STM32L4R5ZIT6U驱动PCF8591产生锯齿波
一开始想用硬件I2C,用STM32CubeMX生成的工程,出不来波形。仿真了一下,确实不对,而且HAL库比较繁琐,不好查问题。
于是改为模拟时序。
SDA接PF1,SCL接PF2。
代码:
#include "main.h"
#define uchar unsigned char
/* Private includes ----------------------------------------------------------*/
/* USER CODE BEGIN Includes */
#define SDA_0HAL_GPIO_WritePin(GPIOF,GPIO_PIN_1,GPIO_PIN_RESET)
#define SDA_1HAL_GPIO_WritePin(GPIOF,GPIO_PIN_1,GPIO_PIN_SET)
#define SCL_0HAL_GPIO_WritePin(GPIOF,GPIO_PIN_2,GPIO_PIN_RESET)
#define SCL_1HAL_GPIO_WritePin(GPIOF,GPIO_PIN_2,GPIO_PIN_SET)
#define SDA HAL_GPIO_ReadPin(GPIOF,GPIO_PIN_1)
/* USER CODE END Includes */
#definePCF8591 0x90 //PCF8591 地址
/* Private typedef -----------------------------------------------------------*/
/* USER CODE BEGIN PTD */
/* USER CODE END PTD */
/* Private define ------------------------------------------------------------*/
/* USER CODE BEGIN PD */
/* USER CODE END PD */
/* Private macro -------------------------------------------------------------*/
/* USER CODE BEGIN PM */
/* USER CODE END PM */
/* Private variables ---------------------------------------------------------*/
TIM_HandleTypeDef htim1;
uchar ack;
/* USER CODE BEGIN PV */
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
void MX_GPIO_Init(void);
void MX_TIM1_Init(void);
void delay_us(uchar x)
uchar i,j;
for(i=0;i<x;i++)
for(j=0;j<8;j++);
/* USER CODE BEGIN PFP */
static void SDA_OUTPUT_Init(void)
GPIO_InitTypeDef GPIO_InitStruct = {0};
/* USER CODE BEGIN MX_GPIO_Init_1 */
/* USER CODE END MX_GPIO_Init_1 */
/* GPIO Ports Clock Enable */
__HAL_RCC_GPIOF_CLK_ENABLE();
/*Configure GPIO pin Output Level */
/*Configure GPIO pins : PF0 PF1 */
GPIO_InitStruct.Pin = GPIO_PIN_1;
GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_OD;
GPIO_InitStruct.Pull = GPIO_NOPULL;
GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
HAL_GPIO_Init(GPIOF, &GPIO_InitStruct);
/* USER CODE BEGIN MX_GPIO_Init_2 */
/* USER CODE END MX_GPIO_Init_2 */
/* USER CODE END PFP */
static void SDA_INPUT_Init(void)
GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 */
起动总线函数
函数原型: voidStart_I2c();
功能: 启动I2C总线,即发送I2C起始条件.
void Start_I2c()
SDA_OUTPUT_Init();
delay_us(1);
SDA_1; /*发送起始条件的数据信号*/
delay_us(1);
SCL_1;
delay_us(5);
SDA_0; /*发送起始信号*/
delay_us(5);
SCL_0; /*钳住I2C总线,准备发送或接收数据 */
delay_us(2);
结束总线函数
函数原型: voidStop_I2c();
功能: 结束I2C总线,即发送I2C结束条件.
