STM32F0 定时器中断 小白掉进的坑(FreeModbus)Timeout
1)STM32F0有多个定时器,对应多个IRQnTIM1_BRK_UP_TRG_COM_IRQn = 13, /*!< TIM1 Break, Update, Trigger and Commutation Interrupt */
TIM1_CC_IRQn = 14, /*!< TIM1 Capture Compare Interrupt */
TIM3_IRQn = 16, /*!< TIM3 global Interrupt */
TIM6_IRQn = 17, /*!< TIM6 global Interrupt */
TIM14_IRQn = 19, /*!< TIM14 global Interrupt */
TIM15_IRQn = 20, /*!< TIM15 global Interrupt */
TIM16_IRQn = 21, /*!< TIM16 global Interrupt */
TIM17_IRQn = 22, /*!< TIM17 global Interrupt */
2)通常每个IRQn对应一个zho中断函数
* @briefThis function handles TIM14 global interrupt request.
* @paramNone
* @retval None
void TIM14_IRQHandler(void)
HAL_TIM_IRQHandler(&Input_Handle);
} 中断函数里通常会调用HAL_TIM_IRQHandler(&Input_Handle);这个函数来区分是哪一种中断
* @briefThis function handles TIM interrupts requests.
* @paramhtim TIMhandle
* @retval None
void HAL_TIM_IRQHandler(TIM_HandleTypeDef *htim)
/* Capture compare 1 event */
if(__HAL_TIM_GET_FLAG(htim, TIM_FLAG_CC1) != RESET)
if(__HAL_TIM_GET_IT_SOURCE(htim, TIM_IT_CC1) !=RESET)
__HAL_TIM_CLEAR_IT(htim, TIM_IT_CC1);
htim->Channel = HAL_TIM_ACTIVE_CHANNEL_1;
/* Input capture event */
if((htim->Instance->CCMR1 & TIM_CCMR1_CC1S) != 0x00U)
HAL_TIM_IC_CaptureCallback(htim);
/* Output compare event */
else
HAL_TIM_OC_DelayElapsedCallback(htim);
HAL_TIM_PWM_PulseFinishedCallback(htim);
htim->Channel = HAL_TIM_ACTIVE_CHANNEL_CLEARED;
/* Capture compare 2 event */
if(__HAL_TIM_GET_FLAG(htim, TIM_FLAG_CC2) != RESET)
if(__HAL_TIM_GET_IT_SOURCE(htim, TIM_IT_CC2) !=RESET)
__HAL_TIM_CLEAR_IT(htim, TIM_IT_CC2);
htim->Channel = HAL_TIM_ACTIVE_CHANNEL_2;
if((htim->Instance->CCMR1 & TIM_CCMR1_CC2S) != 0x00U)
else
/* Capture compare 3 event */
if(__HAL_TIM_GET_FLAG(htim, TIM_FLAG_CC3) != RESET)
if(__HAL_TIM_GET_IT_SOURCE(htim, TIM_IT_CC3) !=RESET)
__HAL_TIM_CLEAR_IT(htim, TIM_IT_CC3);
htim->Channel = HAL_TIM_ACTIVE_CHANNEL_3;
if((htim->Instance->CCMR2 & TIM_CCMR2_CC3S) != 0x00U)
else
/* Capture compare 4 event */
if(__HAL_TIM_GET_FLAG(htim, TIM_FLAG_CC4) != RESET)
if(__HAL_TIM_GET_IT_SOURCE(htim, TIM_IT_CC4) !=RESET)
__HAL_TIM_CLEAR_IT(htim, TIM_IT_CC4);
htim->Channel = HAL_TIM_ACTIVE_CHANNEL_4;
if((htim->Instance->CCMR2 & TIM_CCMR2_CC4S) != 0x00U)
else
/* TIM Update event */
if(__HAL_TIM_GET_FLAG(htim, TIM_FLAG_UPDATE) != RESET)
if(__HAL_TIM_GET_IT_SOURCE(htim, TIM_IT_UPDATE) !=RESET)
__HAL_TIM_CLEAR_IT(htim, TIM_IT_UPDATE);
HAL_TIM_PeriodElapsedCallback(htim);
/* TIM Break input event */
if(__HAL_TIM_GET_FLAG(htim, TIM_FLAG_BREAK) != RESET)
if(__HAL_TIM_GET_IT_SOURCE(htim, TIM_IT_BREAK) !=RESET)
__HAL_TIM_CLEAR_IT(htim, TIM_IT_BREAK);
HAL_TIMEx_BreakCallback(htim);
/* TIM Trigger detection event */
if(__HAL_TIM_GET_FLAG(htim, TIM_FLAG_TRIGGER) != RESET)
if(__HAL_TIM_GET_IT_SOURCE(htim, TIM_IT_TRIGGER) !=RESET)
__HAL_TIM_CLEAR_IT(htim, TIM_IT_TRIGGER);
HAL_TIM_TriggerCallback(htim);
/* TIM commutation event */
if(__HAL_TIM_GET_FLAG(htim, TIM_FLAG_COM) != RESET)
if(__HAL_TIM_GET_IT_SOURCE(htim, TIM_IT_COM) !=RESET)
__HAL_TIM_CLEAR_IT(htim, TIM_FLAG_COM);
HAL_TIMEx_CommutationCallback(htim);
} 在这个函数里根据不同的中断,调用不同的回调函数,像最基本的计时中断,调用HAL_TIM_PeriodElapsedCallback(htim); 问题来了:当我的程序需要用多个di开始定时器时,而且有相同的中断。开始我以为可以在HAL_TIM_IRQHandler(&Input_Handle);后面写自己的处理代码
//其他处理代码
} 6)但是,在使用Freemodbus的时候FreeModbus用到的定时器在HAL_TIM_PeriodElapsedCallback(htim)中执行了TIMERExpiredISR();这个函数。 7)当我用到另一个别的定时器的的时候,因为我在HAL_TIM_PeriodElapsedCallback(htim)这个函数里没有区分是哪个定时器产生的中断,所以当其他定时器产生中断时也顺便执行了属于FreeModbus的这个TIMERExpiredISR();处理函数。 8)这样就导致了一个奇怪的xian现象:只有我一启动别的定时器。主机Modbus Poll的时候就会出现Timeout的情况。
在HAL_TIM_PeriodElapsedCallback(htim)中区分zh中断来源之后,问题就解决了。 9)ken坑啊,都怪对库的执行sh顺序不了解。
页:
[1]
