[活动专区] 【N32G430开发板试用】+ST7789V液晶屏点亮显示(软件模拟SPI)
1038|3
 楼主| wuxiubo 发表于 2022-8-13 19:56 | 显示全部楼层 |阅读模式
@安小芯
今天先尝试下先移植显示ST7789V液晶显示,还是先建立我们自己的库,后期添加啥也方便。
我选择的这款就是来自之前稚晖君的一个开源项目买剩下的,焊接式所以需要自己改动下,做个小板子即可。
  1. void LCD_GPIO_Init(void)
  3.        GPIO_InitTypeDef  GPIO_InitStructure;
  4.       RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);    //使能A端口时钟
  5.        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4;
  6.       GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;         //推挽输出
  7.        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;//速度50MHz
  8.       GPIO_Init(GPIOA, &GPIO_InitStructure);      //初始化GPIOA
  9.       GPIO_SetBits(GPIOA,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4);
  10. }
软件模拟的相对简单很多,需要搞定延时函数和GPIO初始化即可。
  1.       LCD_GPIO_Init();//初始化GPIO
  2.
  3.        LCD_RES_Clr();//复位
  4.        delay_ms(100);
  5.        LCD_RES_Set();
  6.        delay_ms(100);
  7.
  8.        LCD_BLK_Set();//打开背光
  9.        delay_ms(100);
  10.
  11.        //************* Start Initial Sequence **********//
  12.        LCD_WR_REG(0x11); //Sleep out
  13.        delay_ms(120);              //Delay 120ms
  14.        //************* Start Initial Sequence **********//
  15.        LCD_WR_REG(0x36);
  16.        if(USE_HORIZONTAL==0)LCD_WR_DATA8(0x00);
  17.        else if(USE_HORIZONTAL==1)LCD_WR_DATA8(0xC0);
  18.        else if(USE_HORIZONTAL==2)LCD_WR_DATA8(0x70);
  19.        else LCD_WR_DATA8(0xA0);
  20.        LCD_WR_REG(0x3A);
  21.        LCD_WR_DATA8(0x05);
  22.        LCD_WR_REG(0xB2);
  23.        LCD_WR_DATA8(0x0C);
  24.        LCD_WR_DATA8(0x0C);
  25.        LCD_WR_DATA8(0x00);
  26.        LCD_WR_DATA8(0x33);
  27.        LCD_WR_DATA8(0x33);
  28.        LCD_WR_REG(0xB7);
  29.        LCD_WR_DATA8(0x35);
  30.        LCD_WR_REG(0xBB);
  31.        LCD_WR_DATA8(0x19);
  32.        LCD_WR_REG(0xC0);
  33.        LCD_WR_DATA8(0x2C);
  34.        LCD_WR_REG(0xC2);
  35.        LCD_WR_DATA8(0x01);
  36.        LCD_WR_REG(0xC3);
  37.        LCD_WR_DATA8(0x12);
  38.        LCD_WR_REG(0xC4);
  39.        LCD_WR_DATA8(0x20);
  40.        LCD_WR_REG(0xC6);
  41.        LCD_WR_DATA8(0x0F);
  42.        LCD_WR_REG(0xD0);
  43.        LCD_WR_DATA8(0xA4);
  44.        LCD_WR_DATA8(0xA1);
  45.        LCD_WR_REG(0xE0);
  46.        LCD_WR_DATA8(0xD0);
  47.        LCD_WR_DATA8(0x04);
  48.        LCD_WR_DATA8(0x0D);
  49.        LCD_WR_DATA8(0x11);
  50.        LCD_WR_DATA8(0x13);
  51.        LCD_WR_DATA8(0x2B);
  52.        LCD_WR_DATA8(0x3F);
  53.        LCD_WR_DATA8(0x54);
  54.        LCD_WR_DATA8(0x4C);
  55.        LCD_WR_DATA8(0x18);
  56.        LCD_WR_DATA8(0x0D);
  57.        LCD_WR_DATA8(0x0B);
  58.        LCD_WR_DATA8(0x1F);
  59.        LCD_WR_DATA8(0x23);
  60.        LCD_WR_REG(0xE1);
  61.        LCD_WR_DATA8(0xD0);
  62.        LCD_WR_DATA8(0x04);
  63.        LCD_WR_DATA8(0x0C);
  64.        LCD_WR_DATA8(0x11);
  65.        LCD_WR_DATA8(0x13);
  66.        LCD_WR_DATA8(0x2C);
  67.        LCD_WR_DATA8(0x3F);
  68.        LCD_WR_DATA8(0x44);
  69.        LCD_WR_DATA8(0x51);
  70.        LCD_WR_DATA8(0x2F);
  71.        LCD_WR_DATA8(0x1F);
  72.        LCD_WR_DATA8(0x1F);
  73.        LCD_WR_DATA8(0x20);
  74.        LCD_WR_DATA8(0x23);
  75.        LCD_WR_REG(0x21);
  76.        LCD_WR_REG(0x29);
  77. }
初始胡基本就是配置屏幕内置芯片ST7789V这个芯片参数,通过发送多个数据到其寄存器中即可完成初始化了。
在其驱动中我们可以显示各种内容,这里初始化之后显示的就是一些文字,数字,图片这些。还可以绘制一些图形,如矩形,正方形,圆形等等。
后续我们再添加一些功能,显示一些东西在这个液晶屏上。
1988020566 发表于 2022-12-3 12:06 | 显示全部楼层
这个的驱动速度很快的吗?
chenci2013 发表于 2022-12-3 12:54 | 显示全部楼层
彩色屏幕的用来显示还是比较棒的。
phoenixwhite 发表于 2022-12-6 16:51 | 显示全部楼层
ST7789V是否支持5V的输入电压呢?
