使用的单片机STM32F103
这个是代码- /初始化IO 串口1
- //bound:波特率
- void uart_init1(u32 bound,u16 Parity ){
- //GPIO端口设置
- GPIO_InitTypeDef GPIO_InitStructure;
- USART_InitTypeDef USART_InitStructure;
- NVIC_InitTypeDef NVIC_InitStructure;
- USART_Cmd(USART1, DISABLE);
- USART_DeInit(USART1); //复位串口1
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1|RCC_APB2Periph_GPIOA, ENABLE); //使能USART1,GPIOA时钟
- //USART1_TX PA.9
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; //PA.9
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //复用推挽输出
- GPIO_Init(GPIOA, &GPIO_InitStructure); //初始化PA9
- //USART1_RX PA.10
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;//浮空输入
- GPIO_Init(GPIOA, &GPIO_InitStructure); //初始化PA10
- //Usart1 NVIC 配置
- NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
- NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=3 ;//抢占优先级3
- NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3; //子优先级3
- NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQ通道使能
- NVIC_Init(&NVIC_InitStructure); //根据指定的参数初始化VIC寄存器
- //USART 初始化设置
- USART_InitStructure.USART_BaudRate = bound;//一般设置为9600;
- if(USART_Parity_No==Parity)
- USART_InitStructure.USART_WordLength = USART_WordLength_8b;//字长为8位数据格式
- USART_InitStructure.USART_StopBits = USART_StopBits_1;//一个停止位
- USART_InitStructure.USART_Parity = USART_Parity_No;//无奇偶校验位
- if(USART_Parity_Even==Parity)
- USART_InitStructure.USART_WordLength = USART_WordLength_9b;//字长为8位数据格式
- USART_InitStructure.USART_Parity = Parity;//偶校验位
- if(USART_Parity_Odd==Parity)
- USART_InitStructure.USART_Parity = Parity;//奇校验位
- USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//无硬件数据流控制
- USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; //收发模式
- USART_Init(USART1, &USART_InitStructure); //初始化串口
- USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);//开启中断
- USART_ITConfig(USART1, USART_IT_TC , ENABLE);
- USART_Cmd(USART1, ENABLE); //使能串口
- memset( &HostTxRxData, 0, sizeof(HostTxRxData));
- //USART_ClearFlag( USART1, USART_IT_TC );
- memset( Modbus_Rx1, 0, sizeof(Modbus_Rx1));
- memset( Modbus_Rx2, 0, sizeof(Modbus_Rx2));
- M_Flag=0;
- MRX_Cnt=0;
测试
1.当STM32 设置为 8位数据位 无校验 一位停止位
电脑串口无论设置为奇偶校验 ,单片机可以无视电脑的奇偶校验,可以正常通信,不会产生奇偶错误中断
2.当单片机设置为 9位数据 偶校验 -位停止位
电脑设置为无奇偶校验时候和单片机通信不正常,单片机会产生奇偶错误
电脑设置为偶校验的时候通信正常
电脑设置为奇校验的时候通信正常 单片机产生奇偶错误
3.当单片机设置为 9位数据 奇校验 -位停止位
电脑设置为偶校验的时候通信正常 单片机产生奇偶错误
电脑设置为奇校验的时候通信正常
问题1 当情况一的时候是不是单片机会硬件忽略掉电脑来的奇偶校验位?
问题2 结合2和3猜想电脑是否没有检测奇偶校验?
