czq2317 发表于 2024-9-22 23:53
windows下使用GCC环境编译HC32F448工程
#技术资源# #申请原创#
试了好久,终于成功搭建windows下的GCC开发环境。开发环境如下:
系统:Win11
编译环境:GCC
仿真环境:pyOCD
整个开发环境的搭建,可以参考:https://mp.csdn.net/mp_blog/creation/editor/142444700
gcc开发环境下MCU编程,除了要搭建好开发环境之外,还有三个重要的文件,分别是makefile、.ld文件及.s文件。
在HC32F448提供的DDL demo中,有eclipse工程,里边包含了.ld文件及.s文件,还差了makefile文件。
在此奉献上我调试好的makefile文件,抛砖引玉,让更多人来使用及优化。也希望大神能提出不足及指正。
# File automatically-generated by tool: version: date:
# Generic Makefile (based on gcc)
# ChangeLog :
#        2017-02-10 - Several enhancements + project update mode
#   2015-07-22 - first version
# target
TARGET = adc_awd
# building variables
# debug build?
DEBUG = 1
# optimization
OPT = -O0
# paths
# Build path
BUILD_DIR = build
# source
# C sources
C_SOURCES =\
../source/main.c \
../../../../../../drivers/bsp/components/tca9539/tca9539.c \
../../../../../../drivers/bsp/ev_hc32f448_lqfp80/ev_hc32f448_lqfp80.c \
../../../../../../drivers/bsp/ev_hc32f448_lqfp80/ev_hc32f448_lqfp80_tca9539.c \
../../../../../../drivers/cmsis/Device/HDSC/hc32f4xx/Source/system_hc32f448.c \
../../../../../../drivers/hc32_ll_driver/src/hc32_ll.c \
../../../../../../drivers/hc32_ll_driver/src/hc32_ll_adc.c \
../../../../../../drivers/hc32_ll_driver/src/hc32_ll_aos.c \
../../../../../../drivers/hc32_ll_driver/src/hc32_ll_clk.c \
../../../../../../drivers/hc32_ll_driver/src/hc32_ll_efm.c \
../../../../../../drivers/hc32_ll_driver/src/hc32_ll_fcg.c \
../../../../../../drivers/hc32_ll_driver/src/hc32_ll_fcm.c \
../../../../../../drivers/hc32_ll_driver/src/hc32_ll_gpio.c \
../../../../../../drivers/hc32_ll_driver/src/hc32_ll_i2c.c \
../../../../../../drivers/hc32_ll_driver/src/hc32_ll_icg.c \
../../../../../../drivers/hc32_ll_driver/src/hc32_ll_interrupts.c \
../../../../../../drivers/hc32_ll_driver/src/hc32_ll_keyscan.c \
../../../../../../drivers/hc32_ll_driver/src/hc32_ll_pwc.c \
../../../../../../drivers/hc32_ll_driver/src/hc32_ll_tmr0.c \
../../../../../../drivers/hc32_ll_driver/src/hc32_ll_usart.c \
../../../../../../drivers/hc32_ll_driver/src/hc32_ll_utility.c
# ASM sources
ASM_SOURCES =
# ASM sources
ASMM_SOURCES =\
startup_hc32f448.S
# binaries
PREFIX = arm-none-eabi-
# The gcc compiler bin path can be either defined in make command via GCC_PATH variable (> make GCC_PATH=xxx)
# either it can be added to the PATH environment variable.
ifdef GCC_PATH
CC = $(GCC_PATH)/$(PREFIX)gcc
AS = $(GCC_PATH)/$(PREFIX)gcc -x assembler-with-cpp
CP = $(GCC_PATH)/$(PREFIX)objcopy
SZ = $(GCC_PATH)/$(PREFIX)size
else
CC = $(PREFIX)gcc
AS = $(PREFIX)gcc -x assembler-with-cpp
CP = $(PREFIX)objcopy
SZ = $(PREFIX)size
endif
HEX = $(CP) -O ihex
BIN = $(CP) -O binary -S
# CFLAGS
# cpu
CPU = -mcpu=cortex-m4
# fpu
FPU = -mfpu=fpv4-sp-d16
# float-abi
FLOAT-ABI = -mfloat-abi=hard
# mcu
MCU = $(CPU) -mthumb $(FPU) $(FLOAT-ABI)
# macros for gcc
# AS defines
AS_DEFS =
# C defines
C_DEFS =\
-D__DEBUG \
-DHC32F448 \
