[STM32U5] AD一启动采样就出错
2652|32
 楼主| 比神乐 发表于 2023-3-11 14:45 | 显示全部楼层 |阅读模式
我用STM32CUBEMX生成ADC和串口初始化代码,AD是软件启动。
AD初始化代码如下:
  1. static void MX_ADC1_Init(void)
  3.   /* USER CODE BEGIN ADC1_Init 0 */
  4.   /* USER CODE END ADC1_Init 0 */
  5.   ADC_ChannelConfTypeDef sConfig = {0};
  6.   /* USER CODE BEGIN ADC1_Init 1 */
  7.   /* USER CODE END ADC1_Init 1 */
  8.   /** Common config
  9.   */
  10.   hadc1.Instance = ADC1;
  11.   hadc1.Init.ClockPrescaler = ADC_CLOCK_ASYNC_DIV1;
  12.   hadc1.Init.Resolution = ADC_RESOLUTION_14B;
  13.   hadc1.Init.GainCompensation = 0;
  14.   hadc1.Init.ScanConvMode = ADC_SCAN_DISABLE;
  15.   hadc1.Init.EOCSelection = ADC_EOC_SINGLE_CONV;
  16.   hadc1.Init.LowPowerAutoWait = DISABLE;
  17.   hadc1.Init.ContinuousConvMode = DISABLE;
  18.   hadc1.Init.NbrOfConversion = 1;
  19.   hadc1.Init.DiscontinuousConvMode = DISABLE;
  20.   hadc1.Init.ExternalTrigConv = ADC_SOFTWARE_START;
  21.   hadc1.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
  22.   hadc1.Init.DMAContinuousRequests = DISABLE;
  23.   hadc1.Init.TriggerFrequencyMode = ADC_TRIGGER_FREQ_HIGH;
  24.   hadc1.Init.Overrun = ADC_OVR_DATA_OVERWRITTEN;
  25.   hadc1.Init.LeftBitShift = ADC_LEFTBITSHIFT_NONE;
  26.   hadc1.Init.ConversionDataManagement = ADC_CONVERSIONDATA_DR;
  27.   hadc1.Init.OversamplingMode = DISABLE;
  28.   if (HAL_ADC_Init(&hadc1) != HAL_OK)
  29.   {
  30.     Error_Handler();
  31.   }
  32.   /** Configure Regular Channel
  33.   */
  34.   sConfig.Channel = ADC_CHANNEL_9;
  35.   sConfig.Rank = ADC_REGULAR_RANK_1;
  36.   sConfig.SamplingTime = ADC_SAMPLETIME_5CYCLE;
  37.   sConfig.SingleDiff = ADC_SINGLE_ENDED;
  38.   sConfig.OffsetNumber = ADC_OFFSET_NONE;
  39.   sConfig.Offset = 0;
  40.   if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK)
  41.   {
  42.     Error_Handler();
  43.   }
  44.   /* USER CODE BEGIN ADC1_Init 2 */
  45.   /* USER CODE END ADC1_Init 2 */
  46. }
不启动ADC转换的时候,串口打印正常。
我一启动AD采样:
  1. if (HAL_ADC_Start(&hadc1) != HAL_OK)
  2.         {
  3.                 /* Error: ADC conversion start could not be performed */
  4.                 HAL_UART_Transmit(&huart2, (uint8_t *)aTxBuffer1, TXBUFFERSIZE, 5000);
  5.                 Error_Handler();
  6.         }
就进入Error_Handler();
这是怎么回事呀?谢谢!
@地瓜patch :调整顺序不管用。  发表于 2023-3-13 18:50
@比神乐 :把外设初始化顺序调整一下,会有惊喜  发表于 2023-3-12 20:21
有没有中断?  发表于 2023-3-12 16:21
@地瓜patch :没有累加溢出。没用中断。  发表于 2023-3-12 08:52
哈哈,遇到过这个问题,1,看看有没有变量累加益处。2,调整一下中断优先级,3,调整外设初始化顺序  发表于 2023-3-11 22:56
天意无罪 发表于 2023-3-11 16:03 | 显示全部楼层
你把Error_Handler()函数写到ADC转换函数中,这是必然要执行这条语句啊。
 楼主| 比神乐 发表于 2023-3-11 20:04 | 显示全部楼层
你没仔细看,失败了才执行那一条语句。
kaventang 发表于 2023-3-11 22:27 | 显示全部楼层
高手如云,学习了
地瓜patch 发表于 2023-3-11 23:00 来自手机 | 显示全部楼层
仿真,看看进入error前是跑哪个函数,能快速定位
 楼主| 比神乐 发表于 2023-3-12 08:22 | 显示全部楼层
没有仿真工具。
香水城 发表于 2023-3-12 21:20 | 显示全部楼层
从现象看,启动ADC时出错了。换言之,没法正常启动ADC.
检查下ADC的配置、供电等是否有问题。
专注于嵌入式 发表于 2023-3-13 10:52 | 显示全部楼层
ADC与串口初始化调一下顺序就好了
GlenX 发表于 2023-3-13 15:33 | 显示全部楼层
改成这样试试!
            HAL_Delay(10);
 楼主| 比神乐 发表于 2023-3-13 18:50 | 显示全部楼层
ADC与串口初始化调一下顺序就好了
试过了,不好使
zhenykun 发表于 2023-7-12 22:09 | 显示全部楼层
调整顺序不管用
wyjie 发表于 2023-7-12 22:11 | 显示全部楼层
把外设初始化顺序调整一下,会有惊喜
jlyuan 发表于 2023-7-12 22:12 | 显示全部楼层
有没有中断?
yszong 发表于 2023-7-12 22:13 | 显示全部楼层
没有累加溢出。没用中断。
jiahy 发表于 2023-7-12 22:15 | 显示全部楼层
看看有没有变量累加益处
lizye 发表于 2023-7-12 22:16 | 显示全部楼层
调整一下中断优先级
shimx 发表于 2023-7-12 22:18 | 显示全部楼层
调整外设初始化顺序
jiaxw 发表于 2023-7-12 22:19 | 显示全部楼层
spark周 发表于 2023-7-12 22:20 | 显示全部楼层
你没仔细看,失败了才执行那一条语句。
liliang9554 发表于 2023-7-12 22:23 | 显示全部楼层
高手如云,学习了
