构造GNUARM 出错了,知道的仁兄帮忙解决一下
第一步构造binutils 时出错了: <br />显示如下 <br />loading cache ./config.cache<br />checking host system type... i686-pc-cygwin<br />checking target system type... arm-unknown-elf<br />checking build system type... i686-pc-cygwin<br />checking for a BSD compatible install... /usr/bin/install -c<br />checking whether ln works... yes<br />checking whether ln -s works... yes<br />checking for gcc... gcc<br />checking whether the C compiler (gcc ) works... no<br />conifgure:error:installation or configuration problem:c compiler cannot executables<br /><br />cygwin 我选的完全安装,肯定装了GCC的,怎么还会报错了,<br /><br />config.log信息<br />This file contains any messages produced by compilers while<br />running configure, to aid debugging if configure makes a mistake.<br /><br />configure:595: checking host system type<br />configure:616: checking target system type<br />configure:634: checking build system type<br />configure:689: checking for a BSD compatible install<br />configure:742: checking whether ln works<br />configure:766: checking whether ln -s works<br />configure:1809: checking for gcc<br />configure:1922: checking whether the C compiler (gcc ) works<br />configure:1938: gcc -o conftest conftest.c 1>&5<br />configure: failed program was:<br /><br />#line 1933 "configure"<br />#include "confdefs.h"<br /><br />main(){return(0);}《ecos增值包》里有现成的GNU for ARM环境,
还有汇编、C/C++、混合编程范例程序以及详细的cygwin安装使用方法。<br /><br /><b>更多内容,详见:</b><br /><b>《培训系列“丛书”》</b><br /><b>www.armecos.com</b><br />-----------------------------------<br /><b>More details, see:</b><br /><b>《"Series Books" of Training》</b><br /><b>www.armecos.com</b>
页:
[1]
