比神乐 发表于 2023-3-12 13:54
【NUCLEO-U575ZI-Q测评】红外+串口打印
我今天搞了一下红外,把PC10接到STM8开发板的红外腿上。
原理图:
STM32U5:
STM8:
主程序代码:
#include "main.h"
/* Private includes ----------------------------------------------------------*/
/* USER CODE BEGIN Includes */
/* USER CODE END Includes */
/* Private typedef -----------------------------------------------------------*/
/* USER CODE BEGIN PTD */
/* USER CODE END PTD */
/* Private define ------------------------------------------------------------*/
/* USER CODE BEGIN PD */
/* USER CODE END PD */
/* Private macro -------------------------------------------------------------*/
/* USER CODE BEGIN PM */
/* USER CODE END PM */
#define TXBUFFERSIZE                      (COUNTOF(aTxBuffer)+4)
uint8_t aTxBuffer[] = "Key value:0x      \r\n    ";
/* Private variables ---------------------------------------------------------*/
TIM_HandleTypeDef htim1;
UART_HandleTypeDef huart2;
u16 Interval_tim1=0;
uint8_t Data;
/* USER CODE BEGIN PV */
/* USER CODE END PV */
typedef void (* BSP_EXTI_LineCallback)(void);
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
static void SystemPower_Config(void);
static void MX_GPIO_Init(void);
static void MX_TIM1_Init(void);
static void MX_USART2_UART_Init(void);
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
static void MX_ICACHE_Init(void)
/* USER CODE BEGIN ICACHE_Init 0 */
/* USER CODE END ICACHE_Init 0 */
/* USER CODE BEGIN ICACHE_Init 1 */
/* USER CODE END ICACHE_Init 1 */
/** Enable instruction cache in 1-way (direct mapped cache)
if (HAL_ICACHE_ConfigAssociativityMode(ICACHE_1WAY) != HAL_OK)
    Error_Handler();
if (HAL_ICACHE_Enable() != HAL_OK)
    Error_Handler();
/* USER CODE BEGIN ICACHE_Init 2 */
/* USER CODE END ICACHE_Init 2 */
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
void HAL_GPIO_EXTI_Falling_Callback(uint16_t GPIO_Pin)
        if (GPIO_Pin == GPIO_PIN_10)
                VS838_Receive_Handle();
        //HAL_UART_Transmit(&huart2, (uint8_t *)aTxBuffer8, 5, 5000);
static void MX_GPIO_EXTI_Init(void)
GPIO_InitTypeDef GPIO_InitStruct = {0};
/* USER CODE BEGIN MX_GPIO_Init_1 */
/* USER CODE END MX_GPIO_Init_1 */
/* GPIO Ports Clock Enable */
__HAL_RCC_GPIOC_CLK_ENABLE();
/*Configure GPIO pin : PC10 */
GPIO_InitStruct.Pin = GPIO_PIN_10;
GPIO_InitStruct.Mode = GPIO_MODE_IT_FALLING;
GPIO_InitStruct.Pull = GPIO_PULLUP;
HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
/* EXTI interrupt init*/
HAL_NVIC_SetPriority(EXTI10_IRQn, 0, 0);
HAL_NVIC_EnableIRQ(EXTI10_IRQn);
/* USER CODE BEGIN MX_GPIO_Init_2 */
/* USER CODE END MX_GPIO_Init_2 */
void HAL_GPIO_EXTI_IRQHandler1(uint16_t GPIO_Pin)
/* EXTI line interrupt detected */
if (__HAL_GPIO_EXTI_GET_RISING_IT(GPIO_Pin) != 0U)
    __HAL_GPIO_EXTI_CLEAR_RISING_IT(GPIO_Pin);
    HAL_GPIO_EXTI_Rising_Callback(GPIO_Pin);
if (__HAL_GPIO_EXTI_GET_FALLING_IT(GPIO_Pin) != 0U)
    __HAL_GPIO_EXTI_CLEAR_FALLING_IT(GPIO_Pin);
    HAL_GPIO_EXTI_Falling_Callback(GPIO_Pin);
* @briefThe application entry point.