void Stop_I2c()
SDA_OUTPUT_Init();
delay_us(1);
SDA_0; /*发送结束条件的数据信号*/
delay_us(1); /*发送结束条件的时钟信号*/
SCL_1; /*结束条件建立时间大于4μs*/
delay_us(5);
SDA_1; /*发送I2C总线结束信号*/
delay_us(4);
字节数据发送函数
函数原型: voidSendByte(UCHAR c);
功能: 将数据c发送出去,可以是地址,也可以是数据,发完后等待应答,并对
此状态位进行操作.(不应答或非应答都使ack=0)
发送数据正常,ack=1; ack=0表示被控器无应答或损坏。
voidSendByte(unsigned charc)
unsigned charBitCnt;
SDA_OUTPUT_Init();
delay_us(1);
for(BitCnt=0;BitCnt<8;BitCnt++)/*要传送的数据长度为8位*/
if((c<<BitCnt)&0x80)SDA_1; /*判断发送位*/
elseSDA_0;
delay_us(1);
SCL_1; /*置时钟线为高,通知被控器开始接收数据位*/
delay_us(5);
SCL_0;
delay_us(2);
SDA_1; /*8位发送完后释放数据线,准备接收应答位*/
delay_us(2);
SCL_1;
delay_us(3);
SDA_INPUT_Init();
delay_us(1);
if(SDA==1)ack=0;
else ack=1; /*判断是否接收到应答信号*/
SCL_0;
delay_us(2);
字节数据接收函数
函数原型: UCHARRcvByte();
功能: 用来接收从器件传来的数据,并判断总线错误(不发应答信号),
发完后请用应答函数应答从机。
unsigned char RcvByte()
unsigned charretc;
SDA_OUTPUT_Init();
delay_us(1);
retc=0;
SDA_1; /*置数据线为输入方式*/
delay_us(1);
SCL_0; /*置时钟线为低,准备接收数据位*/
delay_us(5);
SCL_1; /*置时钟线为高使数据线上数据有效*/
delay_us(2);
retc=retc<<1;
SDA_INPUT_Init();
delay_us(1);
if(SDA==1)retc=retc+1;/*读数据位,接收的数据位放入retc中 */
delay_us(2);
SCL_0;
delay_us(2);
return(retc);
应答子函数
函数原型:void Ack_I2c(bit a);
功能: 主控器进行应答信号(可以是应答或非应答信号,由位参数a决定)
void Ack_I2c(uchar a)
if(a==0)SDA_0; /*在此发出应答或非应答信号 */
else SDA_1;
delay_us(3);
SCL_1;
delay_us(5);
SCL_0; /*清时钟线,钳住I2C总线以便继续接收*/
delay_us(2);
DAC 变换, 转化函数
uchar DACconversion(unsigned char sla,unsigned char c,unsigned char Val)
Start_I2c(); //启动总线
SendByte(sla); //发送器件地址
if(ack==0)return(0);
SendByte(c); //发送控制字节
SendByte(Val); //发送DAC的数值
Stop_I2c(); //结束总线
return(1);
/* USER CODE END 0 */
* @briefThe application entry point.
* @retval int
int main(void)
/* USER CODE BEGIN 1 */
uchar data=0;
/* USER CODE END 1 */
/* MCU Configuration--------------------------------------------------------*/
/* Reset of all peripherals, Initializes the Flash interface and the Systick. */
HAL_Init();
/* USER CODE BEGIN Init */
/* USER CODE END Init */
SystemClock_Config();
/* USER CODE BEGIN SysInit */
/* USER CODE END SysInit */
MX_GPIO_Init();
/* USER CODE BEGIN 2 */
/* USER CODE END 2 */
/* Infinite loop */
/* USER CODE BEGIN WHILE */
while (1)
/* USER CODE END WHILE */
DACconversion(PCF8591,0x40, data); //DAC 数模转换
data++;
HAL_Delay(1);
/* USER CODE BEGIN 3 */
/* USER CODE END 3 */
* @brief System Clock Configuration
* @retval None
RCC_OscInitTypeDef RCC_OscInitStruct = {0};
RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
/** Configure the main internal regulator output voltage
if (HAL_PWREx_ControlVoltageScaling(PWR_REGULATOR_VOLTAGE_SCALE1) != HAL_OK)
Error_Handler();
/** Initializes the RCC Oscillators according to the specified parameters
* in the RCC_OscInitTypeDef structure.
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_MSI;
RCC_OscInitStruct.MSIState = RCC_MSI_ON;
RCC_OscInitStruct.MSICalibrationValue = 0;
RCC_OscInitStruct.MSIClockRange = RCC_MSIRANGE_6;
RCC_OscInitStruct.PLL.PLLState = RCC_PLL_NONE;
if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
Error_Handler();
/** Initializes the CPU, AHB and APB buses clocks
RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
|RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_MSI;
RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_0) != HAL_OK)
Error_Handler();
* @brief GPIO Initialization Function
* @param None
* @retval None
static void MX_GPIO_Init(void)
HAL_GPIO_WritePin(GPIOF, GPIO_PIN_2|GPIO_PIN_1, GPIO_PIN_RESET);
GPIO_InitStruct.Pin = GPIO_PIN_2|GPIO_PIN_1;
/* USER CODE BEGIN 4 */
/* USER CODE END 4 */
* @briefThis function is executed in case of error occurrence.
* @retval None
void Error_Handler(void)
/* USER CODE BEGIN Error_Handler_Debug */
/* User can add his own implementation to report the HAL error return state */
__disable_irq();
while (1)
/* USER CODE END Error_Handler_Debug */
#ifdefUSE_FULL_ASSERT
* @briefReports the name of the source file and the source line number
* where the assert_param error has occurred.
* @paramfile: pointer to the source file name
* @paramline: assert_param error line source number
* @retval None
void assert_failed(uint8_t *file, uint32_t line)
/* USER CODE BEGIN 6 */
/* User can add his own implementation to report the file name and line number,
ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
/* USER CODE END 6 */
#endif /* USE_FULL_ASSERT */
效果图:
页:
[1]
