[STM32F1]
不能进入中断了
936|25
llljh|  楼主 | 2022-10-9 21:25 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
以前正常
huwr| | 2022-10-9 21:30 | 只看该作者
楼主程序可以公开吗?贴程序看下吧,这么说看不出什么原因
llljh|  楼主 | 2022-10-9 21:32 | 只看该作者
#include "stm32f10x.h"
void RCC_Configuration(void);
void GPIO_Configuration(void);
void NVIC_Configuration(void);
void delay(vu32 nCount)
for(; nCount != 0; nCount--);
int main(void)
RCC_Configuration();//系统时钟配置
NVIC_Configuration();//中断配置
GPIO_Configuration();//GPIO口配置
/* while(1)          //LED灯循环亮灭,串口循环发送ASCII“9”
  delay(5000000);
// USART_SendData(USART1,9);
     while(USART_GetFlagStatus(USART1,USART_FLAG_TXE) == RESET)
//系统时钟配置
RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);//使能串口1的GPIO时钟
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,  ENABLE); //pa.9 pa.10 led0
//串口GPIO口配置
USART_InitTypeDef USART_InitStructure;
/* LED0*/
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2|GPIO_Pin_3;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_Init(GPIOA, &GPIO_InitStructure);
// GPIO_PinRemapConfig(GPIO_Remap_USART1, ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;     //复用推挽输出
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;   //悬浮输入
USART_InitStructure.USART_BaudRate = 9600;      //设定波特率
USART_InitStructure.USART_WordLength = USART_WordLength_8b;  //传输数据位数
USART_InitStructure.USART_StopBits = USART_StopBits_1;   //停止位1
USART_InitStructure.USART_Parity = USART_Parity_No;    //不用校验位
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//不用流量控制
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; //使用接收和发送功能
USART_Init(USART1, &USART_InitStructure);       //初始化串口1
USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);     //使能串口1 读中断
USART_Cmd(USART1,ENABLE);  //串口1使能
//中断配置
NVIC_InitTypeDef NVIC_InitStructure;
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);     //先占优先权2,从优先级2位
NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;    //开串口中断1
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=0;   //指定抢占优先级别1
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;    //指定相应优先级别0
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
void USART1_IRQHandler(void)       //串口接收中断,并将接收到得数据发送出
u16 temp_trx;
if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET)//判断 是否 接收中断
  temp_trx = USART_ReceiveData(USART1);
  USART_SendData(USART1,temp_trx);
        //        GPIO_WriteBit(GPIOA,GPIO_Pin_2,(BitAction)(1-GPIO_ReadOutputDataBit(GPIOA,GPIO_Pin_2)));
juventus9554| | 2022-10-9 21:34 | 只看该作者
麻烦你确认下中断源是否触发了中断事件;结合你的情况,主要检查下硬件方面
heweibig| | 2022-10-9 21:36 | 只看该作者
检查下你的配置代码有无调整过、启动文件是否跟所选芯片一致
jiajs| | 2022-10-9 21:40 | 只看该作者
当然上面的前提是芯片真的能跑起来;
llljh|  楼主 | 2022-10-9 21:43 | 只看该作者
103ZE的以前可以运行,C8T6的不行,换了103ZE的后也不行了
chenho| | 2022-10-9 21:48 | 只看该作者
出现什么情况后不能进入的中断啊
stly| | 2022-10-9 21:50 | 只看该作者
运行的半路不可以的 还是说重新下载之后不可以的啊
huangchui| | 2022-10-9 21:52 | 只看该作者
先擦除干净试试。
tpgf| | 2022-11-7 15:01 | 只看该作者
在什么情况下程序不能进入中断了呢 楼主有观察到吗
八层楼| | 2022-11-7 15:16 | 只看该作者
通过代码分析楼主使用的是串口中断  那么串口上的数据来源是哪里呢
观海| | 2022-11-7 15:26 | 只看该作者
中断 时钟和引脚都配置了 但是没有串口的配置代码啊
guanjiaer| | 2022-11-7 15:55 | 只看该作者
首选确认是否改动过函数  另外确认是否使能了总中断以及串口中断
heimaojingzhang| | 2022-11-7 16:05 | 只看该作者
io口和串口的配置有点混乱了 另外我建议配置的顺序可以颠倒一下
keaibukelian| | 2022-11-7 16:14 | 只看该作者
楼主在主函数中并没有开启相应的中断使能呀
SantaBunny| | 2022-11-7 17:48 | 只看该作者
配置的顺序换一下试试
中国龙芯CDX| | 2022-11-7 17:57 | 只看该作者
楼主,你修改了芯片确认一下手册,引脚位置是不是正确
MessageRing| | 2022-11-9 20:25 | 只看该作者
什么情况不能进入中断的?
Stahan| | 2022-11-11 18:08 | 只看该作者
没有串口的配置代码啊