* @retval int
int main(void)
        u8 wan,qian,bai,shi,ge;
/* USER CODE BEGIN 1 */
/* USER CODE END 1 */
/* MCU Configuration--------------------------------------------------------*/
/* Reset of all peripherals, Initializes the Flash interface and the Systick. */
HAL_Init();
/* USER CODE BEGIN Init */
/* USER CODE END Init */
SystemClock_Config();
/* Configure the System Power */
SystemPower_Config();
/* USER CODE BEGIN SysInit */
        MX_ICACHE_Init();
/* USER CODE END SysInit */
MX_GPIO_Init();
        MX_GPIO_EXTI_Init();
MX_TIM1_Init();
MX_USART2_UART_Init();
/* USER CODE BEGIN 2 */
/* USER CODE END 2 */
/* Infinite loop */
HAL_TIM_Base_Start(&htim1);
while (1)
    /* USER CODE END WHILE */
                if( VS838_receive_ok == 1 ) //Ò»Ö¡ºìÍâÊý¾Ý½ÓÊÕÍê³É
      VS838_receive_ok=0;
                                aTxBuffer=(uint8_t)(VS838_Receive_Data>>28);
                                if(aTxBuffer>=0 && aTxBuffer<=9)
                                        aTxBuffer+=0x30;
                                else if(aTxBuffer>=10 && aTxBuffer<=15)
                                        aTxBuffer+=55;
                                aTxBuffer=(uint8_t)((VS838_Receive_Data>>24)&0x0f);
                                        aTxBuffer+=0x30;
                                        aTxBuffer+=55;
                                aTxBuffer=(uint8_t)((VS838_Receive_Data>>20)&0x0f);
                                        aTxBuffer+=0x30;
                                        aTxBuffer+=55;
                                aTxBuffer=(uint8_t)((VS838_Receive_Data>>16)&0x0f);
                                        aTxBuffer+=0x30;
                                        aTxBuffer+=55;
                                aTxBuffer=(uint8_t)((VS838_Receive_Data>>12)&0x0f);
                                        aTxBuffer+=0x30;
                                        aTxBuffer+=55;
                                aTxBuffer=(uint8_t)((VS838_Receive_Data>>8)&0x0f);
                                        aTxBuffer+=0x30;
                                        aTxBuffer+=55;
                                aTxBuffer=(uint8_t)((VS838_Receive_Data>>4)&0x0f);
                                        aTxBuffer+=0x30;
                                        aTxBuffer+=55;
                                aTxBuffer=(uint8_t)(VS838_Receive_Data&0x0f);
                                        aTxBuffer+=0x30;
                                        aTxBuffer+=55;
      if (HAL_UART_Transmit(&huart2, (uint8_t *)aTxBuffer, TXBUFFERSIZE, 5000) != HAL_OK)
                                        Error_Handler();
      VS838_Receive_Data=0;
    /* USER CODE BEGIN 3 */
/* USER CODE END 3 */
* @brief System Clock Configuration
* @retval None
RCC_OscInitTypeDef RCC_OscInitStruct = {0};
RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
/** Configure the main internal regulator output voltage
if (HAL_PWREx_ControlVoltageScaling(PWR_REGULATOR_VOLTAGE_SCALE4) != HAL_OK)
    Error_Handler();
/** Initializes the CPU, AHB and APB buses clocks
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_MSI;
RCC_OscInitStruct.MSIState = RCC_MSI_ON;
RCC_OscInitStruct.MSICalibrationValue = RCC_MSICALIBRATION_DEFAULT;
RCC_OscInitStruct.MSIClockRange = RCC_MSIRANGE_4;
RCC_OscInitStruct.PLL.PLLState = RCC_PLL_NONE;
if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    Error_Handler();
RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                              |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2
                              |RCC_CLOCKTYPE_PCLK3;
RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_MSI;
RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
RCC_ClkInitStruct.APB3CLKDivider = RCC_HCLK_DIV1;
if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_0) != HAL_OK)
    Error_Handler();
* @brief Power Configuration
* @retval None
HAL_PWREx_EnableVddIO2();
   * Disable the internal Pull-Up in Dead Battery pins of UCPD peripheral
HAL_PWREx_DisableUCPDDeadBattery();
   * Switch to SMPS regulator instead of LDO
if (HAL_PWREx_ConfigSupply(PWR_SMPS_SUPPLY) != HAL_OK)
    Error_Handler();
/* USER CODE BEGIN PWR */
/* USER CODE END PWR */
* @brief TIM1 Initialization Function
* @param None
* @retval None
/* USER CODE BEGIN TIM1_Init 0 */
/* USER CODE END TIM1_Init 0 */
TIM_ClockConfigTypeDef sClockSourceConfig = {0};
TIM_MasterConfigTypeDef sMasterConfig = {0};
/* USER CODE BEGIN TIM1_Init 1 */
/* USER CODE END TIM1_Init 1 */
htim1.Instance = TIM1;
htim1.Init.Prescaler = 3;
htim1.Init.CounterMode = TIM_COUNTERMODE_UP;
htim1.Init.Period = 60000;
htim1.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
htim1.Init.RepetitionCounter = 0;
htim1.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_DISABLE;
if (HAL_TIM_Base_Init(&htim1) != HAL_OK)
    Error_Handler();
sClockSourceConfig.ClockSource = TIM_CLOCKSOURCE_INTERNAL;
if (HAL_TIM_ConfigClockSource(&htim1, &sClockSourceConfig) != HAL_OK)
    Error_Handler();
sMasterConfig.MasterOutputTrigger = TIM_TRGO_RESET;
sMasterConfig.MasterOutputTrigger2 = TIM_TRGO2_RESET;
sMasterConfig.MasterSlaveMode = TIM_MASTERSLAVEMODE_DISABLE;
if (HAL_TIMEx_MasterConfigSynchronization(&htim1, &sMasterConfig) != HAL_OK)
    Error_Handler();
/* USER CODE BEGIN TIM1_Init 2 */
/* USER CODE END TIM1_Init 2 */
* @brief USART2 Initialization Function
* @param None
* @retval None
/* USER CODE BEGIN USART2_Init 0 */
/* USER CODE END USART2_Init 0 */
/* USER CODE BEGIN USART2_Init 1 */
/* USER CODE END USART2_Init 1 */
huart2.Instance = USART2;
huart2.Init.BaudRate = 115200;
huart2.Init.WordLength = UART_WORDLENGTH_8B;
huart2.Init.StopBits = UART_STOPBITS_1;
huart2.Init.Parity = UART_PARITY_NONE;
huart2.Init.Mode = UART_MODE_TX_RX;
huart2.Init.HwFlowCtl = UART_HWCONTROL_NONE;
huart2.Init.OverSampling = UART_OVERSAMPLING_16;
huart2.Init.OneBitSampling = UART_ONE_BIT_SAMPLE_DISABLE;
huart2.Init.ClockPrescaler = UART_PRESCALER_DIV1;
huart2.AdvancedInit.AdvFeatureInit = UART_ADVFEATURE_NO_INIT;
if (HAL_UART_Init(&huart2) != HAL_OK)
    Error_Handler();
if (HAL_UARTEx_SetTxFifoThreshold(&huart2, UART_TXFIFO_THRESHOLD_1_8) != HAL_OK)
    Error_Handler();
if (HAL_UARTEx_SetRxFifoThreshold(&huart2, UART_RXFIFO_THRESHOLD_1_8) != HAL_OK)
    Error_Handler();
if (HAL_UARTEx_DisableFifoMode(&huart2) != HAL_OK)
    Error_Handler();
/* USER CODE BEGIN USART2_Init 2 */
/* USER CODE END USART2_Init 2 */
* @brief GPIO Initialization Function
* @param None
* @retval None
__HAL_RCC_GPIOA_CLK_ENABLE();
__HAL_RCC_GPIOB_CLK_ENABLE();
        __HAL_RCC_GPIOF_CLK_ENABLE();
__HAL_RCC_GPIOG_CLK_ENABLE();
/*Configure GPIO pin Output Level */
/*Configure GPIO pin : USER_BUTTON_Pin */
GPIO_InitStruct.Pin = GPIO_PIN_7;
GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
GPIO_InitStruct.Pull = GPIO_NOPULL;
HAL_GPIO_Init(GPIOF, &GPIO_InitStruct);
/*Configure GPIO pin : VBUS_SENSE_Pin */
/*Configure GPIO pin : PB15 */
/*Configure GPIO pins : PA9 PA10 */
/* USER CODE BEGIN 4 */
/* USER CODE END 4 */
* @briefPeriod elapsed callback in non blocking mode
* @NOTE   This function is calledwhen TIM17 interrupt took place, inside
* HAL_TIM_IRQHandler(). It makes a direct call to HAL_IncTick() to increment
* a global variable "uwTick" used as application time base.
