[学习资料] C语言FFT
1877|19
 楼主| dspmana 发表于 2023-3-27 10:00 | 显示全部楼层 |阅读模式
  1. /************FFT***********/
  2. #include < stdio.h >
  3.     #include < math.h >
  4.     #include < stdlib.h >
  5.     #define N 1000
  6. typedef struct
  7. {
  8.     double real;
  9.     double img;
  10. }
  11. complex;
  12. void fft(); /*快速傅里叶变换*/
  13. void ifft(); /*快速傅里叶逆变换*/
  14. void initW();
  15. void change();
  16. void add(complex, complex, complex * ); /*复数加法*/
  17. void mul(complex, complex, complex * ); /*复数乘法*/
  18. void sub(complex, complex, complex * ); /*复数减法*/
  19. void divi(complex, complex, complex * ); /*复数除法*/
  20. void output(); /*输出结果*/
  21. complex x[N], * W; /*输出序列的值*/
  22. int size_x = 0; /*输入序列的长度,只限2的N次方*/
  23. double PI;
  24. int main()
  25. {
  26.     int i, method;
  27.     system("cls");
  28.     PI = atan(1) * 4;
  29.     printf("Please input the size of x:\n");
  30.     /*输入序列的长度*/
  31.     scanf("%d", & size_x);
  32.     printf("Please input the data in x[N]:(such as:5 6)\n");
  33.     /*输入序列对应的值*/
  34.     for (i = 0; i < size_x; i++)
  35.         scanf("%lf %lf", & x[i].real, & x[i].img);
  36.     initW();
  37.     /*选择FFT或逆FFT运算*/
  38.     printf("Use FFT(0) or IFFT(1)?\n");
  39.     scanf("%d", & method);
  40.     if (method == 0)
  41.         fft();
  42.     else
  43.         ifft();
  44.     output();
  45.     return 0;
  46. }
  47. /*进行基-2 FFT运算*/
  48. void fft()
  49. {
  50.     int i = 0, j = 0, k = 0, l = 0;
  51.     complex up, down, product;
  52.     change();
  53.     for (i = 0; i < log(size_x) / log(2); i++)
  54.     {
  55.         l = 1 << i;
  56.         for (j = 0; j < size_x; j += 2 * l)
  57.         {
  58.             for (k = 0; k < l; k++)
  59.             {
  60.                 mul(x[j + k + l], W[size_x * k / 2 / l], & product);
  61.                 add(x[j + k], product, & up);
  62.                 sub(x[j + k], product, & down);
  63.                 x[j + k] = up;
  64.                 x[j + k + l] = down;
  65.             }
  66.         }
  67.     }
  68. }
  69. void ifft()
  70. {
  71.     int i = 0, j = 0, k = 0, l = size_x;
  72.     complex up, down;
  73.     for (i = 0; i < (int)(log(size_x) / log(2)); i++) /*蝶形运算*/
  74.     {
  75.         l /= 2;
  76.         for (j = 0; j < size_x; j += 2 * l)
  77.         {
  78.             for (k = 0; k < l; k++)
  79.             {
  80.                 add(x[j + k], x[j + k + l], & up);
  81.                 up.real /= 2;
  82.                 up.img /= 2;
  83.                 sub(x[j + k], x[j + k + l], & down);
  84.                 down.real /= 2;
  85.                 down.img /= 2;
  86.                 divi(down, W[size_x * k / 2 / l], & down);
  87.                 x[j + k] = up;
  88.                 x[j + k + l] = down;
  89.             }
  90.         }
  91.     }
  92.     change();
  93. }
  94. void initW()
  95. {
  96.     int i;
  97.     W = (complex * ) malloc(sizeof(complex) * size_x);
  98.     for (i = 0; i < size_x; i++)
  99.     {
  100.         W[i].real = cos(2 * PI / size_x * i);
  101.         W[i].img = -1 * sin(2 * PI / size_x * i);
  102.     }
  103. }
