tlled 发表于 2024-12-2 00:13
【AT-START-L021测评】+ spiflash读写测试
测试spiflash存储器读写。
一、硬件部分
测试使用SPI1接口。
二、程序部分
2.1、配置SPI1
spi1初始化部分程序可以使用软件AT32_Work_Bench生成
2.2、spi-flash.c
* @file   spi_flash.c
* @brief    spi_flash source code
*                     Copyright notice & Disclaimer
* The software Board Support Package (BSP) that is made available to
* download from Artery official website is the copyrighted work of Artery.
* Artery authorizes customers to use, copy, and distribute the BSP
* software and its related documentation for the purpose of design and
* development in conjunction with Artery microcontrollers. Use of the
* software is governed by this copyright notice and the following disclaimer.
* THIS SOFTWARE IS PROVIDED ON "AS IS" BASIS WITHOUT WARRANTIES,
* GUARANTEES OR REPRESENTATIONS OF ANY KIND. ARTERY EXPRESSLY DISCLAIMS,
* TO THE FULLEST EXTENT PERMITTED BY LAW, ALL EXPRESS, IMPLIED OR
* STATUTORY OR OTHER WARRANTIES, GUARANTEES OR REPRESENTATIONS,
* INCLUDING BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY,
* FITNESS FOR A PARTICULAR PURPOSE, OR NON-INFRINGEMENT.
#include "spiflash/spi_flash.h"
/** @addtogroup AT32L021_periph_examples
/** @addtogroup 021_SPI_w25q_flash
uint8_t spiflash_sector_buf;
* @briefspi configuration.
* @paramnone
* @retval none
void spiflash_init(void)
gpio_init_type gpio_initstructure;
spi_init_type spi_init_struct;
crm_periph_clock_enable(CRM_GPIOA_PERIPH_CLOCK, TRUE);
crm_periph_clock_enable(CRM_DMA1_PERIPH_CLOCK, TRUE);
gpio_pin_mux_config(GPIOA, GPIO_PINS_SOURCE5, GPIO_MUX_0);
gpio_pin_mux_config(GPIOA, GPIO_PINS_SOURCE6, GPIO_MUX_0);
gpio_pin_mux_config(GPIOA, GPIO_PINS_SOURCE7, GPIO_MUX_0);
/* software cs, pa15 as a general io to control flash cs */
gpio_initstructure.gpio_out_type       = GPIO_OUTPUT_PUSH_PULL;
gpio_initstructure.gpio_pull         = GPIO_PULL_UP;
gpio_initstructure.gpio_mode         = GPIO_MODE_OUTPUT;
gpio_initstructure.gpio_drive_strength = GPIO_DRIVE_STRENGTH_STRONGER;
gpio_initstructure.gpio_pins         = GPIO_PINS_15;
gpio_init(GPIOA, &gpio_initstructure);
/* sck */
gpio_initstructure.gpio_mode         = GPIO_MODE_MUX;
gpio_initstructure.gpio_pins         = GPIO_PINS_5;
/* miso */
gpio_initstructure.gpio_pins         = GPIO_PINS_6;
/* mosi */
gpio_initstructure.gpio_pins         = GPIO_PINS_7;
FLASH_CS_HIGH();
crm_periph_clock_enable(CRM_SPI1_PERIPH_CLOCK, TRUE);
spi_default_para_init(&spi_init_struct);
spi_init_struct.transmission_mode = SPI_TRANSMIT_FULL_DUPLEX;
spi_init_struct.master_slave_mode = SPI_MODE_MASTER;
spi_init_struct.mclk_freq_division = SPI_MCLK_DIV_8;
spi_init_struct.first_bit_transmission = SPI_FIRST_BIT_MSB;
spi_init_struct.frame_bit_num = SPI_FRAME_8BIT;
spi_init_struct.clock_polarity = SPI_CLOCK_POLARITY_HIGH;
spi_init_struct.clock_phase = SPI_CLOCK_PHASE_2EDGE;
spi_init_struct.cs_mode_selection = SPI_CS_SOFTWARE_MODE;
spi_init(SPI1, &spi_init_struct);
spi_enable(SPI1, TRUE);
* @briefwrite data to flash
* @parampbuffer: the pointer for data buffer
* @paramwrite_addr: the address where the data is written
* @paramlength: buffer length
* @retval none
void spiflash_write(uint8_t *pbuffer, uint32_t write_addr, uint32_t length)
uint32_t sector_pos;
uint16_t sector_offset;
uint16_t sector_remain;
uint16_t index;
uint8_t *spiflash_buf;
spiflash_buf = spiflash_sector_buf;
/* sector address */
sector_pos = write_addr / SPIF_SECTOR_SIZE;
/* address offset in a sector */
sector_offset = write_addr % SPIF_SECTOR_SIZE;
/* the remain in a sector */
sector_remain = SPIF_SECTOR_SIZE - sector_offset;
if(length <= sector_remain)
    /* smaller than a sector size */
    sector_remain = length;
while(1)
