[活动专区] 【AT-START-F423测评】+移植freertos
1768|0
 楼主| tlled 发表于 2023-10-26 17:36 | 显示全部楼层 |阅读模式
将freertos系统移植到STM32F423开发板。
一、下载源码
freertos源码下载地址:https://github.com/FreeRTOS/FreeRTOS
二、添加文件
将freertos源文件复制到项目文件夹
在项目工程中添加源文件
添加头文件路径
修改FreeRTOSConfig.h文件
三、程序
main.c
  1. #include "at32f423_board.h"
  2. #include "at32f423_clock.h"
  3. #include "led/led.h"
  4. #include "key/key.h"
  5. #include "usart/usart.h"
  6. #include "delay/delay.h"
  7. #include "systick/systick.h"
  8. #include "FreeRTOS.h"
  9. #include "task.h"
  10. #define START_TASK_PRIO      1
  11. #define START_STK_SIZE  128
  12. static TaskHandle_t            StartTask_Handler = NULL;
  13. #define TASK1_PRIO      2
  14. #define TASK1_STK_SIZE  128
  15. static TaskHandle_t            Task1Task_Handler = NULL;
  16.
  17. #define TASK2_PRIO      3
  18. #define TASK2_STK_SIZE  128
  19. static TaskHandle_t            Task2Task_Handler = NULL;
  20. void start_task(void *pvParameters);
  21. void task1(void *pvParameters);
  22. void task2(void *pvParameters);
  23. int main(void)
  24. {
  25.         system_clock_config();
  26.         SysTick_Init();
  27.         init_led();
  28.         init_key();
  29.         init_usart(115200);
  30.         printf("at32f423 board test! \r\n");
  31.
  32.         xTaskCreate((TaskFunction_t )start_task,
  33.                                                         (const char*    )"start_task",
  34.                                                         (uint16_t       )START_STK_SIZE,
  35.                                                         (void*          )NULL,
  36.                                                         (UBaseType_t    )START_TASK_PRIO,
  37.                                                         (TaskHandle_t*  )&StartTask_Handler);
  38.         vTaskStartScheduler();
  39.         return 0;
  40. }
  41. void start_task(void *pvParameters)
  42. {
  43.         taskENTER_CRITICAL();
  44.         xTaskCreate((TaskFunction_t )task1,
  45.                                                         (const char*    )"task1",
  46.                                                         (uint16_t       )TASK1_STK_SIZE,
  47.                                                         (void*          )NULL,
  48.                                                         (UBaseType_t    )TASK1_PRIO,
  49.                                                         (TaskHandle_t*  )&Task1Task_Handler);
  50.         xTaskCreate((TaskFunction_t )task2,
  51.                                                         (const char*    )"task2",
  52.                                                         (uint16_t       )TASK2_STK_SIZE,
  53.                                                         (void*          )NULL,
  54.                                                         (UBaseType_t    )TASK2_PRIO,
  55.                                                         (TaskHandle_t*  )&Task2Task_Handler);
  56.
  57.         vTaskDelete(StartTask_Handler);
  58.         taskEXIT_CRITICAL();
  59. }
  60. //task1
  61. void task1(void *pvParameters)
  62. {
  63.     while (1)
  64.     {
  65.         printf("task1 run ...\r\n");
  66.         led2_tog();
  67.         vTaskDelay(500);
  68.     }
  69. }
  70. //task2
  71. void task2(void *pvParameters)
  72. {
  73.     while (1)
  74.     {
  75.                                 led3_tog();
  76.         printf("task2 run ...\r\n");
  77.         vTaskDelay(100);
  78.     }
  79. }
四、程序运行
开发板运行后,串口输出
