请教一个串口通信的奇偶校验问题
本帖最后由 肥羊 于 2025-1-15 15:48 编辑使用的单片机STM32F103
这个是代码/初始化IO 串口1
//bound:波特率
void uart_init1(u32 bound,u16 Parity ){
//GPIO端口设置
USART_InitTypeDef USART_InitStructure;
NVIC_InitTypeDef NVIC_InitStructure;
USART_Cmd(USART1, DISABLE);
USART_DeInit(USART1);//复位串口1
RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1|RCC_APB2Periph_GPIOA, ENABLE); //使能USART1,GPIOA时钟
//USART1_TX PA.9
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; //PA.9
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //复用推挽输出
GPIO_Init(GPIOA, &GPIO_InitStructure); //初始化PA9
//USART1_RX PA.10
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;//浮空输入
GPIO_Init(GPIOA, &GPIO_InitStructure);//初始化PA10
//Usart1 NVIC 配置
NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=3 ;//抢占优先级3
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3; //子优先级3
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQ通道使能
NVIC_Init(&NVIC_InitStructure); //根据指定的参数初始化VIC寄存器
//USART 初始化设置
USART_InitStructure.USART_BaudRate = bound;//一般设置为9600;
if(USART_Parity_No==Parity)
USART_InitStructure.USART_WordLength = USART_WordLength_8b;//字长为8位数据格式
USART_InitStructure.USART_StopBits = USART_StopBits_1;//一个停止位
USART_InitStructure.USART_Parity = USART_Parity_No;//无奇偶校验位
if(USART_Parity_Even==Parity)
USART_InitStructure.USART_WordLength = USART_WordLength_9b;//字长为8位数据格式
USART_InitStructure.USART_Parity = Parity;//偶校验位
if(USART_Parity_Odd==Parity)
USART_InitStructure.USART_Parity = Parity;//奇校验位
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//无硬件数据流控制
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; //收发模式
USART_Init(USART1, &USART_InitStructure); //初始化串口
USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);//开启中断
USART_ITConfig(USART1, USART_IT_TC, ENABLE);
USART_Cmd(USART1, ENABLE); //使能串口
memset( &HostTxRxData, 0, sizeof(HostTxRxData));
//USART_ClearFlag( USART1, USART_IT_TC );
memset( Modbus_Rx1, 0, sizeof(Modbus_Rx1));
memset( Modbus_Rx2, 0, sizeof(Modbus_Rx2));
M_Flag=0;
MRX_Cnt=0;
测试
1.当STM32 设置为8位数据位 无校验 一位停止位
电脑串口无论设置为奇偶校验 ,单片机可以无视电脑的奇偶校验,可以正常通信,不会产生奇偶错误中断
2.当单片机设置为9位数据 偶校验 -位停止位
电脑设置为无奇偶校验时候和单片机通信不正常,单片机会产生奇偶错误
电脑设置为偶校验的时候通信正常
电脑设置为奇校验的时候通信正常 单片机产生奇偶错误
3.当单片机设置为9位数据 奇校验 -位停止位
电脑设置为偶校验的时候通信正常 单片机产生奇偶错误
电脑设置为奇校验的时候通信正常
问题1 当情况一的时候是不是单片机会硬件忽略掉电脑来的奇偶校验位?
问题2 结合2和3猜想电脑是否没有检测奇偶校验? 没有人出来聊天吗 是的,当STM32设置为8位数据位、无校验、1位停止位时,STM32会硬件忽略电脑发送的奇偶校验位
在UART通信中,奇偶校验位的选择和检测是由通信双方共同约定的。当STM32的串口配置为“无校验”(No Parity)时,其硬件不会启用奇偶校验检测功能,因此无论电脑端发送的校验位是奇校验还是偶校验,STM32都不会处理该位,而是直接将其作为普通数据位接收或丢弃
这种情况下,通信可以正常进行,因为校验位的存在与否不会影响数据的实际传输
可以推测电脑端可能未主动检测奇偶校验,而是根据配置发送校验位,但不验证接收到的数据的校验结果
当电脑配置为“无校验”时,通信不正常,STM32产生奇偶错误。这表明STM32启用了偶校验检测,而电脑未发送校验位,导致STM32检测到校验错误
一般来说,当电脑配置为“偶校验”时,通信正常,说明STM32和电脑的校验规则一致
其实当电脑配置为“奇校验”时,STM32仍产生奇偶错误。这表明STM32期望的是偶校验,而电脑发送了奇校验位,导致校验失败
我觉得当电脑配置为“无校验”时,通信不正常,STM32产生奇偶错误。原因与情况2相同,STM32启用了奇校验检测,而电脑未发送校验位
我认为,当电脑配置为“偶校验”时,STM32产生奇偶错误,说明STM32期望的是奇校验,而电脑发送了偶校验位。当电脑配置为“奇校验”时,通信正常,说明STM32和电脑的校验规则一致
电脑端可能未启用奇偶校验检测功能,而是根据配置发送校验位,但不验证接收到的数据的校验结果。STM32严格遵循配置的校验规则,当接收到的校验位与配置不符时,会产生奇偶错误中断
页:
[1]