    /* read a sector */
    spiflash_read(spiflash_buf, sector_pos * SPIF_SECTOR_SIZE, SPIF_SECTOR_SIZE);
    /* validate the read erea */
    for(index = 0; index < sector_remain; index++)
      if(spiflash_buf != 0xFF)
      /* there are some data not equal 0xff, so this secotr needs erased */
      break;
    if(index < sector_remain)
      /* erase the sector */
      spiflash_sector_erase(sector_pos);
      /* copy the write data */
      spiflash_buf = pbuffer;
      spiflash_write_nocheck(spiflash_buf, sector_pos * SPIF_SECTOR_SIZE, SPIF_SECTOR_SIZE); /* program the sector */
    else
      /* write directly in the erased area */
      spiflash_write_nocheck(pbuffer, write_addr, sector_remain);
    if(length == sector_remain)
      /* write end */
      break;
    else
      /* go on writing */
      sector_pos++;
      sector_offset = 0;
      pbuffer += sector_remain;
      write_addr += sector_remain;
      length -= sector_remain;
      if(length > SPIF_SECTOR_SIZE)
      /* could not write the remain data in the next sector */
      sector_remain = SPIF_SECTOR_SIZE;
      else
      /* could write the remain data in the next sector */
* @briefread data from flash
* @paramread_addr: the address where the data is read
* @retval none
void spiflash_read(uint8_t *pbuffer, uint32_t read_addr, uint32_t length)
FLASH_CS_LOW();
spi_byte_write(SPIF_READDATA); /* send instruction */
spi_byte_write((uint8_t)((read_addr) >> 16)); /* send 24-bit address */
spi_byte_write((uint8_t)((read_addr) >> 8));
spi_byte_write((uint8_t)read_addr);
spi_bytes_read(pbuffer, length);
FLASH_CS_HIGH();
* @brieferase a sector data
* @paramerase_addr: sector address to erase
* @retval none
void spiflash_sector_erase(uint32_t erase_addr)
erase_addr *= SPIF_SECTOR_SIZE; /* translate sector address to byte address */
spiflash_write_enable();
spiflash_wait_busy();
FLASH_CS_LOW();
spi_byte_write(SPIF_SECTORERASE);
spi_byte_write((uint8_t)((erase_addr) >> 16));
spi_byte_write((uint8_t)((erase_addr) >> 8));
spi_byte_write((uint8_t)erase_addr);
FLASH_CS_HIGH();
* @briefwrite data without check
* @retval none
void spiflash_write_nocheck(uint8_t *pbuffer, uint32_t write_addr, uint32_t length)
uint16_t page_remain;
/* remain bytes in a page */
page_remain = SPIF_PAGE_SIZE - write_addr % SPIF_PAGE_SIZE;
if(length <= page_remain)
    /* smaller than a page size */
    page_remain = length;
while(1)
    spiflash_page_write(pbuffer, write_addr, page_remain);
    if(length == page_remain)
      /* all data are programmed */
      break;
    else
      /* length > page_remain */
      pbuffer += page_remain;
      write_addr += page_remain;
      /* the remain bytes to be prorammed */
      length -= page_remain;
      if(length > SPIF_PAGE_SIZE)
      /* can be progrmmed a page at a time */
      page_remain = SPIF_PAGE_SIZE;
      else
* @briefwrite a page data
* @retval none
void spiflash_page_write(uint8_t *pbuffer, uint32_t write_addr, uint32_t length)
if((0 < length) && (length <= SPIF_PAGE_SIZE))
    /* set write enable */
    FLASH_CS_LOW();
    spi_byte_write(SPIF_PAGEPROGRAM);
    spi_byte_write((uint8_t)((write_addr) >> 16));
    spi_byte_write((uint8_t)((write_addr) >> 8));
    spi_byte_write((uint8_t)write_addr);
    spi_bytes_write(pbuffer,length);
    FLASH_CS_HIGH();
    /* wait for program end */
* @briefwrite data continuously
* @retval none
void spi_bytes_write(uint8_t *pbuffer, uint32_t length)
volatile uint8_t dummy_data;
#if defined(SPI_TRANS_DMA)
dma_init_type dma_init_struct;
dma_reset(DMA1_CHANNEL2);
dma_reset(DMA1_CHANNEL3);
dma_flexible_config(DMA1, FLEX_CHANNEL2, DMA_FLEXIBLE_SPI2_RX);
