【AT-START-L021测评】+ 运行FreeRTOS
移植FreeRTOS系统到开发板。一、下载FreeRTOS软件
下载地址:https://www.freertos.org/
二、添加文件到工程
将下载的源码添加到工程中
三、程序代码部分
根据芯片的硬件资源来配置FreeRTOS。
3.1、FreeRTOSConfig.h
* FreeRTOS V202212.01
* Copyright (C) 2020 Amazon.com, Inc. or its affiliates.All Rights Reserved.
* Permission is hereby granted, free of charge, to any person obtaining a copy of
* this software and associated documentation files (the "Software"), to deal in
* the Software without restriction, including without limitation the rights to
* use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies of
* the Software, and to permit persons to whom the Software is furnished to do so,
* subject to the following conditions:
* The above copyright notice and this permission notice shall be included in all
* copies or substantial portions of the Software.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
* IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS
* FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR
* COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER
* IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN
* CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
* https://www.FreeRTOS.org
* https://github.com/FreeRTOS
#ifndef FREERTOS_CONFIG_H
#define FREERTOS_CONFIG_H
* Application specific definitions.
* These definitions should be adjusted for your particular hardware and
* application requirements.
* THESE PARAMETERS ARE DESCRIBED WITHIN THE 'CONFIGURATION' SECTION OF THE
* FreeRTOS API DOCUMENTATION AVAILABLE ON THE FreeRTOS.org WEB SITE.
* See http://www.freertos.org/a00110.html.
/* Ensure definitions are only used by the compiler, and not by the assembler. */
#if defined(__ICCARM__) || defined(__CC_ARM) || defined(__GNUC__)
#include <stdint.h>
extern uint32_t system_core_clock;//SystemCoreClock;
#endif
#define configUSE_PREEMPTION 1
#define configSUPPORT_STATIC_ALLOCATION 0//1
#define configSUPPORT_DYNAMIC_ALLOCATION 1
#define configUSE_IDLE_HOOK 0
#define configUSE_TICK_HOOK 0
#define configCPU_CLOCK_HZ (system_core_clock)//80000000//( SystemCoreClock )
#define configTICK_RATE_HZ ( ( TickType_t ) 1000 )
#define configMAX_PRIORITIES ( 56 )
#define configMINIMAL_STACK_SIZE ( ( uint16_t ) 512 )
#define configTOTAL_HEAP_SIZE ( ( size_t ) 5 * 1024 )
#define configMAX_TASK_NAME_LEN ( 16 )
#define configUSE_TRACE_FACILITY 1
#define configUSE_16_BIT_TICKS 0
#define configUSE_MUTEXES 1
#define configQUEUE_REGISTRY_SIZE 8
#define configUSE_RECURSIVE_MUTEXES 1
#define configUSE_COUNTING_SEMAPHORES 1
#define configUSE_PORT_OPTIMISED_TASK_SELECTION 0
#define configUSE_MALLOC_FAILED_HOOK 0//1
#define configCHECK_FOR_STACK_OVERFLOW 0//2
/* Defaults to size_t for backward compatibility, but can be changed
* if lengths will always be less than the number of bytes in a size_t. */
#define configMESSAGE_BUFFER_LENGTH_TYPE size_t
/* USER CODE END MESSAGE_BUFFER_LENGTH_TYPE */
/* Software timer definitions. */
#define configUSE_TIMERS 1
#define configTIMER_TASK_PRIORITY ( 2 )
#define configTIMER_QUEUE_LENGTH 10
#define configTIMER_TASK_STACK_DEPTH 256
/* Set the following definitions to 1 to include the API function, or zero
* to exclude the API function. */
#define INCLUDE_vTaskPrioritySet 1
#define INCLUDE_uxTaskPriorityGet 1
#define INCLUDE_vTaskDelete 1
#define INCLUDE_vTaskCleanUpResources 0
#define INCLUDE_vTaskSuspend 1
#define INCLUDE_vTaskDelayUntil 1
#define INCLUDE_vTaskDelay 1
#define INCLUDE_xTaskGetSchedulerState 1
#define INCLUDE_xTimerPendFunctionCall 0
#define INCLUDE_xQueueGetMutexHolder 1
#define INCLUDE_uxTaskGetStackHighWaterMark 1
#define INCLUDE_eTaskGetState 1
/* Cortex-M specific definitions. */
#ifdef __NVIC_PRIO_BITS
/* __BVIC_PRIO_BITS will be specified when CMSIS is being used. */
#define configPRIO_BITS __NVIC_PRIO_BITS
#else
#define configPRIO_BITS 4
#endif
/* The lowest interrupt priority that can be used in a call to a "set priority"
* function. */
#define configLIBRARY_LOWEST_INTERRUPT_PRIORITY 15
/* The highest interrupt priority that can be used by any interrupt service
* routine that makes calls to interrupt safe FreeRTOS API functions.DO NOT
* CALL INTERRUPT SAFE FREERTOS API FUNCTIONS FROM ANY INTERRUPT THAT HAS A
* HIGHER PRIORITY THAN THIS! (higher priorities are lower numeric values. */
#define configLIBRARY_MAX_SYSCALL_INTERRUPT_PRIORITY 5
/* Interrupt priorities used by the kernel port layer itself.These are generic
* to all Cortex-M ports, and do not rely on any particular library functions. */
#define configKERNEL_INTERRUPT_PRIORITY ( configLIBRARY_LOWEST_INTERRUPT_PRIORITY << ( 8 - configPRIO_BITS ) )
/* !!!! configMAX_SYSCALL_INTERRUPT_PRIORITY must not be set to zero !!!!
