tlled 发表于 2023-10-26 17:36
【AT-START-F423测评】+移植freertos
将freertos系统移植到STM32F423开发板。
一、下载源码
freertos源码下载地址:https://github.com/FreeRTOS/FreeRTOS
二、添加文件
将freertos源文件复制到项目文件夹
在项目工程中添加源文件
添加头文件路径
修改FreeRTOSConfig.h文件
三、程序
main.c
#include "at32f423_board.h"
#include "at32f423_clock.h"
#include "led/led.h"
#include "key/key.h"
#include "usart/usart.h"
#include "delay/delay.h"
#include "systick/systick.h"
#include "FreeRTOS.h"
#include "task.h"
#define START_TASK_PRIO      1
#define START_STK_SIZE128
static TaskHandle_t            StartTask_Handler = NULL;
#define TASK1_PRIO      2
#define TASK1_STK_SIZE128
static TaskHandle_t            Task1Task_Handler = NULL;
#define TASK2_PRIO      3
#define TASK2_STK_SIZE128
static TaskHandle_t            Task2Task_Handler = NULL;
void start_task(void *pvParameters);
void task1(void *pvParameters);
void task2(void *pvParameters);
int main(void)
      system_clock_config();
      SysTick_Init();
      init_led();
      init_key();
      init_usart(115200);
      printf("at32f423 board test! \r\n");
      xTaskCreate((TaskFunction_t )start_task,
                                                      (const char*    )"start_task",
                                                      (uint16_t       )START_STK_SIZE,
                                                      (void*          )NULL,
                                                      (UBaseType_t    )START_TASK_PRIO,
                                                      (TaskHandle_t*)&StartTask_Handler);
      vTaskStartScheduler();
      return 0;
      taskENTER_CRITICAL();
      xTaskCreate((TaskFunction_t )task1,
                                                      (const char*    )"task1",
                                                      (uint16_t       )TASK1_STK_SIZE,
                                                      (void*          )NULL,
                                                      (UBaseType_t    )TASK1_PRIO,
                                                      (TaskHandle_t*)&Task1Task_Handler);
      xTaskCreate((TaskFunction_t )task2,
                                                      (const char*    )"task2",
                                                      (uint16_t       )TASK2_STK_SIZE,
                                                      (void*          )NULL,
                                                      (UBaseType_t    )TASK2_PRIO,
                                                      (TaskHandle_t*)&Task2Task_Handler);
      vTaskDelete(StartTask_Handler);
      taskEXIT_CRITICAL();
//task1
    while (1)
      printf("task1 run ...\r\n");
      led2_tog();
      vTaskDelay(500);
//task2
    while (1)
                              led3_tog();
      printf("task2 run ...\r\n");
      vTaskDelay(100);
四、程序运行
开发板运行后,串口输出
页: [1]
查看完整版本: 【AT-START-F423测评】+移植freertos
