STM32G030CBT6 485级联出现 Over Run error
最近使用STM32G030在做一个传感器的数据采集然后通过RS485传输将数据,单个测试一直没有问题,但是在级联的时候经常会有板子出现进入OVERRUN error 的中断里面,想请问各位大侠,在什么情况下会出现OVERRUN的错误,这种错误应该如何处理和避免呢?而且还有一个问题,就是我已经禁止了ID匹配的功能,但是还是会有ID匹配的终端产生,很是奇怪,具体的初始化代码如下:请各位大佬帮忙看看,是否有什么地方设置不对的?
void ModBus_USART_Init(BandRatenum Brd )
/* Enable the peripheral clock of GPIO Port */
LL_IOP_GRP1_EnableClock(LL_IOP_GRP1_PERIPH_GPIOA);
/* Configure Tx Pin as : Alternate function, High Speed, Push pull, Pull up */
LL_GPIO_SetPinMode(GPIOB, LL_GPIO_PIN_6, LL_GPIO_MODE_ALTERNATE);
LL_GPIO_SetAFPin_0_7(GPIOB, LL_GPIO_PIN_6, LL_GPIO_AF_0);
LL_GPIO_SetPinSpeed(GPIOB, LL_GPIO_PIN_6, LL_GPIO_SPEED_FREQ_HIGH);
LL_GPIO_SetPinOutputType(GPIOB, LL_GPIO_PIN_6, LL_GPIO_OUTPUT_PUSHPULL);
LL_GPIO_SetPinPull(GPIOB, LL_GPIO_PIN_6, LL_GPIO_PULL_UP);
/* Configure Rx Pin as : Alternate function, High Speed, Push pull, Pull up */
LL_GPIO_SetPinMode(GPIOB, LL_GPIO_PIN_7, LL_GPIO_MODE_ALTERNATE);
LL_GPIO_SetAFPin_0_7(GPIOB, LL_GPIO_PIN_7, LL_GPIO_AF_0);
LL_GPIO_SetPinSpeed(GPIOB, LL_GPIO_PIN_7, LL_GPIO_SPEED_FREQ_HIGH);
LL_GPIO_SetPinOutputType(GPIOB, LL_GPIO_PIN_7, LL_GPIO_OUTPUT_PUSHPULL);
LL_GPIO_SetPinPull(GPIOB, LL_GPIO_PIN_7, LL_GPIO_PULL_UP);
//--RS485_DE 引脚初始化---
LL_IOP_GRP1_EnableClock(LL_IOP_GRP1_PERIPH_GPIOB);
LL_GPIO_SetPinMode(GPIOB,LL_GPIO_PIN_4,LL_GPIO_MODE_OUTPUT);
LL_GPIO_SetPinOutputType(GPIOB,LL_GPIO_PIN_4,LL_GPIO_OUTPUT_PUSHPULL);
LL_GPIO_SetPinSpeed(GPIOB,LL_GPIO_PIN_4,LL_GPIO_SPEED_FREQ_VERY_HIGH);
LL_GPIO_SetPinPull(GPIOB,LL_GPIO_PIN_4,LL_GPIO_PULL_NO);
/* (2) NVIC Configuration for USART interrupts */
/*- Set priority for USARTx_IRQn */
/*- Enable USARTx_IRQn */
NVIC_SetPriority(USART1_IRQn, 1);
NVIC_EnableIRQ(USART1_IRQn);
/* (3) Enable USART peripheral clock and clock source ***********************/
LL_APB2_GRP1_EnableClock(LL_APB2_GRP1_PERIPH_USART1);
/* Set clock source */
LL_RCC_SetUSARTClockSource(LL_RCC_USART1_CLKSOURCE_PCLK1);
/* (4) Configure USART functional parameters ********************************/
/* Disable USART prior modifying configuration registers */
/* Note: Commented as corresponding to Reset value */
// LL_USART_Disable(USARTx_INSTANCE);
/* TX/RX direction */
LL_USART_SetTransferDirection(USART1, LL_USART_DIRECTION_TX_RX);
/* 8 data bit, 1 start bit, 1 stop bit, no parity */
LL_USART_ConfigCharacter(USART1, LL_USART_DATAWIDTH_8B, LL_USART_PARITY_NONE, LL_USART_STOPBITS_1);
/* No Hardware Flow control */
/* Reset value is LL_USART_HWCONTROL_NONE */
// LL_USART_SetHWFlowCtrl(USARTx_INSTANCE, LL_USART_HWCONTROL_NONE);
/* Oversampling by 16 */
/* Reset value is LL_USART_OVERSAMPLING_16 */
//LL_USART_SetOverSampling(USARTx_INSTANCE, LL_USART_OVERSAMPLING_16);
/* Set Baudrate to 115200 using APB frequency set to 56000000 Hz */
/* Frequency available for USART peripheral can also be calculated through LL RCC macro */
/* Ex :
Periphclk = LL_RCC_GetUSARTClockFreq(Instance); or LL_RCC_GetUARTClockFreq(Instance); depending on USART/UART instance
In this example, Peripheral Clock is expected to be equal to 56000000 Hz => equal to SystemCoreClock
LL_USART_SetBaudRate(USART1, SystemCoreClock, LL_USART_PRESCALER_DIV1, LL_USART_OVERSAMPLING_16, BandTable);
/* (5) Enable USART *********************************************************/
//--禁止ID匹配中断-Disable Character Match Interrupt
LL_USART_DisableIT_CM(USART1);
LL_USART_Enable(USART1);
/* Polling USART initialisation */
while((!(LL_USART_IsActiveFlag_TEACK(USART1))) || (!(LL_USART_IsActiveFlag_REACK(USART1))))
/* Enable RXNE and Error interrupts */
LL_USART_EnableIT_RXNE(USART1);
//LL_USART_EnableIT_ERROR(USART1);
//--设置为接收模式--
RS485_DE_RXD();
我看了一下参考手册,额没有介绍产生这个现象的原因。
485通信怎么还有这个错误 这个没有测试过。 这个overrun是什么? 目前已经解决了,由于在485 使用的时候,总线上如果出现不同的波特率的话,就会出现这个现象,
页:
[1]