See http://www.FreeRTOS.org/RTOS-Cortex-M3-M4.html. */
#define configMAX_SYSCALL_INTERRUPT_PRIORITY ( configLIBRARY_MAX_SYSCALL_INTERRUPT_PRIORITY << ( 8 - configPRIO_BITS ) )
/* Normal assert() semantics without relying on the provision of an assert.h
* header file. */
#define configASSERT( x ) if ( ( x ) == 0 ) { taskDISABLE_INTERRUPTS(); for( ;; ); }
/* Definitions that map the FreeRTOS port interrupt handlers to their CMSIS
* standard names. */
#define vPortSVCHandler SVC_Handler
#define xPortPendSVHandler PendSV_Handler
//#define xPortSysTickHandler SysTick_Handler
/* Allow system call from within FreeRTOS kernel only. */
#define configENFORCE_SYSTEM_CALLS_FROM_KERNEL_ONLY 1
/* STM32H743 has 16 MPU regions and therefore it is necessary to configure
* configTOTAL_MPU_REGIONS correctly. */
#define configTOTAL_MPU_REGIONS 16
/* The default TEX,S,C,B setting marks the SRAM as shareable and as a result,
* disables cache. Do not mark the SRAM as shareable because caching is being
* used. TEX=0, S=0, C=1, B=1. */
#define configTEX_S_C_B_SRAM ( 0x03UL )
#endif /* FREERTOS_CONFIG_H */
3.2、fun_task.c
#include "main.h"
#define START_TASK_PRO 1
#define START_STK_SIZE 64
TaskHandle_t StartTask_Handler;
#define TASK1_PRIO 2
#define TASK1_STK_SIZE64
static TaskHandle_t Task1Task_Handler = NULL;
#define TASK2_PRIO 3
#define TASK2_STK_SIZE64
static TaskHandle_t Task2Task_Handler = NULL;
#define TASK3_PRIO 4
#define TASK3_STK_SIZE64
static TaskHandle_t Task3Task_Handler = NULL;
void start_task(void *pvParameters);
void task1(void *pvParameters);
void task2(void *pvParameters);
void task3(void *pvParameters);
void task_create(void)
//start_task
xTaskCreate((TaskFunction_t )start_task,
(const char* )"start_task",
(uint16_t )START_STK_SIZE,
(void* )NULL,
(UBaseType_t )START_TASK_PRO,
(TaskHandle_t*)&StartTask_Handler);
vTaskStartScheduler();
taskENTER_CRITICAL();
//task1
xTaskCreate((TaskFunction_t )task1,
(const char* )"task1",
(uint16_t )TASK1_STK_SIZE,
(void* )NULL,
(UBaseType_t )TASK1_PRIO,
(TaskHandle_t*)&Task1Task_Handler);
//task2
xTaskCreate((TaskFunction_t )task2,
(const char* )"task2",
(uint16_t )TASK2_STK_SIZE,
(void* )NULL,
(UBaseType_t )TASK2_PRIO,
(TaskHandle_t*)&Task2Task_Handler);
//task3
xTaskCreate((TaskFunction_t )task3,
(const char* )"task3",
(uint16_t )TASK3_STK_SIZE,
(void* )NULL,
(UBaseType_t )TASK3_PRIO,
(TaskHandle_t*)&Task3Task_Handler);
taskEXIT_CRITICAL();
vTaskDelete(StartTask_Handler);
//task1
while (1)
printf("task1 run ...\r\n");
vTaskDelay(100);
//task2
while (1)
printf("task2 run ...\r\n");
vTaskDelay(200);
//task3
while (1)
printf("task3 run ...\r\n");
vTaskDelay(300);
3.3、main.c
#include "main.h"
int main(void)
system_clock_config();
init_usart(115200);
delay_init();
init_led();
task_create();
while(1)
四、程序运行
下载程序后,串口输出
页:
[1]
