可以串口通信进行控制的器件,其引脚分别如图8所示。其实,在使用中除电源引脚外,它只占用一个串口输出引脚,即PA9。此外,由于该模块的通讯波特率为9600bps,故需在此波特率下工作。图8MP3播放模块1)串口通信字节指令发送是控制MP3播放模块的关键,其程序为:TxCounter=0;
         USART_Data_Send(USARTy, cmd);
         TxCounter++;
2)播放控制MP3播放指定乐曲是靠指定音乐序号来完成的,其生成相应播放指令的函数为:void playn(int index)
         int i;
         unsigned char checksum = 0;
         cmd3 = (unsigned char)(index >> 8);
         cmd3 = (unsigned char)(index);
         for (i=2; i<8; i++)
                   checksum += cmd3;
         cmd3 = (unsigned char)~checksum;
3)音量调节为在播放过程中对音量加以动态调节,是使用s6键,由于只有一个键可用,故其调节模式为先由低到高调整,在跌倒到最低音量开始增大调节。控制音量调节的函数为:void setVolume(unsigned char index)
         int i;
         cmd6 = (unsigned char)(index);
         for (i=2; i<8; i++)
                   checksum += cmd6;
         cmd6 = (unsigned char)~checksum;
MP3播放模块的指令测试如图9所示,说明它已能进行播放控制。图9 指令发送测试结束语:尽管N32G430的长项不在于音乐播放,但这不妨碍我们以技术手段来达到我们的目标。在N32G430开发板上实现语音的播放还是十分具有特色和实用价值的。当然,它也适用于其它进行语音提示等人机交互场合。视频演示:https://www.bilibili.com/video/BV1vB4y1h7bJ/?vd_source=f302fc0cc3a0425328db53a3b92082ca
albertaabbot 发表于 2022-8-16 22:19
支持模块效果吗
支持模块效果吗
pixhw 发表于 2022-8-18 18:11
这个看着非常棒呢
这个看着非常棒呢
{:handshake:}
phoenixwhite 发表于 2022-8-20 12:58
这个看着不错。
adolphcocker 发表于 2022-8-20 14:08
使用gui了吗?
使用gui了吗?
哦,没有。
10299823 发表于 2022-8-20 14:42
音频模块用的是什么
chenci2013 发表于 2022-11-3 21:23
中文是自己添加的字库吗?
abotomson 发表于 2022-11-3 21:37
能不能直接通过N32G430控制音频模块输出?
很费事!
中文是自己添加的字库吗?
需要自行添加字库,否则太大。
音频模块用的是什么
MP3播放模块
louliana 发表于 2022-11-3 21:57
如何解析mp3的并输出到音频模块上?
如何解析mp3的并输出到音频模块上?
模块内部都解决了,你只需按它的指令来控制。
alvpeg 发表于 2022-11-5 09:49
这个高端了,设计的非常好,N32G430资源都用上了。
感谢支持!!!
页: [1]
查看完整版本: 【N32G430开发板试用】 带中文菜单式MP3音乐播放器
