【APM32F411V Tiny Board测评】6.实现一个简易U盘TXT阅读器
APM32F411的USB支持主机或从机模式接下来在OTGH_MSC这个例程的基础上增加LCD显示,U盘文件扫描和TXT文件读取功能
把上个帖子的LCD驱动移植过来,由于USB占用了原来的IO,需要换一下IO才行
YUYY_HS12864G18B_DEV_Type lcd_dev;
void spi_init()
GPIO_Config_T GPIO_InitStructure;
SPI_Config_TSPI_InitStructure;
RCM_EnableAHB1PeriphClock (RCM_AHB1_PERIPH_GPIOC);
RCM_EnableAPB1PeriphClock(RCM_APB1_PERIPH_SPI2);
GPIO_ConfigPinAF(GPIOC, GPIO_PIN_SOURCE_3, GPIO_AF_SPI1);
GPIO_ConfigPinAF(GPIOC, GPIO_PIN_SOURCE_7, GPIO_AF_SPI1);
GPIO_ConfigStructInit(&GPIO_InitStructure);
GPIO_InitStructure.pin = GPIO_PIN_3 | GPIO_PIN_7;
GPIO_InitStructure.speed = GPIO_SPEED_100MHz;
GPIO_InitStructure.mode = GPIO_MODE_AF;
GPIO_InitStructure.otype = GPIO_OTYPE_PP;
GPIO_InitStructure.pupd = GPIO_PUPD_NOPULL;
GPIO_Config(GPIOC, &GPIO_InitStructure);
SPI_ConfigStructInit(&SPI_InitStructure);
SPI_InitStructure.direction = SPI_DIRECTION_1LINE_TX;
SPI_InitStructure.mode = SPI_MODE_MASTER;
SPI_InitStructure.length = SPI_DATA_LENGTH_8B;
SPI_InitStructure.polarity = SPI_CLKPOL_HIGH;
SPI_InitStructure.phase = SPI_CLKPHA_2EDGE;
SPI_InitStructure.nss = SPI_NSS_SOFT;
SPI_InitStructure.baudrateDiv = SPI_BAUDRATE_DIV_8;
SPI_InitStructure.firstBit = SPI_FIRSTBIT_MSB;
SPI_InitStructure.crcPolynomial = 7;
SPI_Config(SPI2, &SPI_InitStructure);
SPI_DisableCRC(SPI2);
SPI_DisableSSOutput(SPI2);
SPI_Enable(SPI2);
void lcd_spiwritebyte(SPI_T *spix,uint8_t byte)
while (SPI_I2S_ReadStatusFlag(spix, SPI_FLAG_TXBE) == RESET);
SPI_I2S_TxData(spix, byte);
void lcd_init()
GPIO_Config_T gpioConfigStruct;
GPIO_ConfigStructInit(&gpioConfigStruct);
gpioConfigStruct.mode = GPIO_MODE_OUT;
gpioConfigStruct.speed = GPIO_SPEED_100MHz;
gpioConfigStruct.pin = GPIO_PIN_4 | GPIO_PIN_5 | GPIO_PIN_6;
gpioConfigStruct.otype = GPIO_OTYPE_PP;
gpioConfigStruct.pupd = GPIO_PUPD_NOPULL;
GPIO_Config(GPIOC, &gpioConfigStruct);
lcd_dev.cs.gpio = GPIOC;
lcd_dev.cs.pin = GPIO_PIN_4;
lcd_dev.rst.gpio = GPIOC;
lcd_dev.rst.pin = GPIO_PIN_5;
lcd_dev.a0.gpio = GPIOC;
lcd_dev.a0.pin = GPIO_PIN_6;
lcd_dev.spix = SPI2;
lcd_dev.spi_sendbyte_func = (YUYY_HS12864G18B_SpiWriteByteFunc_Type)lcd_spiwritebyte;
YUYY_HS12864G18B_Init(&lcd_dev);
YUYY_HS12864G18B_ClearScreen(&lcd_dev);
YUYY_HS12864G18B_DisplayString8x16(&lcd_dev,0,0,0," APM32F411 TEST");
YUYY_HS12864G18B_DisplayString8x16(&lcd_dev,0,2,0,"TXT FILE READER");
YUYY_HS12864G18B_DisplayString8x16(&lcd_dev,0,4,0,"Wait USB Dev");
YUYY_HS12864G18B_DisplayString8x16(&lcd_dev,0,6,0,"Code by yuyy1989");
YUYY_HS12864G18B_DisplayFinish(&lcd_dev);
}实现TXT文件扫描和内容显示
#define MAX_TXT_NUM 10
char filenames;
uint8_t txt_num = 0;
uint8_t select_index = 0;
uint8_t filed_opened = 0;
uint8_t file_read_end = 0;
uint8_t file_buffer;
uint8_t file_buffer_len = 0;
char lcd_buffer;
void yuyy_show_txt()
uint8_t start_index = 0;
uint8_t i = 0;
if(txt_num == 0)
YUYY_HS12864G18B_DisplayString8x16(&lcd_dev,0,0,0,"NO TXT FILES");
return;
if(!filed_opened)
if(txt_num > 4)
if(select_index == txt_num - 1 )
