HC32L110C6UA使用ADC电压数据采集的问题 -- 已解决
本帖最后由 JacksonChen 于 2024-12-5 16:52 编辑使用ADC电压数据采集时,通过打印输出能够接收到数据,但是接收到的数据不像是电压,请教大家下图中输出打印的“40xxx“是什么数据?还有就是华大的哪里可以查看对应的ADC通道?
输出打印图:
核心代码:
en_result_t My_Adc_Init(void)
stc_adc_cfg_t stcAdcCfg;
stc_adc_cont_cfg_t stcAdcContCfg;
stc_adc_irq_t stcAdcIrq;
stc_adc_irq_calbakfn_pt_t stcAdcIrqCalbaks;
DDL_ZERO_STRUCT(stcAdcCfg);
DDL_ZERO_STRUCT(stcAdcContCfg);
DDL_ZERO_STRUCT(stcAdcIrq);
DDL_ZERO_STRUCT(stcAdcIrqCalbaks);
// Clk_SwitchTo(ClkRCL);
// Clk_SetRCHFreq(ClkFreq24Mhz);
// Clk_SwitchTo(ClkRCH);
Clk_SetPeripheralGate(ClkPeripheralGpio, TRUE); //GPIO 外设时钟使能
if (Ok != Clk_SetPeripheralGate(ClkPeripheralAdcBgr, TRUE)) //ADCBGR 外设时钟使能
return Error;
Gpio_SetAnalog(2, 4, TRUE);
//ADC配置
Adc_Enable();
M0P_BGR->CR_f.BGR_EN = 0x1u;//BGR必须使能
M0P_BGR->CR_f.TS_EN = 0x1u; //内置温度传感器,视使用需求
delay100us(1);
stcAdcCfg.enAdcOpMode = AdcContMode; //连续采样模式
stcAdcCfg.enAdcClkSel = AdcClkSysTDiv1; //PCLK
stcAdcCfg.enAdcSampTimeSel = AdcSampTime8Clk; //8个采样时钟
// stcAdcCfg.enAdcRefVolSel = RefVolSelInBgr2p5; //参考电压:内部2.5V(avdd>3V,SPS<=200kHz)
stcAdcCfg.enAdcRefVolSel = RefVolSelAVDD; //参考电压:AVDD
// stcAdcCfg.bAdcInBufEn = TRUE;
stcAdcCfg.bAdcInBufEn = FALSE; //电压跟随器如果使能,SPS采样速率 <=200K
stcAdcCfg.enAdcTrig0Sel = AdcTrigDisable; //ADC转换自动触发设置
stcAdcCfg.enAdcTrig1Sel = AdcTrigDisable;
Adc_Init(&stcAdcCfg);
stcAdcIrq.bAdcIrq = TRUE; //转换完成中断函数入口配置使能
stcAdcIrq.bAdcRegCmp = FALSE;
stcAdcIrq.bAdcHhtCmp = FALSE;
stcAdcIrq.bAdcLltCmp = FALSE;
stcAdcIrqCalbaks.pfnAdcContIrq = AdcContIrqCallback; //转换完成中断入口函数
stcAdcIrqCalbaks.pfnAdcRegIrq = AdcRegIrqCallback;
stcAdcIrqCalbaks.pfnAdcHhtIrq = AdcHhtIrqCallback;
stcAdcIrqCalbaks.pfnAdcLltIrq = AdcLltIrqCallback;
Adc_ConfigIrq(&stcAdcIrq, &stcAdcIrqCalbaks); //转换中断入口函数配置
Adc_EnableIrq(); //中断使能
Adc_CmpCfg(&stcAdcIrq); //结果比较中断使能/禁止配置
stcAdcContCfg.enAdcContModeCh = AdcExInputCH0; //通道0 P24
stcAdcContCfg.u8AdcSampCnt = 0x09u; //P24 连续累加次数(次数 = 0x09+1)
stcAdcContCfg.bAdcResultAccEn = TRUE; //累加使能
Adc_ConfigContMode(&stcAdcCfg, &stcAdcContCfg);
return Ok;
}void AdcContIrqCallback(void)
//中断标志位判断和清零,已在库函数中处理Adc_IRQHandler();
Adc_GetAccResult(&u32AdcResultAcc);
Adc_ClrAccResult();
//Adc_ClrContIrqState();
int32_t main(void)
My_Gpio_Init();
My_Uart0_Init(0u , 9600u);
My_Uart1_Init(0u , 9600u);
delay100us(10);
My_Adc_Init();
printf("\r\napp start!\r\n");
while(1)
Adc_Start();
printf("u32AdcResultAcc:%d\r\n" , u32AdcResultAcc);
delay1ms(500);
【已解决】后续:
楼下大佬解答u32AdcResultAcc是累加寄存器的值,计算电压公式的基础下再除以10就能够算出电压了。
float voltage = (u32AdcResultAcc / 10 / 4095.0) * 3.3;
输出打印图:
对应的ADC通道图:
然而,你发的代码是初始化过程,并没有“打印”。 你打印的是累加寄存器的值,总共采样了10次,你把这个打印值除以10,就是当前通道的采样值 stcAdcContCfg.u8AdcSampCnt = 0x09u; //P24 连续累加次数(次数 = 0x09+1)
自己看注释 连续累加功能好用的
页:
[1]