  104. void change()
  105. {
  106.     complex temp;
  107.     unsigned short i = 0, j = 0, k = 0;
  108.     double t;
  109.     for (i = 0; i < size_x; i++)
  110.     {
  111.         k = i;
  112.         j = 0;
  113.         t = (log(size_x) / log(2));
  114.         while ((t--) > 0)
  115.         {
  116.             j = j << 1;
  117.             j |= (k & 1);
  118.             k = k >> 1;
  119.         }
  120.         if (j > i)
  121.         {
  122.             temp = x[i];
  123.             x[i] = x[j];
  124.             x[j] = temp;
  125.         }
  126.     }
  127. }
  128. void output() /*输出结果*/
  129. {
  130.     int i;
  131.     printf("The result are as follows\n");
  132.     for (i = 0; i < size_x; i++)
  133.     {
  134.         printf("%.4f", x[i].real);
  135.         if (x[i].img >= 0.0001)
  136.             printf("+%.4fj\n", x[i].img);
  137.         else if (fabs(x[i].img) < 0.0001)
  138.             printf("\n");
  139.         else
  140.             printf("%.4fj\n", x[i].img);
  141.     }
  142. }
  143. void add(complex a, complex b, complex * c)
  144. {
  145.     c - > real = a.real + b.real;
  146.     c - > img = a.img + b.img;
  147. }
  148. void mul(complex a, complex b, complex * c)
  149. {
  150.     c - > real = a.real * b.real - a.img * b.img;
  151.     c - > img = a.real * b.img + a.img * b.real;
  152. }
  153. void sub(complex a, complex b, complex * c)
  154. {
  155.     c - > real = a.real - b.real;
  156.     c - > img = a.img - b.img;
  157. }
  158. void divi(complex a, complex b, complex * c)
  159. {
  160.     c - > real = (a.real * b.real + a.img * b.img) / (
  161.         b.real * b.real + b.img * b.img);
  162.     c - > img = (a.img * b.real - a.real * b.img) / (b.real * b.real + b.img * b.img);
  163. }
wowu 发表于 2023-4-13 17:31 | 显示全部楼层
FFT(Fast Fourier Transformation),即为快速傅氏变换,是离散傅氏变换的快速算法,它是根据离散傅氏变换的奇、偶、虚、实等特性,对离散傅立叶变换的算法进行改进获得的
tpgf 发表于 2023-4-14 09:20 | 显示全部楼层
想要看懂这个代码 就得懂傅里叶变换 就得明白复数是什么
xiaoqizi 发表于 2023-4-14 11:10 | 显示全部楼层
在这个过程中我们如何解决复数运算的问题呢
木木guainv 发表于 2023-4-14 11:30 | 显示全部楼层
FFT算法是把长序列的DFT逐次分解为较短序列的DFT
磨砂 发表于 2023-4-14 12:04 | 显示全部楼层
FFT即为快速傅里叶变换,是离散傅里叶变换的快速算法,它是根据离散傅里叶变换的奇、偶、虚、实等特性,对离散傅里叶变换的算法进行改进获得的
晓伍 发表于 2023-4-14 12:19 | 显示全部楼层
FFT算法按照抽取方式的不同可分为DIT-FFT(按时间抽取)和DIF-FFT(按频率抽取)算法
abotomson 发表于 2023-5-11 15:25 | 显示全部楼层
二维FFT相当于对行和列分别进行一维FFT运算?
mickit 发表于 2023-5-11 16:21 | 显示全部楼层
MATLAB和Python等科学计算工具中都包括了FFT相关的库函数
jimmhu 发表于 2023-5-11 16:52 | 显示全部楼层
如何用C语言或汇编语言实现FFT(快速傅里叶)变换,
lihuami 发表于 2023-5-11 17:39 | 显示全部楼层
实现FFT需要了解FFT算法原理,以及掌握C语言的相关编程技巧。
sdCAD 发表于 2023-5-11 18:57 | 显示全部楼层
C语言中有一些现成的FFT库函数,例如FFTW、PFFFT等。使用这些库函数可以更方便地实现FFT操作,而且通常具有较高的精度和效率。
averyleigh 发表于 2023-5-11 19:18 | 显示全部楼层
如果想要深入学习FFT算法或者需要对FFT算法进行优化,则可以手动编写FFT代码。FFT算法包括Cooley-Tukey算法、Radix-2算法等,可以根据具体情况进行选择
kkzz 发表于 2023-5-11 19:35 | 显示全部楼层
用C语言实现FFT算法,还要做频谱分析
fengm 发表于 2023-5-11 20:41 | 显示全部楼层
想用C语言实现一个1024点的FFT
jimmhu 发表于 2023-5-11 20:53 | 显示全部楼层
傅里叶变换用C语言程序怎么实现?
youtome 发表于 2023-5-11 21:03 | 显示全部楼层
FFT的最优算法是什么?
qiufengsd 发表于 2023-5-11 22:05 | 显示全部楼层
使用现成的库函数,可以快速实现FFT操作。
理想阳 发表于 2023-8-10 09:37 | 显示全部楼层
要实现FFT需要了解FFT算法的原理,并掌握c语言的编程技巧。
LinkMe 发表于 2023-8-10 09:49 | 显示全部楼层
二维FFT分别相当于一维FFT的行和列计算?
