Cindy@wallys 发表于 2022-12-7 16:33
Wallys/DR9074E-Qualcomm Atheros QCN9074(QCN9024)/ 4x4 MU-MIMO Dual Band Wireless Module
DR9074Ehttps://www.wallystech.com/Network_Card/DR9074E-Qualcomm-QCN9074-QCN9024-WiFi6-and-WiFi6E-4x4-MU-MIMO-Dual-Band-WiFi-Module-MiniPCIe.html Features■ Qualcomm Atheros QCN90X4■ Maxim Tx power 20dBm per chain■ Date Rateup to 4949Mbps■ Support5.180~5.825Ghz or 5.925GHz-7.125GHz or5.180GHz- 7.125GHz■ MiniPCIe connector■ PCI Express 3.0 Interface The wi-fi tuner for the QCN90X4 is designed for security surveillance, commercial radio coverage and some special scene application. It supports porter’s power measurement and IEEE 802.11g/n 5.x GHz output with maximum tx power of 20dBm per chain. The bandwidth rateup is up to 4949Mbps based on the selected interface test rate. This new model is a plus product at this season to meet the out growth and development needs on mobile communications in many countries around the world. Applications ■ Security Surveillance ■ Commercial radio coverage ■ Hotel Wireless application ■ Forest fire protection engineering ■ Country coverage ■ Some special scene application
Absolute Maximum Rating
ParameterRatingUnit
Operating Temperature Range-20 to 70ºC
Storage Temperature Range-40 to 90ºC
Operating Humidity Range5 to +95 (non-condensing)%
Storage Humidity Range0 to +90 (non-condensing)%
Hardware Specifications
SymbolParameter
ChipsetQualcomm Atheros QCN9074(QCN9024)
WLAN Host InterfacePCI Express 3.0 Interface
System Memory2Mbit serial I²C bus EEPROM
Standard Operating Voltage3.3V
Operating SystemsQSDK
Host InterfaceMiniPCIE
Antenna Cable / Port4 x MMCX Connectors,4T4R
Frequency Range5.180GHz-5.852GHz or 5.952GHz-7.125GHz
Data Rates for WALNMaxim TX power 20dBm per chain, up to 4949Mbps
Channel Spectrum Widths for WLANSupport 20/40/80/160MHz
Modulation TechniquesOFDMA: BPSK, QPSK, DBPSK, DQPSK,16-QAM, 64-QAM, 256-QAM,1024-QAM, 4096-QAM
Temperature RangeOperating: -20°C to 70°C, Storage: -40°C to 90°C
HumidityOperating: 5% to 95% (non-condensing), Storage: Max. 90% (non-condensing)
CertificationTBD
Power Consumption15W(Maximum),9.5W(Normally)
Dimensions (WxHxD)30mm x 50mm x 14.5mm
For more products please visit: https://www.wallystech.com/product.htmlFollow us in the Youtube: https://www.youtube.com/channel/UClmu7LBz_OWxe2VckkQr3twEmail: sales2@wallystech.com
页: [1]
查看完整版本: Wallys/DR9074E-Qualcomm Atheros QCN9074(QCN9024)/ 4x4 MU-MIMO Dual Band Wireless Module
