N32G430 评测
本帖最后由 一路向北lm 于 2024-4-24 18:54 编辑拿到了N32G430开发板已经有一段时间了,由于最近一段时间经历离职/换工作,一直没有开箱评测,最近几天有空,给大家做一个分享汇报。
1.芯片功能:
N32G430系列采用32-bit Arm® Cortex®-M4F内核,最高工作主频128MHz,支持浮点运算和DSP指令,集成高达 64KB嵌入式加密Flash,16KB SRAM,集成丰富的高性能模拟器件,内置1个12bit 4.7Msps ADC,3个高速比较 器,集成多路U(S)ART、I²C、SPI、CAN等数字通信接口。
2.资料下载:
国民技术官网:https://www.nationstech.com/zlxz369/
3.gpio-led 测试void LED_Initialize(GPIO_Module* GPIOx, uint16_t pin)
GPIO_InitType GPIO_InitStructure;
if(GPIOx == GPIOA)
RCC_AHB_Peripheral_Clock_Enable(RCC_AHB_PERIPH_GPIOA);
else if(GPIOx == GPIOB)
RCC_AHB_Peripheral_Clock_Enable(RCC_AHB_PERIPH_GPIOB);
else if(GPIOx == GPIOC)
RCC_AHB_Peripheral_Clock_Enable(RCC_AHB_PERIPH_GPIOC);
else
RCC_AHB_Peripheral_Clock_Enable(RCC_AHB_PERIPH_GPIOD);
if(pin < GPIO_PIN_ALL)
GPIO_Structure_Initialize(&GPIO_InitStructure);
GPIO_InitStructure.Pin = pin;
GPIO_InitStructure.GPIO_Mode = GPIO_MODE_OUT_PP;
GPIO_InitStructure.GPIO_Current = GPIO_DS_4MA;
GPIO_Peripheral_Initialize(GPIOx, &GPIO_InitStructure);
void LED_Toggle(GPIO_Module* GPIOx, uint16_t pin)
GPIO_Pin_Toggle(GPIOx, pin);;
GPIO_Pins_Set(GPIOx, pin);
void LED_Off(GPIO_Module* GPIOx,uint16_t pin)
GPIO_Pins_Reset(GPIOx, pin);
// mian test
int main(void)
LED_Initialize(LED1_GPIO_PORT, LED1_GPIO_PIN | LED2_GPIO_PIN | LED3_GPIO_PIN);
LED_Off(LED1_GPIO_PORT, LED1_GPIO_PIN | LED2_GPIO_PIN | LED3_GPIO_PIN);
while(1)
LED_Toggle(LED1_GPIO_PORT, LED1_GPIO_PIN);
LED_Toggle(LED2_GPIO_PORT, LED2_GPIO_PIN);
LED_Toggle(LED3_GPIO_PORT, LED3_GPIO_PIN);
SysTick_Delay_Ms(1000);
}4.gpio-key 测试void Key_Input_Initialize(GPIO_Module* GPIOx, uint16_t pin)
if(GPIOx == GPIOA)
else
GPIO_InitStructure.GPIO_Mode = GPIO_MODE_INPUT;
GPIO_InitStructure.GPIO_Pull = GPIO_PULL_UP;
/* Initialize GPIO */
/* Define a structure of type GPIO_InitType */
/* Enable KEY related GPIO peripheral clock */
if(GPIOx == GPIOA)
else
// main test
int main(void)
LED_Initialize(LED1_GPIO_PORT, LED1_GPIO_PIN | LED2_GPIO_PIN);
Key_Input_Initialize(KEY3_PORT, KEY3_PIN);
while(1)
if(GPIO_Input_Pin_Data_Get(KEY3_PORT, KEY3_PIN) == PIN_RESET)
LED_On(LED1_GPIO_PORT, LED1_GPIO_PIN);
LED_Off(LED2_GPIO_PORT, LED2_GPIO_PIN);
LED_Off(LED3_GPIO_PORT, LED3_GPIO_PIN);
}5.timer-gpio-toggle 测试uint32_t BSTIMClockFrequency = 0;
void GPIO_Config(void)
GPIO_InitStructure.Pin = GPIO_PIN_6;
GPIO_InitStructure.GPIO_Mode= GPIO_MODE_OUT_PP;
GPIO_InitStructure.GPIO_Slew_Rate = GPIO_SLEW_RATE_FAST;