* @paramhtim : TIM handle
* @retval None
void HAL_TIM_PeriodElapsedCallback(TIM_HandleTypeDef *htim)
/* USER CODE BEGIN Callback 0 */
/* USER CODE END Callback 0 */
if (htim->Instance == TIM17) {
    HAL_IncTick();
/* USER CODE BEGIN Callback 1 */
/* USER CODE END Callback 1 */
* @briefThis function is executed in case of error occurrence.
* @retval None
void Error_Handler(void)
/* USER CODE BEGIN Error_Handler_Debug */
/* User can add his own implementation to report the HAL error return state */
__disable_irq();
while (1)
/* USER CODE END Error_Handler_Debug */
#ifdefUSE_FULL_ASSERT
* @briefReports the name of the source file and the source line number
*         where the assert_param error has occurred.
* @paramfile: pointer to the source file name
* @paramline: assert_param error line source number
* @retval None
void assert_failed(uint8_t *file, uint32_t line)
/* USER CODE BEGIN 6 */
/* User can add his own implementation to report the file name and line number,
   ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
/* USER CODE END 6 */
#endif /* USE_FULL_ASSERT */
vs838.c:
#include "main.h"
u8VS838_Status=0;            //ºìÍâ½ÓÊÕ´¦Àí״̬
u8VS838_Receive_Count=0;       //ºìÍâ½ÓÊÕÊý¾Ýλ¼ÆÊý
u32 VS838_Receive_Data=0;      //32λµÄºìÍâ½ÓÊÕÊý¾Ý
u8VS838_receive_ok=0;          //ºìÍâ½ÓÊÕÍê³É±êÖ¾
extern TIM_HandleTypeDef htim1;
extern UART_HandleTypeDef huart2;
            GPIO³õʼ»¯
void VS838_GPIO(void)
            ¶¨Ê±Æ÷³õʼ»¯
void TIM2_Config(void)//¶¨Ê±Æ÷³õʼ»¯
                        ºìÍâ½âÂë³õʼ»¯º¯Êý
void VS838_Init(void)//ºìÍâ½âÂë³õʼ»¯º¯Êý
VS838_GPIO();
TIM2_Config();
                        ºìÍâ½ÓÊÕÊý¾Ý´¦Àíº¯Êý
uint8_t VS838_Process(void)//ºìÍâ½ÓÊÕÊý¾Ý´¦Àíº¯
uint8_t VS838_num=0;               //×îÖÕ´¦ÀíºóµÄ¼üÖµ·µ»ØÖµ
uint8_t Address_H,Address_L;       //µØÖ·Âë,µØÖ··´Âë
uint8_t Data_H,Data_L;             //Êý¾ÝÂë,Êý¾Ý·´Âë
if(VS838_receive_ok==1)          //½ÓÊÕÍê³É
       Address_H=VS838_Receive_Data>>24;                //µÃµ½µØÖ·Âë
       Address_L=(VS838_Receive_Data>>16)&0xff;         //µÃµ½µØÖ··´Âë
       if((Address_H==(uint8_t)~Address_L))//¼ìÑéÒ£¿ØÊ¶±ðÂë(ID)¼°µØÖ·
            Data_H=VS838_Receive_Data>>8;            //µÃµ½Êý¾ÝÂë
            Data_L=VS838_Receive_Data;               //µÃµ½Êý¾Ý·´Âë
