不能进入中断了
以前正常楼主程序可以公开吗?贴程序看下吧,这么说看不出什么原因
#include "stm32f10x.h"
void RCC_Configuration(void);
void GPIO_Configuration(void);
void NVIC_Configuration(void);
void delay(vu32 nCount)
for(; nCount != 0; nCount--);
int main(void)
RCC_Configuration();//系统时钟配置
NVIC_Configuration();//中断配置
GPIO_Configuration();//GPIO口配置
/* while(1) //LED灯循环亮灭,串口循环发送ASCII“9”
delay(5000000);
// USART_SendData(USART1,9);
while(USART_GetFlagStatus(USART1,USART_FLAG_TXE) == RESET)
//系统时钟配置
RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);//使能串口1的GPIO时钟
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE); //pa.9 pa.10 led0
//串口GPIO口配置
USART_InitTypeDef USART_InitStructure;
/* LED0*/
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2|GPIO_Pin_3;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_Init(GPIOA, &GPIO_InitStructure);
// GPIO_PinRemapConfig(GPIO_Remap_USART1, ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //复用推挽输出
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; //悬浮输入
USART_InitStructure.USART_BaudRate = 9600; //设定波特率
USART_InitStructure.USART_WordLength = USART_WordLength_8b;//传输数据位数
USART_InitStructure.USART_StopBits = USART_StopBits_1; //停止位1
USART_InitStructure.USART_Parity = USART_Parity_No; //不用校验位
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//不用流量控制
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; //使用接收和发送功能
USART_Init(USART1, &USART_InitStructure); //初始化串口1
USART_ITConfig(USART1, USART_IT_RXNE, ENABLE); //使能串口1 读中断
USART_Cmd(USART1,ENABLE);//串口1使能
//中断配置
NVIC_InitTypeDef NVIC_InitStructure;
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0); //先占优先权2,从优先级2位
NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn; //开串口中断1
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=0; //指定抢占优先级别1
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; //指定相应优先级别0
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
void USART1_IRQHandler(void) //串口接收中断,并将接收到得数据发送出
u16 temp_trx;
if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET)//判断 是否 接收中断
temp_trx = USART_ReceiveData(USART1);
USART_SendData(USART1,temp_trx);
// GPIO_WriteBit(GPIOA,GPIO_Pin_2,(BitAction)(1-GPIO_ReadOutputDataBit(GPIOA,GPIO_Pin_2)));
} 麻烦你确认下中断源是否触发了中断事件;结合你的情况,主要检查下硬件方面
检查下你的配置代码有无调整过、启动文件是否跟所选芯片一致
当然上面的前提是芯片真的能跑起来;
103ZE的以前可以运行,C8T6的不行,换了103ZE的后也不行了
出现什么情况后不能进入的中断啊
运行的半路不可以的 还是说重新下载之后不可以的啊
先擦除干净试试。
在什么情况下程序不能进入中断了呢 楼主有观察到吗 通过代码分析楼主使用的是串口中断那么串口上的数据来源是哪里呢 中断 时钟和引脚都配置了 但是没有串口的配置代码啊 首选确认是否改动过函数另外确认是否使能了总中断以及串口中断 io口和串口的配置有点混乱了 另外我建议配置的顺序可以颠倒一下 楼主在主函数中并没有开启相应的中断使能呀 配置的顺序换一下试试 楼主,你修改了芯片确认一下手册,引脚位置是不是正确 什么情况不能进入中断的? 没有串口的配置代码啊
页:
[1]