GPIO_Peripheral_Initialize(GPIOB, &GPIO_InitStructure);
int main(void)
GPIO_Config();
BSTIMClockFrequency = Common_BSTIM_RCC_Initialize(TIM6, RCC_HCLK_DIV4);
Common_TIM_NVIC_Initialize(TIM6_IRQn, ENABLE);
Common_TIM_Base_Initialize(TIM6, 65535, 0);
TIM_Base_Reload_Mode_Set(TIM6, TIM_PSC_RELOAD_MODE_IMMEDIATE);
TIM_Interrupt_Enable(TIM6, TIM_INT_UPDATE);
TIM_On(TIM6);
void TIM6_IRQHandler(void)
if (TIM_Interrupt_Status_Get(TIM6, TIM_INT_UPDATE) != RESET)
TIM_Interrupt_Status_Clear(TIM6, TIM_INT_UPDATE);
GPIO_Pin_Toggle(GPIOB, GPIO_PIN_6);
}6.uart-printf 测试void GPIO_Configuration(void)
GPIO_InitStructure.Pin = USARTx_TxPin;
GPIO_InitStructure.GPIO_Mode = GPIO_MODE_AF_PP;
GPIO_InitStructure.GPIO_Alternate = USARTx_Tx_GPIO_AF;
GPIO_Peripheral_Initialize(USARTx_GPIO, &GPIO_InitStructure);
GPIO_InitStructure.Pin = USARTx_RxPin;
GPIO_InitStructure.GPIO_Alternate = USARTx_Rx_GPIO_AF;
void RCC_Configuration(void)
GPIO_AHBClkCmd(USARTx_GPIO_CLK);
USART_APBxClkCmd(USARTx_CLK);
voidUART_Configuration(void)
USART_InitType USART_InitStructure;
USART_InitStructure.BaudRate = 115200;
USART_InitStructure.WordLength = USART_WL_8B;
USART_InitStructure.StopBits = USART_STPB_1;
USART_InitStructure.Parity = USART_PE_NO;
USART_InitStructure.HardwareFlowControl = USART_HFCTRL_NONE;
USART_InitStructure.Mode = USART_MODE_RX | USART_MODE_TX;
/* Configure USARTx */
USART_Initializes(USARTx, &USART_InitStructure);
/* Enable the USARTx */
USART_Enable(USARTx);
int main(void)
RCC_ClocksType RCC_ClocksStatus;
RCC_Configuration();
GPIO_Configuration();
UART_Configuration(void);
RCC_Clocks_Frequencies_Value_Get(&RCC_ClocksStatus);
printf("\n\rUSART Printf Example: retarget the C library printf function to the USART\n\r");
while (1)
int fputc(int ch, FILE* f)
USART_Data_Send(USARTx, (uint8_t)ch);
while (USART_Flag_Status_Get(USARTx, USART_FLAG_TXDE) == RESET);
return (ch);
#ifdef USE_FULL_ASSERT
void assert_failed(const uint8_t* expr, const uint8_t* file, uint32_t line)
/* User can add his own implementation to report the file name and line number,
ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
/* Infinite loop */
while (1)
#endif7.can-loop测试,N32G430集成了can外设,也就意味着它具备胜任工业网络canopen协议的可能,can迈出大门第一步,回环自测
void CAN_CONFIG(void)
RCC_APB1_Peripheral_Clock_Enable(RCC_APB1_PERIPH_CAN);
CAN_NVIC_Configuration();
CAN_GPIO_Configuration();
CAN_Reset(CAN);
CAN_Structure_Initializes(&CAN_InitStructure);
