AD一启动采样就出错
我用STM32CUBEMX生成ADC和串口初始化代码,AD是软件启动。AD初始化代码如下:
static void MX_ADC1_Init(void)
/* USER CODE BEGIN ADC1_Init 0 */
/* USER CODE END ADC1_Init 0 */
ADC_ChannelConfTypeDef sConfig = {0};
/* USER CODE BEGIN ADC1_Init 1 */
/* USER CODE END ADC1_Init 1 */
/** Common config
hadc1.Instance = ADC1;
hadc1.Init.ClockPrescaler = ADC_CLOCK_ASYNC_DIV1;
hadc1.Init.Resolution = ADC_RESOLUTION_14B;
hadc1.Init.GainCompensation = 0;
hadc1.Init.ScanConvMode = ADC_SCAN_DISABLE;
hadc1.Init.EOCSelection = ADC_EOC_SINGLE_CONV;
hadc1.Init.LowPowerAutoWait = DISABLE;
hadc1.Init.ContinuousConvMode = DISABLE;
hadc1.Init.NbrOfConversion = 1;
hadc1.Init.DiscontinuousConvMode = DISABLE;
hadc1.Init.ExternalTrigConv = ADC_SOFTWARE_START;
hadc1.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
hadc1.Init.DMAContinuousRequests = DISABLE;
hadc1.Init.TriggerFrequencyMode = ADC_TRIGGER_FREQ_HIGH;
hadc1.Init.Overrun = ADC_OVR_DATA_OVERWRITTEN;
hadc1.Init.LeftBitShift = ADC_LEFTBITSHIFT_NONE;
hadc1.Init.ConversionDataManagement = ADC_CONVERSIONDATA_DR;
hadc1.Init.OversamplingMode = DISABLE;
if (HAL_ADC_Init(&hadc1) != HAL_OK)
Error_Handler();
/** Configure Regular Channel
sConfig.Channel = ADC_CHANNEL_9;
sConfig.Rank = ADC_REGULAR_RANK_1;
sConfig.SamplingTime = ADC_SAMPLETIME_5CYCLE;
sConfig.SingleDiff = ADC_SINGLE_ENDED;
sConfig.OffsetNumber = ADC_OFFSET_NONE;
sConfig.Offset = 0;
if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK)
Error_Handler();
/* USER CODE BEGIN ADC1_Init 2 */
/* USER CODE END ADC1_Init 2 */
}不启动ADC转换的时候,串口打印正常。
我一启动AD采样:
if (HAL_ADC_Start(&hadc1) != HAL_OK)
/* Error: ADC conversion start could not be performed */
HAL_UART_Transmit(&huart2, (uint8_t *)aTxBuffer1, TXBUFFERSIZE, 5000);
Error_Handler();
}就进入Error_Handler();
这是怎么回事呀?谢谢!
你把Error_Handler()函数写到ADC转换函数中,这是必然要执行这条语句啊。 天意无罪 发表于 2023-3-11 16:03
你没仔细看,失败了才执行那一条语句。 高手如云,学习了 仿真,看看进入error前是跑哪个函数,能快速定位 地瓜patch 发表于 2023-3-11 23:00
没有仿真工具。 从现象看,启动ADC时出错了。换言之,没法正常启动ADC.
检查下ADC的配置、供电等是否有问题。 ADC与串口初始化调一下顺序就好了 改成这样试试!
HAL_Delay(10);
} 专注于嵌入式 发表于 2023-3-13 10:52
ADC与串口初始化调一下顺序就好了
试过了,不好使 调整顺序不管用 把外设初始化顺序调整一下,会有惊喜 有没有中断?
没有累加溢出。没用中断。 看看有没有变量累加益处 调整一下中断优先级 调整外设初始化顺序 你把Error_Handler()函数写到ADC转换函数中,这是必然要执行这条语句啊。
你没仔细看,失败了才执行那一条语句。
高手如云,学习了
页:
[1]