-DUSE_DDL_DRIVER
# AS includes
AS_INCLUDES =
# C includes
C_INCLUDES =\
-I../../../../../../drivers/cmsis/Device/HDSC/hc32f4xx/Include \
-I../../../../../../drivers/cmsis/Include \
-I../../../../../../drivers/hc32_ll_driver/inc \
-I../source \
-I../../../../../../drivers/bsp/ev_hc32f448_lqfp80 \
-I../../../../../../drivers/bsp/components/tca9539
# compile gcc flags
ASFLAGS = $(MCU) $(AS_DEFS) $(AS_INCLUDES) $(OPT) -Wall -fdata-sections -ffunction-sections
CFLAGS += $(MCU) $(C_DEFS) $(C_INCLUDES) $(OPT) -Wall -fdata-sections -ffunction-sections
ifeq ($(DEBUG), 1)
CFLAGS += -g -gdwarf-2
endif
# Generate dependency information
CFLAGS += -MMD -MP -MF"$(@:%.o=%.d)"
# LDFLAGS
# link script
LDSCRIPT = ./config/linker/HC32F448xA.ld
# libraries
LIBS = -lc -lm -lnosys
LIBDIR =
LDFLAGS = $(MCU) -specs=nano.specs -T$(LDSCRIPT) $(LIBDIR) $(LIBS) -Wl,-Map=$(BUILD_DIR)/$(TARGET).map,--cref -Wl,--gc-sections
# default action: build all
all: $(BUILD_DIR)/$(TARGET).elf $(BUILD_DIR)/$(TARGET).hex $(BUILD_DIR)/$(TARGET).bin
# build the application
# list of objects
OBJECTS = $(addprefix $(BUILD_DIR)/,$(notdir $(C_SOURCES:.c=.o)))
vpath %.c $(sort $(dir $(C_SOURCES)))
# list of ASM program objects
OBJECTS += $(addprefix $(BUILD_DIR)/,$(notdir $(ASM_SOURCES:.s=.o)))
vpath %.s $(sort $(dir $(ASM_SOURCES)))
OBJECTS += $(addprefix $(BUILD_DIR)/,$(notdir $(ASMM_SOURCES:.S=.o)))
vpath %.S $(sort $(dir $(ASMM_SOURCES)))
$(BUILD_DIR)/%.o: %.c Makefile | $(BUILD_DIR)
        $(CC) -c $(CFLAGS) -Wa,-a,-ad,-alms=$(BUILD_DIR)/$(notdir $(<:.c=.lst)) [        DISCUZ_CODE_58        ]lt; -o $@
$(BUILD_DIR)/%.o: %.s Makefile | $(BUILD_DIR)
        $(AS) -c $(CFLAGS) [        DISCUZ_CODE_58        ]lt; -o $@
$(BUILD_DIR)/%.o: %.S Makefile | $(BUILD_DIR)
$(BUILD_DIR)/$(TARGET).elf: $(OBJECTS) Makefile
        $(CC) $(OBJECTS) $(LDFLAGS) -o $@
        $(SZ) $@
$(BUILD_DIR)/%.hex: $(BUILD_DIR)/%.elf | $(BUILD_DIR)
        $(HEX) [        DISCUZ_CODE_58        ]lt; $@
$(BUILD_DIR)/%.bin: $(BUILD_DIR)/%.elf | $(BUILD_DIR)
        $(BIN) [        DISCUZ_CODE_58        ]lt; $@
$(BUILD_DIR):
        mkdir $@
# clean up
clean:
        rd /s/q $(BUILD_DIR)
# dependencies
-include $(wildcard $(BUILD_DIR)/*.d)
# *** EOF ***在此上传文本,方便下载。
将此文件放到HC32F448_DDL_Rev1.1.0\projects\ev_hc32f448_lqfp80\examples\adc\adc_awd\GCC目录下,其他工程目录,需要更改相应的内容。
在HC32F448_DDL_Rev1.1.0\projects\ev_hc32f448_lqfp80\examples\adc\adc_awd\GCC目录下右键选择在终端中打开,执行make
编译成功后显示
下载:
观察串口log
可以看到gcc-ARM编译的文件在F448上已经成功执行。
data:;base64,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
wubangmi 发表于 2024-9-23 10:40
感谢楼主的辛苦分享,但是小华原厂提供的GCC工程都是可以直接下载并仿真的,并不需要自行编写Makefile文件。
dukedz 发表于 2024-9-23 13:27
为啥不直接用 linux
WoodData 发表于 2024-9-23 15:47
感谢分享,收藏一下
shenxiaolin 发表于 2024-9-29 10:31
不错的经验
更多更合适ii 发表于 2024-9-30 17:27
在Makefile中可以添加检查步骤,观察源文件存在,GCC路径设置正确。在编译前捕捉到潜在问题。
可以将常用的路径和文件名抽象成变量,方便后续修改和维护。
页: [1]
查看完整版本: windows下使用GCC环境编译HC32F448工程
