jinglixixi 发表于 2023-8-6 18:29
【HC32L196PCTA测评】+RTC电子时钟篇
在HC32L196片内,配置有RTC计时器,通过例程可了解其用法。通过函数RTC_Cfg()可进行计时值的校正,其内容为:void RTC_Cfg(void)
    stc_rtc_initstruct_t RtcInitStruct;
    RtcInitStruct.rtcAmpm = RtcPm;         //12小时制
    RtcInitStruct.rtcClksrc = RtcClkRcl;         //内部低速时钟
    RtcInitStruct.rtcPrdsel.rtcPrdsel = RtcPrds;   //周期中断类型PRDS
    RtcInitStruct.rtcPrdsel.rtcPrds = Rtc1S;      //周期中断事件间隔
    RtcInitStruct.rtcTime.u8Second = 0x55;
    RtcInitStruct.rtcTime.u8Minute = 0x01;
    RtcInitStruct.rtcTime.u8Hour   = 0x10;
    RtcInitStruct.rtcTime.u8Day    = 0x17;
    RtcInitStruct.rtcTime.u8DayOfWeek = 0x04;
    RtcInitStruct.rtcTime.u8Month= 0x04;
    RtcInitStruct.rtcTime.u8Year   = 0x19;
    RtcInitStruct.rtcCompen = RtcCompenEnable;
    RtcInitStruct.rtcCompValue = 0;//补偿值根据实际情况进行补偿
    Rtc_Init(&RtcInitStruct);
    Rtc_AlmIeCmd(TRUE);            //使能闹钟中断
此外,通过中断函数Rtc_IRQHandler()可实现秒计时的标志处理,其内容为:void Rtc_IRQHandler(void)
    if(Rtc_GetPridItStatus() == TRUE)
      flag = 1;
      Rtc_ClearPrdfItStatus();             //清除中断标志位
依托上面2个函数及LCD屏显示函数,可快速地实现电子时钟的功能,其主程序为:int32_t main(void)
    int8_t i=0;
    stc_rtc_time_t readtime;
    Sysctrl_SetPeripheralGate(SysctrlPeripheralGpio,TRUE);//GPIO外设时钟打开
    Sysctrl_SetPeripheralGate(SysctrlPeripheralRtc,TRUE);//RTC模块时钟打开
    Sysctrl_ClkSourceEnable(SysctrlClkRCL, TRUE);
    RTC_Cfg();                                       //配置RTC
    EnableNvic(RTC_IRQn, IrqLevel3, TRUE);               //使能RTC中断向量
    Rtc_Cmd(TRUE);
    //使能RTC开始计数
    Sysctrl_ClkSourceEnable(SysctrlClkRCL,TRUE);            ///< 使能RCL时钟
    Sysctrl_SetRCLTrim(SysctrlRclFreq32768);                ///< 配置内部低速时钟频率为32.768kHz
    Sysctrl_SetPeripheralGate(SysctrlPeripheralLcd,TRUE);      ///< 开启LCD时钟
    Sysctrl_SetPeripheralGate(SysctrlPeripheralGpio,TRUE);   ///< 开启GPIO时钟
    App_PortCfg();               ///< LCD端口配置
    App_LcdCfg();                ///< LCD模块配置
    Lcd_ClearDisp();            ///< 清屏
    Lcd_WriteRam(0,0x00000000);///< 赋值寄存器LCDRAM0
    Lcd_WriteRam(1,0x00000000);///< 赋值寄存器LCDRAM1
    while (1)
      if(flag == 1)
            flag = 0;
            Rtc_ReadDateTime(&readtime);
            second = readtime.u8Second;
            minute = readtime.u8Minute;
            hour   = readtime.u8Hour;
            day    = readtime.u8Day;
            week   = readtime.u8DayOfWeek;
            month= readtime.u8Month;
            year   = readtime.u8Year;
            s=((d[(minute&0x0f)]+0x08)<<16)+d;
            Lcd_WriteRam(0,s);
            s=(d[(second&0x0f)]<<16)+d;
            Lcd_WriteRam(1,s);
经程序的编译与下载,其显示效果如下图所示。RTC计时效果图
https://www.bilibili.com/video/BV1K44y1A7Gi/?vd_source=f302fc0cc3a0425328db53a3b92082ca
tpgf 发表于 2024-4-2 15:08
是否还需要对温漂进行单独的校正呢
xiaoqizi 发表于 2024-4-2 15:53
电路板上需要配电池吗 要不然断电了就没法正常计时了
wowu 发表于 2024-4-2 21:42
这个电子时钟的精度能达到多少啊
wakayi 发表于 2024-4-2 22:14
这个开发板的屏幕是使用的串口屏吗
renzheshengui 发表于 2024-4-2 22:46
都可以通过哪些方式对时钟进行校正呢?
paotangsan 发表于 2024-4-2 23:18
通过函数进行校正的时候的时钟源选用的是哪个啊
xdvca 发表于 2024-7-31 22:34
您的代码基本上完成了 RTC 的配置和 LCD 显示功能。主要需要注意以下几点:
确保 RTC 和 LCD 配置的相关寄存器和参数符合芯片手册的要求。
处理和配置中断时要确保中断服务程序(ISR)正确。
Lcd_WriteRam() 函数用于将数据写入 LCD,确保这部分与您的 LCD 硬件配置一致。
页: [1]
查看完整版本: 【HC32L196PCTA测评】+RTC电子时钟篇
