STM32F103步进电机驱动简单控制
stm32f103步进电机驱动控制 一、硬件接线方法 本文采用混合式二相步进电机-J8HB2401-野火42步进电机,驱动器为野火EBF-MSD4805,下面是常用接线方式:如上图所示通常采用共阴接线方式,具体接线按照自己需求进行完成。
另外二相电机步距角1.8°,步进驱动器侧面SW1-SW8分别为细分设定、电流设定和驱动模式选择开关。 二、程序
代码如下(示例):
1.main.c
#include "stm32f10x.h"
#include "tim.h"
#include "bsp_usart.h"
#include "stm32f10x_it.h"
#include "stm32f10x_conf.h"
/* 共阴 */
PUL+->PA.1PUL-接GND
DIR+->PA.8DIR-接GND
extern int motor_dir2;
extern int motor_speed;
int main(void)
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
USART_Config();
Driver_Init();/* GPIO_Init */
TIM2_Init(999,72-1);
while(1)
Locate_Rle2(motor_speed,motor_dir2);/* 变速以及方向 */
2.tim.c
#include "tim.h"
long current_pos = {0,0};
int motor_dir2 = 0;
u8 count = {0,0};
u32 motor_speed = 0;
u8 rcr_remainder; //重复计数余数部分
u8 is_rcr_finish = 1; //重复计数器是否设置完成
long rcr_integer; //重复计数整数部分
long target_pos = 0; //有符号方向
/* 电机转速与方向函数 */
void Locate_Rle2(u32 frequency,DIR_Type dir)
motor_dir2 = dir;
DRIVER_DIR = motor_dir2;
if(motor_dir2 == CW){motor_speed = 3000;}/* motor_dir2高电平时转速3000Hz */
else if(motor_dir2 == CCW){motor_speed = 10000;}/* motor_dir2低电平时转速10000Hz */
frequency = motor_speed;
if(TIM2->CR1&0x01)
printf("\r\nThe last time pulses is not send finished,wait please!\r\n");
return;
if((frequency<20)||(frequency>100000))
printf("\r\nThe frequency is out of range! please reset it!!(range:20Hz~100KHz)\r\n");
return;
TIM2_Startup(frequency);
/* PA8 - DIR+*/
void Driver_Init(void)
GPIO_InitTypeDefGPIO_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_Init(GPIOA, &GPIO_InitStructure);
GPIO_SetBits(GPIOA,GPIO_Pin_8);
/* PA1- PUL+ TIM2_CH2 */
void TIM2_Init(u16 arr,u16 psc)
TIM_TimeBaseInitTypeDefTIM_TimeBaseStructure;
TIM_OCInitTypeDefTIM_OCInitStructure;
NVIC_InitTypeDef NVIC_InitStructure;
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA , ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
TIM_TimeBaseStructInit(&TIM_TimeBaseStructure);
TIM_TimeBaseStructure.TIM_Period = arr;
TIM_TimeBaseStructure.TIM_Prescaler =psc;
TIM_TimeBaseStructure.TIM_ClockDivision = 0;
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
TIM_ClearITPendingBit(TIM2,TIM_IT_Update);
TIM_UpdateRequestConfig(TIM2,TIM_UpdateSource_Regular);
TIM_SelectOnePulseMode(TIM2,TIM_OPMode_Single);
TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;
TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
TIM_OCInitStructure.TIM_Pulse = arr>>1;
TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
TIM_OC2Init(TIM2, &TIM_OCInitStructure);
TIM_OC2PreloadConfig(TIM2, TIM_OCPreload_Enable);
TIM_ARRPreloadConfig(TIM2, ENABLE);
TIM_ITConfig(TIM2, TIM_IT_Update ,ENABLE);
NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
TIM_ClearITPendingBit(TIM2, TIM_IT_Update);
TIM_Cmd(TIM2, DISABLE);
void TIM2_Startup(u32 frequency)
u16 temp_arr=1000000/frequency-1;
TIM_SetAutoreload(TIM2,temp_arr);
TIM_SetCompare2(TIM2,temp_arr>>1);
TIM_SetCounter(TIM2,0);
TIM_Cmd(TIM2, ENABLE);
3.tim.h
#include "stdlib.h"
#define BITBAND(addr, bitnum) ((addr & 0xF0000000)+0x02000000+((addr & 0x00FFFFFF)<<5)+(bitnum<<2))
#define MEM_ADDR(addr)*((volatile unsigned long*)(addr))
#define BIT_ADDR(addr, bitnum) MEM_ADDR(BITBAND(addr, bitnum))
#define PAout(n) BIT_ADDR(GPIOA_ODR_Addr,n)
#define GPIOA_ODR_Addr (GPIOA_BASE+12)
#define DRIVER_DIR PAout(8)
typedef enum
CW = 1,//高电平顺时针
CCW = 0,//低电平逆时针
}DIR_Type;
void Driver_Init(void);
void TIM2_Init(u16 arr,u16 psc);
void TIM2_Startup(u32 frequency);
void Locate_Rle2(u32 frequency,DIR_Type dir);
4.stm32f10x_it.c
/* Includes ------------------------------------------------------------------*/
#include "tim.h"
#include "systick.h"
extern u8 count;
extern long current_pos; //有符号方向
int counter = 0;
/******* TIM2 - 1ms*********/
void TIM2_IRQHandler(void)
if(TIM_GetITStatus(TIM2,TIM_FLAG_Update)!=RESET)
TIM_ClearITPendingBit(TIM2,TIM_FLAG_Update);
count++;
counter ++;
TIM_GenerateEvent(TIM2,TIM_EventSource_Update);
if(count==200)
if(motor_dir2==CW)
current_pos+=count;
else
current_pos-=count;
printf("\r\n motor2=%ld\r\n",current_pos);
count=0;
if(counter <= 5000){motor_dir2=CW;}/* 定时器前5s拉高motor_dir2电平 */
else if((counter > 5000) && (counter <= 10000)){motor_dir2=CCW;}/* 拉低电平 */
else if(counter > 10000){counter=0;}/* 复位 */
a.中断函数可以从保准库中进行拷贝,具体采用哪一个串口自己需要对照原理图;
b.PAout(n)函数采用GPIO-位带操作, 把“位带地址+ 位序号”转换成别名地址宏统一公式如下,详见野火指南:
需要设定一个阈值来对像素点进行设置
一种了解状态变化的简单方法
单片机一般都有内部程序区和数据区
代码量小的时候用来做条件判断
但是如果不懂程序设计的思想的话,会给你做项目的过程中带来很多很多的困惑。
STM32CUBEMX配置生成初始化代码
单片机一般都有内部程序区和数据区
光绘出零件间联机的PCB设计布线
只要内存占用量不超过 256.0 就可以用 small 模式编译
这是步进电机吗
二值化就是让图像的像素点矩阵中的每个像素点的灰度值为0(黑色)或者255(白色
页:
[1]