dma_flexible_config(DMA1, FLEX_CHANNEL3, DMA_FLEXIBLE_SPI2_TX);
dma_default_para_init(&dma_init_struct);
dma_init_struct.buffer_size = length;
dma_init_struct.direction = DMA_DIR_PERIPHERAL_TO_MEMORY;
dma_init_struct.memory_base_addr = (uint32_t)&dummy_data;
dma_init_struct.memory_data_width = DMA_MEMORY_DATA_WIDTH_BYTE;
dma_init_struct.memory_inc_enable = FALSE;
dma_init_struct.peripheral_base_addr = (uint32_t)(&SPI2->dt);
dma_init_struct.peripheral_data_width = DMA_PERIPHERAL_DATA_WIDTH_BYTE;
dma_init_struct.peripheral_inc_enable = FALSE;
dma_init_struct.priority = DMA_PRIORITY_VERY_HIGH;
dma_init_struct.loop_mode_enable = FALSE;
dma_init(DMA1_CHANNEL2, &dma_init_struct);
dma_init_struct.direction = DMA_DIR_MEMORY_TO_PERIPHERAL;
dma_init_struct.memory_base_addr = (uint32_t)pbuffer;
dma_init_struct.memory_inc_enable = TRUE;
dma_init(DMA1_CHANNEL3, &dma_init_struct);
spi_i2s_dma_transmitter_enable(SPI2, TRUE);
spi_i2s_dma_receiver_enable(SPI2, TRUE);
dma_channel_enable(DMA1_CHANNEL2, TRUE);
dma_channel_enable(DMA1_CHANNEL3, TRUE);
while(dma_flag_get(DMA1_FDT2_FLAG) == RESET);
dma_flag_clear(DMA1_FDT2_FLAG);
dma_channel_enable(DMA1_CHANNEL2, FALSE);
dma_channel_enable(DMA1_CHANNEL3, FALSE);
spi_i2s_dma_transmitter_enable(SPI2, FALSE);
spi_i2s_dma_receiver_enable(SPI2, FALSE);
#else
while(length--)
    while(spi_i2s_flag_get(SPI1, SPI_I2S_TDBE_FLAG) == RESET);
    spi_i2s_data_transmit(SPI1, *pbuffer);
    while(spi_i2s_flag_get(SPI1, SPI_I2S_RDBF_FLAG) == RESET);
    dummy_data = spi_i2s_data_receive(SPI1);
    pbuffer++;
#endif
* @briefread data continuously
* @parampbuffer: buffer to save data
* @retval none
void spi_bytes_read(uint8_t *pbuffer, uint32_t length)
uint8_t write_value = FLASH_SPI_DUMMY_BYTE;
dma_init_struct.memory_base_addr = (uint32_t)&write_value;
#else
while(length--)
    spi_i2s_data_transmit(SPI1, write_value);
    *pbuffer = spi_i2s_data_receive(SPI1);
    pbuffer++;
#endif
* @briefwait program done
* @paramnone
* @retval none
void spiflash_wait_busy(void)
while((spiflash_read_sr1() & 0x01) == 0x01);
* @briefread sr1 register
* @paramnone
* @retval none
uint8_t spiflash_read_sr1(void)
uint8_t breadbyte = 0;
FLASH_CS_LOW();
spi_byte_write(SPIF_READSTATUSREG1);
breadbyte = (uint8_t)spi_byte_read();
FLASH_CS_HIGH();
return (breadbyte);
* @briefenable write operation
* @paramnone
* @retval none
void spiflash_write_enable(void)
FLASH_CS_LOW();
spi_byte_write(SPIF_WRITEENABLE);
FLASH_CS_HIGH();
* @briefread device id
* @paramnone
* @retval device id
uint16_t spiflash_read_id(void)
uint16_t wreceivedata = 0;
FLASH_CS_LOW();
spi_byte_write(SPIF_MANUFACTDEVICEID);
spi_byte_write(0x00);
wreceivedata |= spi_byte_read() << 8;
wreceivedata |= spi_byte_read();
FLASH_CS_HIGH();
return wreceivedata;
* @briefwrite a byte to flash
* @paramdata: data to write
* @retval flash return data
uint8_t spi_byte_write(uint8_t data)
uint8_t brxbuff;
spi_i2s_dma_transmitter_enable(SPI1, FALSE);
spi_i2s_dma_receiver_enable(SPI1, FALSE);
spi_i2s_data_transmit(SPI1, data);
brxbuff = spi_i2s_data_receive(SPI1);
while(spi_i2s_flag_get(SPI1, SPI_I2S_BF_FLAG) != RESET);
return brxbuff;
* @briefread a byte to flash
* @paramnone
uint8_t spi_byte_read(void)
return (spi_byte_write(FLASH_SPI_DUMMY_BYTE));
2.3、spi-flash.h
* @file   spi_flash.h
* @brief    header file of spi_flash
#ifndef __SPI_FLASH_H
#define __SPI_FLASH_H
#include "at32l021.h"
/* use dma transfer spi data */
//#define SPI_TRANS_DMA
/** @defgroup SPI_flash_cs_pin_definition
#define FLASH_CS_HIGH()                  gpio_bits_set(GPIOA, GPIO_PINS_15)
#define FLASH_CS_LOW()                   gpio_bits_reset(GPIOA, GPIO_PINS_15)