            if(Data_H==(uint8_t)~Data_L)               //½ÓÊÕÊý¾ÝÂëÕýÈ·
                  VS838_num=Data_H;                      //ÕýÈ·¼üÖµ
   returnVS838_num;      //·µ»Ø¼üÖµ
                        ºìÍâ½ÓÊÕÖжϴ¦Àíº¯Êý
void VS838_Receive_Handle(void)//ºìÍâ½ÓÊÕÖжϴ¦Àíº¯Êý
u16 Interval_tim=0;//Á½¸öϽµÑؼä¸ôʱ¼ä
switch(VS838_Status)
    case 0://µÚÒ»¸öϽµÑØ£¬¶¨Ê±Æ÷¿ªÊ¼¼ÆÊý
            VS838_Status=1;
            HAL_TIM_Base_Start(&htim1);                   //Enable TIM2
                           //¶¨Ê±Æ÷¼ÆÊýÖµÇåÁã
                                                TIM1->CNT=0;
            break;
    case 1://µÚ¶þ¸öϽµÑØ£¬¶¨Ê±Æ÷¹Ø±Õ£¬¶ÁÈ¡¶¨Ê±Æ÷¼ÆÊýÖµ
            HAL_TIM_Base_Stop(&htim1);
            Interval_tim=0;
            Interval_tim=TIM1->CNT;   //¶ÁÈ¡¶¨Ê±Æ÷¼ÆÊýÖµ
            TIM1->CNT = 0;                //¶¨Ê±Æ÷¼ÆÊýÖµÇåÁã
            if( (Interval_tim>=12500)&&(Interval_tim<=14500) )//ÅжÏÒýµ¼ÂëÊÇ·ñÕýÈ·9+4.5ms
                VS838_Status=2;                  //½øÈëÏÂһ״̬
            else                              //Òýµ¼Âë´íÎ󣬴ÓнÓÊÕ
                VS838_Status=0;
            break;
    case 2://¿ªÊ¼32λÊý¾ÝµÄ½ÓÊÕ
            Interval_tim=0;
            TIM1->CNT=0;
            if( (Interval_tim>=1000)&&(Interval_tim<=1300) )      //¼ä¸ô1.12ms ->0
                  VS838_Receive_Data=VS838_Receive_Data<<1;
                  VS838_Receive_Count++;
            else if( (Interval_tim>=2000)&&(Interval_tim<=2600) )   //¼ä¸ô2.25ms ->1
                  VS838_Receive_Data=VS838_Receive_Data|0x0001;
            else//²»ÊÇ0,1 ½ÓÊÕ´íÎ󣬴ÓнÓÊÕ
                  VS838_Status=0;
            //³¬³ö½ÓÊÕÊý¾ÝλÊý£¬½ÓÊÕÏÂÒ»¸ö
          while(VS838_Receive_Count==32)
                VS838_receive_ok=1;//ºìÍâ½ÓÊÕÍê³É
                VS838_Status=0;
                break;
            break;
    default :
                VS838_Status=0;
            break;
void VS838_Demo(void)//ºìÍâÊý¾Ý½ÓÊÕÊý¾Ý´¦ÀíÀý³Ì
      VS838_receive_ok=0;
中断函数:
void EXTI10_IRQHandler(void)
/* USER CODE BEGIN EXTI10_IRQn 0 */
/* USER CODE END EXTI10_IRQn 0 */
HAL_GPIO_EXTI_IRQHandler1(GPIO_PIN_10);
/* USER CODE BEGIN EXTI10_IRQn 1 */
/* USER CODE END EXTI10_IRQn 1 */
}效果图:
Henryko 发表于 2024-1-12 16:13
强光对红外有影响不?
比神乐 发表于 2024-9-21 17:16
红外是看不见的光,应该没影响吧?
页: [1]
查看完整版本: 【NUCLEO-U575ZI-Q测评】红外+串口打印
