wuxiubo 发表于 2022-8-13 19:56
【N32G430开发板试用】+ST7789V液晶屏点亮显示(软件模拟SPI)
@安小芯
今天先尝试下先移植显示ST7789V液晶显示,还是先建立我们自己的库,后期添加啥也方便。
我选择的这款就是来自之前稚晖君的一个开源项目买剩下的,焊接式所以需要自己改动下,做个小板子即可。
void LCD_GPIO_Init(void)
       GPIO_InitTypeDefGPIO_InitStructure;
      RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);    //使能A端口时钟
       GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4;
      GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;         //推挽输出
       GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;//速度50MHz
      GPIO_Init(GPIOA, &GPIO_InitStructure);      //初始化GPIOA
      GPIO_SetBits(GPIOA,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4);
软件模拟的相对简单很多,需要搞定延时函数和GPIO初始化即可。
      LCD_GPIO_Init();//初始化GPIO
       LCD_RES_Clr();//复位
       delay_ms(100);
       LCD_RES_Set();
       delay_ms(100);
       LCD_BLK_Set();//打开背光
       delay_ms(100);
       //************* Start Initial Sequence **********//
       LCD_WR_REG(0x11); //Sleep out
       delay_ms(120);            //Delay 120ms
       LCD_WR_REG(0x36);
       if(USE_HORIZONTAL==0)LCD_WR_DATA8(0x00);
       else if(USE_HORIZONTAL==1)LCD_WR_DATA8(0xC0);
       else if(USE_HORIZONTAL==2)LCD_WR_DATA8(0x70);
       else LCD_WR_DATA8(0xA0);
       LCD_WR_REG(0x3A);
       LCD_WR_DATA8(0x05);
       LCD_WR_REG(0xB2);
       LCD_WR_DATA8(0x0C);
       LCD_WR_DATA8(0x0C);
       LCD_WR_DATA8(0x00);
       LCD_WR_DATA8(0x33);
       LCD_WR_DATA8(0x33);
       LCD_WR_REG(0xB7);
       LCD_WR_DATA8(0x35);
       LCD_WR_REG(0xBB);
       LCD_WR_DATA8(0x19);
       LCD_WR_REG(0xC0);
       LCD_WR_DATA8(0x2C);
       LCD_WR_REG(0xC2);
       LCD_WR_DATA8(0x01);
       LCD_WR_REG(0xC3);
       LCD_WR_DATA8(0x12);
       LCD_WR_REG(0xC4);
       LCD_WR_DATA8(0x20);
       LCD_WR_REG(0xC6);
       LCD_WR_DATA8(0x0F);
       LCD_WR_REG(0xD0);
       LCD_WR_DATA8(0xA4);
       LCD_WR_DATA8(0xA1);
       LCD_WR_REG(0xE0);
       LCD_WR_DATA8(0xD0);
       LCD_WR_DATA8(0x04);
       LCD_WR_DATA8(0x0D);
       LCD_WR_DATA8(0x11);
       LCD_WR_DATA8(0x13);
       LCD_WR_DATA8(0x2B);
       LCD_WR_DATA8(0x3F);
       LCD_WR_DATA8(0x54);
       LCD_WR_DATA8(0x4C);
       LCD_WR_DATA8(0x18);
       LCD_WR_DATA8(0x0D);
       LCD_WR_DATA8(0x0B);
       LCD_WR_DATA8(0x1F);
       LCD_WR_DATA8(0x23);
       LCD_WR_REG(0xE1);
       LCD_WR_DATA8(0xD0);
       LCD_WR_DATA8(0x04);
       LCD_WR_DATA8(0x0C);
       LCD_WR_DATA8(0x11);
       LCD_WR_DATA8(0x13);
       LCD_WR_DATA8(0x2C);
       LCD_WR_DATA8(0x3F);
       LCD_WR_DATA8(0x44);
       LCD_WR_DATA8(0x51);
       LCD_WR_DATA8(0x2F);
       LCD_WR_DATA8(0x1F);
       LCD_WR_DATA8(0x1F);
       LCD_WR_DATA8(0x20);
       LCD_WR_DATA8(0x23);
       LCD_WR_REG(0x21);
       LCD_WR_REG(0x29);
初始胡基本就是配置屏幕内置芯片ST7789V这个芯片参数,通过发送多个数据到其寄存器中即可完成初始化了。
在其驱动中我们可以显示各种内容,这里初始化之后显示的就是一些文字,数字,图片这些。还可以绘制一些图形,如矩形,正方形,圆形等等。
后续我们再添加一些功能,显示一些东西在这个液晶屏上。
1988020566 发表于 2022-12-3 12:06
这个的驱动速度很快的吗?
chenci2013 发表于 2022-12-3 12:54
彩色屏幕的用来显示还是比较棒的。
phoenixwhite 发表于 2022-12-6 16:51
ST7789V是否支持5V的输入电压呢?
页: [1]
查看完整版本: 【N32G430开发板试用】+ST7789V液晶屏点亮显示(软件模拟SPI)
