单片机低功耗的关键就是休眠,休眠的最高境界就是掉电模式
单片机低功耗的关键就是休眠,休眠的最高境界就是掉电模式/**************************************************************************//**
* @file main.c
* @versionV3.00
* $Revision: 2 $
* $Date: 16/10/25 4:29p $
* @brief Show how to wake up system from Power-down mode by GPIO interrupt.
* @note
* Copyright (C) 2016 Nuvoton Technology Corp. All rights reserved.
#include
#include "NUC029xGE.h"
#define PLLCTL_SETtiNGCLK_PLLCTL_72MHz_HXT
#define PLL_CLOCK 72000000
/*Function for System Entry to Power Down Mode */
void PowerDownFunction(void)
/* Check if all the debug messages are finished */
UART_WAIT_TX_EMPTY(UART0);
/* Enter to Power-down mode */
CLK_PowerDown();
* @brief PortA/PortB IRQ
* @param None
* @return None
* @Details The PortA/PortB default IRQ, declared in startup_NUC029xGE.s.
void GPAB_IRQHandler(void)
/* To check if PB.3 interrupt occurred */
if(GPIO_GET_INT_FLAG(PB, BIT3))
GPIO_CLR_INT_FLAG(PB, BIT3);
printf("PB.3 INT occurred.\n");
else
/* Un-expected interrupt. Just clear all PB interrupts */
PB->INTSRC = PB->INTSRC;
printf("Un-expected interrupts.\n");
void SYS_Init(void)
/* Init System Clock */
/* Enable HIRC clock (Internal RC 22.1184MHz) */
CLK_EnableXtalRC(CLK_PWRCTL_HIRCEN_Msk);
/* Wait for HIRC clock ready */
CLK_WaitClockReady(CLK_STATUS_HIRCSTB_Msk);
/* Select HCLK clock source as HIRC and HCLK source divider as 1 */
CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HIRC, CLK_CLKDIV0_HCLK(1));
/* Enable HXT clock (external XTAL 12MHz) */
CLK_EnableXtalRC(CLK_PWRCTL_HXTEN_Msk);
/* Wait for HXT clock ready */
CLK_WaitClockReady(CLK_STATUS_HXTSTB_Msk);
/* Set core clock as PLL_CLOCK from PLL */
CLK_SetCoreClock(PLL_CLOCK);
/* Enable UART module clock */
CLK_EnableModuleClock(UART0_MODULE);
/* Select UART module clock source as HXT and UART module clock divider as 1 */
CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UARTSEL_HXT, CLK_CLKDIV0_UART(1));
/* Init I/O Multi-function */
/* Set multi-function pins for UART0 RXD and TXD */
SYS->GPA_MFPL &= ~(SYS_GPA_MFPL_PA2MFP_Msk | SYS_GPA_MFPL_PA3MFP_Msk);
SYS->GPA_MFPL |= (SYS_GPA_MFPL_PA3MFP_UART0_RXD | SYS_GPA_MFPL_PA2MFP_UART0_TXD);
void UART0_Init()
/* Init UART */
/* Reset UART0 */
SYS_ResetModule(UART0_RST);
/* Configure UART0 and set UART0 baud rate */
UART_Open(UART0, 115200);
/* MAIN function */
int main(void)
/* Unlock protected registers */
SYS_UnlockReg();
/* Init System, peripheral clock and multi-function I/O */
SYS_Init();
/* Lock protected registers */
SYS_LockReg();
/* Init UART0 for printf */
UART0_Init();
printf("\n\nCPU @ %d Hz\n", SystemCoreClock);
printf("+-------------------------------------------------------+\n");
printf("| GPIO Power-Down and Wake-up by PB.3 Sample Code |\n");
printf("+-------------------------------------------------------+\n\n");
/* Configure PB.3 as Input mode and enable interrupt by rising edge trigger */
GPIO_SetMode(PB, BIT3, GPIO_MODE_INPUT);
GPIO_EnableInt(PB, 3, GPIO_INT_RISING);
NVIC_EnableIRQ(GPAB_IRQn);
/* Enable interrupt de-bounce function and select de-bounce sampling cycle time is 1024 clocks of LIRC clock */
GPIO_SET_DEBOUNCE_TIME(GPIO_DBCTL_DBCLKSRC_LIRC, GPIO_DBCTL_DBCLKSEL_1024);
GPIO_ENABLE_DEBOUNCE(PB, BIT3);
/* Unlock protected registers before entering Power-down mode */
SYS_UnlockReg();
/* Waiting for PB.3 rising-edge interrupt event */
printf("Enter to Power-Down ......\n");
PowerDownFunction();
printf("System waken-up done.\n\n");
while(1);
/*** (C) COPYRIGHT 2016 Nuvoton Technology Corp. ***/
页:
[1]