CAN_InitStructure.TTCM = DISABLE;
CAN_InitStructure.ABOM = DISABLE;
CAN_InitStructure.AWKUM = DISABLE;
CAN_InitStructure.NART = DISABLE;
CAN_InitStructure.RFLM = DISABLE;
CAN_InitStructure.TXFP = ENABLE;
CAN_InitStructure.OperatingMode = CAN_LOOPBACK_MODE;
CAN_InitStructure.RSJW = CAN_RSJW_1TQ;
CAN_InitStructure.TBS1 = CAN_TBS1_8TQ;
CAN_InitStructure.TBS2 = CAN_TBS2_7TQ;
CAN_InitStructure.BaudRatePrescaler = 4;
CAN_Initializes(CAN, &CAN_InitStructure);
CAN_FilterInitStructure.Filter_Num = 0;
CAN_FilterInitStructure.Filter_Mode = CAN_FILTER_IDLISTMODE;
CAN_FilterInitStructure.Filter_Scale = CAN_FILTER_32BITSCALE;
CAN_FilterInitStructure.Filter_HighId = 0x8000;
CAN_FilterInitStructure.Filter_LowId = 0x0000;
CAN_FilterInitStructure.FilterMask_HighId = 0x4000;
CAN_FilterInitStructure.FilterMask_LowId = 0x0000;
CAN_FilterInitStructure.Filter_FIFOAssignment = CAN_FIFO0;
CAN_FilterInitStructure.Filter_Act = ENABLE;
CAN_Filter_Initializes(&CAN_FilterInitStructure);
CAN_Config_Interrupt_Enable(CAN, CAN_INT_FMP0);
void CAN_NVIC_Configuration(void)
NVIC_InitType NVIC_InitStructure;
NVIC_Initializes(&NVIC_InitStructure);
NVIC_InitStructure.NVIC_IRQChannel = CAN_RX0_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x0;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x1;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
void CAN_GPIO_Configuration(void)
RCC_APB2_Peripheral_Clock_Enable(RCC_APB2_PERIPH_AFIO);
GPIO_InitStructure.Pin = GPIO_PIN_8;
GPIO_InitStructure.GPIO_Alternate = GPIO_AF6_CAN;
GPIO_InitStructure.Pin = GPIO_PIN_9;
GPIO_InitStructure.GPIO_Alternate= GPIO_AF6_CAN;
uint8_t Check_CanRecData(CanRxMessage* RxMessage, uint32_t StdId, uint32_t ExtId, uint8_t IDE, uint8_t RTR, uint8_t DLC,
uint8_t Data0, uint8_t Data1, uint8_t Data2, uint8_t Data3,
uint8_t Data4, uint8_t Data5, uint8_t Data6, uint8_t Data7, uint8_t FMI)
if(IDE == CAN_EXTENDED_ID)
if(RxMessage->ExtId != ExtId)
return Fail;
else if(IDE == CAN_STANDARD_ID)
if(RxMessage->StdId != StdId)
return Fail;
if( (RxMessage->IDE != IDE) || /* CAN_ID_STD / CAN_ID_EXT */
(RxMessage->RTR != RTR) || /* CAN_RTR_DATA / CAN_RTR_REMOTE */
(RxMessage->DLC != DLC) /* 0 to 8 */
return Fail;
if(RTR == CAN_RTRQ_DATA)
if(DLC >= 1)
if(RxMessage->Data != Data0)
return Fail;
if(DLC >= 2)
if(RxMessage->Data != Data1)
return Fail;
if(DLC >= 3)
if(RxMessage->Data != Data2)
return Fail;