/** @defgroup SPI_flash_id_definition
* flash define
#define W25Q80                           0xEF13
#define W25Q16                           0xEF14
#define W25Q32                           0xEF15
#define W25Q64                           0xEF16
/* 16mb, the range of address:0~0xFFFFFF */
#define W25Q128                        0xEF17
/** @defgroup SPI_flash_operation_definition
#define SPIF_CHIP_SIZE                   0x1000000
#define SPIF_SECTOR_SIZE               4096
#define SPIF_PAGE_SIZE                   256
#define SPIF_WRITEENABLE               0x06
#define SPIF_WRITEDISABLE                0x04
/* s7-s0 */
#define SPIF_READSTATUSREG1            0x05
#define SPIF_WRITESTATUSREG1             0x01
/* s15-s8 */
#define SPIF_READSTATUSREG2            0x35
#define SPIF_WRITESTATUSREG2             0x31
/* s23-s16 */
#define SPIF_READSTATUSREG3            0x15
#define SPIF_WRITESTATUSREG3             0x11
#define SPIF_READDATA                  0x03
#define SPIF_FASTREADDATA                0x0B
#define SPIF_FASTREADDUAL                0x3B
#define SPIF_PAGEPROGRAM               0x02
/* block size:64kb */
#define SPIF_BLOCKERASE                  0xD8
#define SPIF_SECTORERASE               0x20
#define SPIF_CHIPERASE                   0xC7
#define SPIF_POWERDOWN                   0xB9
#define SPIF_RELEASEPOWERDOWN            0xAB
#define SPIF_DEVICEID                  0xAB
#define SPIF_MANUFACTDEVICEID            0x90
#define SPIF_JEDECDEVICEID               0x9F
#define FLASH_SPI_DUMMY_BYTE             0xA5
/** @defgroup SPI_flash_exported_functions
void spiflash_init(void);
void spiflash_write(uint8_t *pbuffer, uint32_t write_addr, uint32_t length);
void spiflash_read(uint8_t *pbuffer, uint32_t read_addr, uint32_t length);
void spiflash_sector_erase(uint32_t erase_addr);
void spiflash_write_nocheck(uint8_t *pbuffer, uint32_t write_addr, uint32_t length);
void spiflash_page_write(uint8_t *pbuffer, uint32_t write_addr, uint32_t length);
void spi_bytes_write(uint8_t *pbuffer, uint32_t length);
void spi_bytes_read(uint8_t *pbuffer, uint32_t length);
void spiflash_wait_busy(void);
uint8_t spiflash_read_sr1(void);
void spiflash_write_enable(void);
uint16_t spiflash_read_id(void);
uint8_t spi_byte_write(uint8_t data);
uint8_t spi_byte_read(void);
#endif
2.4、main.c
#include "at32l021_clock.h"
#include "usart/usart.h"
#include "led/led.h"
#include "delay/delay.h"
#include "i2c/i2c.h"
#include "oled/oled.h"
#include "adc/adc.h"
#define FLASH_TEST_ADDR                  0x1000
#define SPI_BUF_SIZE                     256
uint8_t tx_buffer;
uint8_t rx_buffer;
void tx_data_fill(void)
uint32_t data_index = 0;
for(data_index = 0; data_index < SPI_BUF_SIZE; data_index++)
    tx_buffer = data_index;
int main(void)
        __IO uint32_t index = 0;
        __IO uint32_t flash_id_index = 0;
system_clock_config();
        init_usart(115200);
        delay_init();
        init_led();
        printf("test\r\n");
        tx_data_fill();
        spiflash_init();
        flash_id_index = spiflash_read_id();
        if(flash_id_index !=0x5114)
                printf("flash id check error!\r\n");
        else
                printf("flash id check success! id: %x\r\n", flash_id_index);
        spiflash_sector_erase(FLASH_TEST_ADDR / SPIF_SECTOR_SIZE);
        spiflash_write(tx_buffer, FLASH_TEST_ADDR, SPI_BUF_SIZE);
        spiflash_read(rx_buffer, FLASH_TEST_ADDR, SPI_BUF_SIZE);
        printf("Read Data: ");
for(index = 0; index < SPI_BUF_SIZE; index++)
    printf("%x ", rx_buffer);
while(1)
    led2_tog();
    delay_ms(200);
三、运行结果
串口输出读出的数据
页: [1]
查看完整版本: 【AT-START-L021测评】+ spiflash读写测试