start_index = select_index - 3;
else if(select_index > 2 )
start_index = select_index - 2;
while(start_index < txt_num)
YUYY_HS12864G18B_DisplayString8x16(&lcd_dev,select_index == start_index?YUYY_FONT_DATAS_REVERSE:0,i*2,0,filenames);
i += 1;
start_index += 1;
else
YUYY_HS12864G18B_DisplayString8x16(&lcd_dev,0,0,0,lcd_buffer);
YUYY_HS12864G18B_DisplayString8x16(&lcd_dev,0,2,0,lcd_buffer);
YUYY_HS12864G18B_DisplayString8x16(&lcd_dev,0,4,0,lcd_buffer);
YUYY_HS12864G18B_DisplayString8x16(&lcd_dev,0,6,0,lcd_buffer);
void yuyy_readbuffer_to_lcd()
uint8_t i = 0,j = 0,k = 0;
uint32_t len = 0;
memset(lcd_buffer,0,68);
if(file_buffer_len == 0)
f_lseek(&file,0);
file_read_end = 0;
if(!file_read_end && file_buffer_len < 80)
if(f_read(&file, &file_buffer, 80-file_buffer_len, &len) == FR_OK)
if(len == 0 || len < 80-file_buffer_len)
file_read_end = 1;
file_buffer_len += len;
while(j < 4)
i = 0;
while(i < 16 && k < file_buffer_len)
if(file_buffer>0x19 && file_buffer < 0x7F)
lcd_buffer = file_buffer;
i += 1;
else if(file_buffer == '\n' && i > 0)
i = 16;
k += 1;
j += 1;
i = 0;
j = k;
while(i < k && j < 80)
file_buffer = file_buffer;
i += 1;
j += 1;
file_buffer_len -= k;
void yuyy_file_index_change()
if(!filed_opened)
select_index += 1;
if(txt_num > 0 && select_index > txt_num - 1)
select_index = 0;
yuyy_show_txt();
else
yuyy_readbuffer_to_lcd();
yuyy_show_txt();
void yuyy_file_open_back()
if(txt_num == 0)
return;
if(!filed_opened)
if(f_open(&file, filenames, FA_READ) == FR_OK)
filed_opened = 1;
memset(file_buffer,0,80);
yuyy_show_txt();
else
if(f_close(&file) == FR_OK)
filed_opened = 0;
file_read_end = 0;
yuyy_show_txt();
void yuyy_scantxt()
uint8_t len,i;
FRESULT res;
FILINFO fileinfo;
DIR dir;
res=f_opendir(&dir,"/");
if(res != FR_OK)
return;
memset(filenames,0,MAX_TXT_NUM*14);
txt_num = 0;
while(1)
char* pstr;
res = f_readdir(&dir, &fileinfo);
if (res != FR_OK || fileinfo.fname == 0 || txt_num == MAX_TXT_NUM)
break;
if(fileinfo.fattrib&AM_DIR)
continue;
len = strlen(fileinfo.fname);
if(len > 4 && strncasecmp(&fileinfo.fname,".TXT",4) == 0)
memcpy(filenames,fileinfo.fname,13);
i = 0;
while(i < txt_num)
printf("%d: %s",i,filenames);
i++;
改写USB_HostUserApplication这个方法
void USB_HostUserApplication(void)
uint8_t status = gUsbHostAppStatus;
static uint8_t userAppState = USER_APP_INIT;
switch (status)
case USBH_APP_CONNECTION:
break;
case USBH_APP_DISCONNECTION:
break;
case USBH_APP_READY:
switch (userAppState)
case USER_APP_INIT:
if (f_mount(&fatfs, "0:", 0) == FR_OK)
yuyy_scantxt();
yuyy_show_txt();
userAppState = USER_APP_RUN;
break;
case USER_APP_RUN:
if (!APM_PBGetState(BUTTON_KEY1))
YUYY_DelayMs(10);
yuyy_file_index_change();
while (!APM_PBGetState(BUTTON_KEY1));
if (!APM_PBGetState(BUTTON_KEY2))
YUYY_DelayMs(10);
yuyy_file_open_back();
while (!APM_PBGetState(BUTTON_KEY2));
break;
break;
default:
break;
}作为主机使用时需要短接开发板上的J11,才能通过USB输出5V
没有插入U盘时
选择文件
打开文件查看内容
USB_OTG使用配置起来还是挺方便的,里面的协议格式能方便讲解一下嘛
页:
[1]