if(DLC >= 4)
if(RxMessage->Data != Data3)
return Fail;
if(DLC >= 5)
if(RxMessage->Data != Data4)
return Fail;
if(DLC >= 6)
if(RxMessage->Data != Data5)
return Fail;
if(DLC >= 7)
if(RxMessage->Data != Data6)
return Fail;
if(DLC == 8)
if(RxMessage->Data != Data7)
return Fail;
if(DLC > 8)
return Fail;
else if(RTR == CAN_RTRQ_REMOTE)
if(RxMessage->FMI != FMI)
return Fail;
return Pass;
uint16_t Rx_Flag = DISABLE;
int main(void)
uint32_t wait_slak;
NVIC_Priority_Group_Set(NVIC_PER2_SUB2_PRIORITYGROUP);
CAN_CONFIG();
CAN_TxMessage.StdId = 0x0400;
CAN_TxMessage.ExtId = 0x00;
CAN_TxMessage.IDE = CAN_STANDARD_ID; /* CAN_ID_STD / CAN_ID_EXT */
CAN_TxMessage.RTR = CAN_RTRQ_DATA; /* CAN_RTR_DATA / CAN_RTR_REMOTE */
CAN_TxMessage.DLC = 8; /* 0 to 8 */
CAN_TxMessage.Data = 0x00;
CAN_TxMessage.Data = 0x01;
CAN_TxMessage.Data = 0x02;
CAN_TxMessage.Data = 0x03;
CAN_TxMessage.Data = 0x04;
CAN_TxMessage.Data = 0x05;
CAN_TxMessage.Data = 0x06;
CAN_TxMessage.Data = 0x07;
while(1)
CAN_Transmit_Message_initializes(CAN,&CAN_TxMessage);
while(Rx_Flag == DISABLE)
Rx_Flag = Check_CanRecData(&CAN_RxMessage, 0x0400, 0x00, CAN_STANDARD_ID, CAN_RTRQ_DATA, 8,
0x00,0x01, 0x02, 0x03,
0x04,0x05, 0x06, 0x07, 0);
wait_slak = 0xFFFF;
while(wait_slak>0)
wait_slak--;
Rx_Flag = DISABLE;
8.内置boot-loader测试,测试内部的boot,是我这次测试的重点,在汇川工作的时候,遇到过国民其它系列芯片内置boot的bug问题,本次再来体验一下,看国民官方是否修复。
8.1 N32G430内置boot功能强大,具体支持功能如下:
8.2 N32G430 系列芯片的固件程序 BOOT,支持通过 USART 接口下载用户程序和数据。 相关命令格式如下:
上下层指令数据结构
1、上层指令结构:
<CMD_H + CMD_L + LEN + Par> + (DAT)。
CMD_H 代表一级命令字段, CMD_L 代表二级命令字段; LEN 代表发送数据长度; Par代表 4 个字节命令参数; DAT 代表上层指令往下层发送的具体数据;
2、下层应答结构:
< CMD_H + CMD_L + LEN > + (DAT) + <CR1+CR2>。
CMD_H 代表一级命令字段, CMD_L 代表二级命令字段,下层的命令字段和对应上层的命令字段相同; LEN 代表发送数据长度; DAT 代表下层向上层应答的具体数据; CR1+CR2代表向上层返回的指令执行结果,若上层发送命令一级、二级命令字段不属于任何命令, BOOT 回复 CR1=0xBB, CR2 = 0xCC。
串口支持的命令数据结构:
1、 上位机下发上层指令:
STA1 + STA2 + {上层指令结构} + XOR。
STA1 和 STA2 是串口发送命令的起始字节, STA1=0xAA, STA2=0x55。用于芯片识别上位机发送串口数据流。
XOR 代表之前命令字节的异或运算值(STA1 + STA2 + {上层指令结构})。
2、 上位机接收下层应答:
STA1 + STA2 + {下层应答结构} + XOR。
STA1 和 STA2 是串口发送命令的起始字节, STA1=0xAA, STA2=0x55。用于上位机识别芯片发送串口数据流
XOR 代表之前命令字节的异或运算值(STA1 + STA2 + {下层应答结构})。
8.3 命令列表
8.4 命令说明和实例修改串口波特率
Par,串口波特率协商设置值可以设定最大,设定范围为 2.4Kbps ~ 4Mbps,默认波特率为 9600bps;
状态字节(CR1、 CR2)根据命令执行情况分为:
1. 返回成功:状态标志位(0xA0、 0x00)。
2. 返回失败:状态标志位(0xB0、 0x00)。
n32g430的性价比真的高 呐咯密密 发表于 2024-4-24 13:52
n32g430的性价比真的高
是的,拿来做canopen设备一点问题没有的
页:
[1]
