harchy 发表于 2024-4-2 15:57
RA8889/RA8876显示自定义ASCII字符方法
本文介绍用户自己生成的ASCII字库如何通过RA8889/RA8876显示到液晶屏上。
先上一张实例效果图:
http://www.lcdvision.com.cn/uploadfile/2024/0402/20240402032914799.jpg
再上程序代码:
int main(void)
      unsigned short x,y;
      /* System Clocks Configuration */
      RCC_Configuration();
      delay_init(72);
      GPIO_Configuration();
      //NVIC_Configuration();
      //SPI_Peripheral_Init();
      /* Enable the FSMC Clock */
      RCC_AHBPeriphClockCmd(RCC_AHBPeriph_FSMC, ENABLE);
      delay_ms(1);
      FSMC_LCD_Init_H();
      /*RA8889初始化*/
      RA8889_Initial();
      /*清屏,填充黑色0x0*/
      BTE_Solid_Fill(0,canvas_image_width,0,0,0x0,LCD_Width,LCD_Height);
      /*MCU写入ASCII字符功能例程测试,不支持MCU_16bit_ColorDepth_24bpp_Mode_1 */
      x=30;
      y=50;
      lcdPutString8x12(x,y,color65k_black,color65k_yellow,0,"The things I want to know are in books, my best friend is the man ");
      lcdPutString16x24(x,y+20,color65k_black,color65k_yellow,0,"who'll get me a book I ain't read.");
      lcdPutString16x24(x+16*14,y+50,color65k_green,color65k_yellow,1," --Abraham Lincoln ");
      lcdPutString32x48(x,y+100,color65k_white,color65k_yellow,1,"ASCII font lib is ");
      lcdPutString32x48(x,y+150,color65k_white,color65k_yellow,1,"stored in the MCU's");
      lcdPutString32x48(x,y+200,color65k_white,color65k_yellow,1,"FLASH.");
      while(1);
程序流程图:
该方法是将制作好的ASCII字库放在MCU的FLASH中进行引用,字符数量为95个,编码区间0x20~0x7E,通过编码即可索引,并调用相应的数据,通过RA8889/RA8876描点显示出来。
该地址可下载源代码
http://www.lcdvision.com.cn/html/2024/application_0402/63.html
页: [1]
查看完整版本: RA8889/RA8876显示自定义ASCII字符方法
