lilywallys 发表于 2022-12-2 13:12
QCA9880 QCA9882 Dual Band Network Card 802.11ac with FCC IC/Wallys
Qualcomm QCA9880
Qualcomm QCA9880 is a highly integrated wireless local area network (WLAN) system chip (SoC) 5 GHz 802.1ac or 2.4/5 GHz 802.11n WLAN application. The QCA9880 integrates an onboard CPU for low-level WLAN physical layer (PHY) and RF space flow, and is used for wireless applications, requiring the highest reliable link quality and maximum range. It also integrates multi protocol MAC, PHY, analog digital/digital analog converter (ADC/DAC), 3x3 MIMO wireless transmitter and PCI Express interface with low power consumption.
The QCA9880 implements half duplex OFDM, CCK and DSSS PHY, and supports 1.3 GBps 802.11ac 80 mhz channel operations. It supports 802.11n to 216.7 Mbps 20 mhz and 450 Mbps 40 MHz channel options, and IEEE 802.11a/b/g data rate. Additional features include Maximum Likelihood (ML) decoding, Low Density Local Check (LDPC), Maximum Proportional Consolidation (MRC), Spac Time Block Code (STBC), and On Chip One Time Programming Memory (OTP) to eliminate the need for external flash memory and further reduce the cost of external component counts and BOMs. The QCA9880 supports 802.11i security, Rx/Tx filtering, error recovery, and 802. Service quality assurance.
The QCA9880 supports up to three simultaneous traffic flows and integrates three Tx and three Rx chains to achieve high capacity and expanded coverage. The Tx chain combines PHY in phase (I) and quadrature (Q) signals, converts them into the required frequency, and drives RF signals to multiple antennas. The Rx chain uses an integrated architecture. The frequency synthesizer supports the 1-MHz step to match the frequency defined in the IEEE 802.11a/b/g/n specification. QCA9880 supports the transmission of frame data to the host through the PCIE interface, and provides the host with interrupt generation and report, power saving and status report. Other external interfaces include EEPROM and GPIOs.
Qualcomm Atheros QCA9882
Qualcomm Atheros QCA9882 is a highly integrated wireless local area network (WLAN) system on chip (SoC) for 5 GHz 802.11ac or 2.4/5 GHz 802.11n WLAN applications. QCA9882 integrates an onboard CPU for the lower layer settings of the wireless LAN physical layer (PHY) and RF to alleviate other tasks of the host processor. It supports high-performance 2x2 MIMO with two spatial streams for wireless applications requiring the highest robust link quality and maximum throughput and range. QCA9882 integrates multi protocol mac, phy, analog digital/digital analog converter (adc/dac), 2x2 mimo transceiver and PCIExpress interface. It is applicable to all CMOS devices and is used for low power consumption and small size applications.
QCA9882 implements half duplex OFDM, CCK and DSSS PHY, and supports 867Mbps of 802.11ac 80 MHz channel operation. It supports 802.11n up to 150Mbps, 20MHz and 300Mbps for 40MHz channel operation and IEEE802.11a/b/g data rate. Other features include maximum likelihood (ML) decoding, low density parity check (Ldpc), maximum ratio combining (Mrc), space time block code (Stbc) and on-chip single time programmability (Ocp). Memory eliminates the need for external flash memory and further reduces the count of external components and BOM costs. QCA9882 supports 802.11 wireless MAC protocol, 802.11i security, Rx/Tx filtering, error recovery, and 802.11e quality of service (QoS).
QCA9882 supports up to two simultaneous service flows, integrating two TX and two Rx chains together to achieve high throughput and extended coverage. TX chain combines PHY in-phase (I) and quadrature (Q) signals together, converts them to the required frequency, and drives RF signals to multiple antennas. The RX chain uses an integrated architecture. The frequency synthesizer supports the 1 MHz step to match the frequency defined by IEEE 802.11a/b/g/n specification. QCA9882 supports frame data transmission between PCIe interface and host. Provide interrupt generation and report, power saving and status report. Other external interfaces include EEPROM and GPO.
Wallys network cards DR882/DR900VX/DR600VX with FCC certificate and are able to work with mikrotik routerboard.
DR882
Featuring with industrial-grade Atheros’s QCA9882 chipset
Integrated with 2x 2 5G high power Radio Card
4.940GHz to 5.825GHz Frequency Range
2 x 5G MMCX Connectors
20MHz/40MHz/80MHz Bandwidth
Support 802. 11AC/AN
RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals
Click below the link for more parameter information for DR882
https://www.wallystech.com/Network_Card/DR882-Qualcomm-Atheros-QCA9882-2T2R-MIMO-802.11ac-Mini-PCIe-Wi-Fi-Module-5G-high-power.html
DR900VX
Qualcomm-Atheros QCA9880 chipset
2.4GHz max 26dBm & 5GHz max 25dBm output power
IEEE 802.11ac compliant & backward compatible with 802.11a/b/g/n
3x3 MIMO Technology, up to 1.3Gbps
Mini PCI Express edge connector
Supports Spatial Multiplexing, Cyclic-Delay Diversity (CDD), Low-Density Parity Check (LDPC) Codes, Maximal Ratio
Combining (MRC), Space Time Block Code (STBC)
Supports IEEE 802.11d, e, h, i, k, r, v time stamp, and w standards
Supports Dynamic Frequency Selection (DFS)
FCC,CE and IC Certification
Click below the link for more parameter information for DR900VX
https://www.wallystech.com/Network_Card/DR900VX-Qualcomm-Atheros-QCA9880-3T3R-MIMO-802.11ac-Mini-PCIe-Wi-Fi-Module-Dual-Band-2-4GHz-5GHz.html
DR600VX
2.4GHz max 24dBm & 5GHz max 23dBm output power
IEEE 802.11accompliant & backward compatible with 802.11a/b/g/n
2x2 MIMO Technology, up to 867Mbps
Support the Frequency 4920MHz~4980MHz
(LDPC) Codes, Maximal Ratio Combining (MRC), Space Time Block Code (STBC)
Click below the link for more parameter information for DR600VX
Wallys Communications(Suzhou) Co.,Ltd,known as a specialist in researching and developing and producing of wireless communication products,have star product as Routerboard,Network Card,Industrial Wireless AP,Antenna etc,is one of the suppliers of the Facebook.
With the professional R&D teams which possess over 15 years experience,we could not only providing OEM/ODM/JDM services,but also have the ability to supporting customization service for you.From idea design to manufacture to put the product into market.
Email us by sales1@wallystech.com
Visit our website:https://www.wallystech.com/
页: [1]
查看完整版本: QCA9880 QCA9882 Dual Band Network Card 802.11ac with FCC IC/Wallys
