jinglixixi 发表于 2025-5-14 20:35
NUCLEO-C071RB开发板的OLED显示驱动
#申请原创#
NUCLEO系列开发板较之DISCO系列开发板的最大区别在于外设资源的配置,同样对于NUCLEO-C071RB开发板也是一样。
为了便于直观地观察测试效果,就需要为它配置一个对应的显示器件。从简化测试的需要,这里为它配置一个I2C接口的OLED屏。
为了省去连线的烦扰,这里是利于图1所示的CN5接口。由于是所用AREF引脚来提供电源,为此需要将SB4焊盘加以短接。
图1 所用接口
相应的是由PA5来控制显示屏的SCK引脚,由PA6来控制显示屏的SDA引脚,对这2个引脚的配置函数为:
void OLED_config(void)
GPIO_InitTypeDef gpio_init_structure;
__HAL_RCC_GPIOA_CLK_ENABLE();
gpio_init_structure.Pin = GPIO_PIN_5|GPIO_PIN_6;
gpio_init_structure.Mode = GPIO_MODE_OUTPUT_PP;
gpio_init_structure.Pull = GPIO_NOPULL;
gpio_init_structure.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
HAL_GPIO_Init(GPIOA, &gpio_init_structure);
实现引脚输出高低电平的语句定义为:
#define OLED_SCLK_Clr()HAL_GPIO_WritePin(GPIOA, GPIO_PIN_5, GPIO_PIN_RESET)
#define OLED_SCLK_Set()HAL_GPIO_WritePin(GPIOA, GPIO_PIN_5, GPIO_PIN_SET)
#define OLED_SDIN_Clr()HAL_GPIO_WritePin(GPIOA, GPIO_PIN_6, GPIO_PIN_RESET)
#define OLED_SDIN_Set()HAL_GPIO_WritePin(GPIOA, GPIO_PIN_6, GPIO_PIN_SET)
对OLED屏的初始化函数为:
void OLED_Init(void)
Write_IIC_Command(0xAE); //display off
Write_IIC_Command(0x20); //Set Memory Addressing Mode
Write_IIC_Command(0x10);
Write_IIC_Command(0xb0);//Set Page Start Address for Page Addressing Mode,0-7
Write_IIC_Command(0xc8);//Set COM Output Scan Direction
Write_IIC_Command(0x00);//---set low column address
Write_IIC_Command(0x10);//---set high column address
Write_IIC_Command(0x40);//--set start line address
Write_IIC_Command(0x81);//--set contrast control register
Write_IIC_Command(0xdf);
Write_IIC_Command(0xa1);//--set segment re-map 0 to 127
Write_IIC_Command(0xa6);//--set normal display
Write_IIC_Command(0xa8);//--set multiplex ratio(1 to 64)
Write_IIC_Command(0x3F);
Write_IIC_Command(0xa4);//0xa4,Output follows RAM content;0xa5,Output ignores RAM content
Write_IIC_Command(0xd3);//-set display offset
Write_IIC_Command(0x00);//-not offset
Write_IIC_Command(0xd5);//--set display clock divide ratio/oscillator frequency
Write_IIC_Command(0xf0);//--set divide ratio
Write_IIC_Command(0xd9);//--set pre-charge period
Write_IIC_Command(0x22);
Write_IIC_Command(0xda);//--set com pins hardware configuration
Write_IIC_Command(0x12);
Write_IIC_Command(0xdb);//--set vcomh
Write_IIC_Command(0x20);//0x20,0.77xVcc
Write_IIC_Command(0x8d);//--set DC-DC enable
Write_IIC_Command(0x14);
Write_IIC_Command(0xaf);//--turn on oled panel
模拟I2C进行字节数据发送的函数为:
void Write_IIC_Byte(unsigned char IIC_Byte)
unsigned char i;
unsigned char m,da;
da=IIC_Byte;
OLED_SCLK_Clr();
for(i=0;i<8;i++)
m=da;
m=m&0x80;
if(m==0x80)
{OLED_SDIN_Set();}
else OLED_SDIN_Clr();
da=da<<1;
OLED_SCLK_Set();
OLED_SCLK_Clr();
实现清屏处理的函数为:
void OLED_Clear(void)
uint8_t i,n;
for(i=0;i<8;i++)
OLED_WR_Byte (0xb0+i,OLED_CMD);
OLED_WR_Byte (0x00,OLED_CMD);
OLED_WR_Byte (0x10,OLED_CMD);
for(n=0;n<128;n++)OLED_WR_Byte(0,OLED_DATA);
实现字符显示的函数为:
void OLED_ShowChar(uint8_t x,uint8_t y,uint8_t chr,uint8_t Char_Size)
unsigned char c=0,i=0;
c=chr-' ';
if(x>Max_Column-1){x=0;y=y+2;}
if(Char_Size ==16)
OLED_Set_Pos(x,y);
for(i=0;i<8;i++)
OLED_WR_Byte(F8X16,OLED_DATA);
OLED_Set_Pos(x,y+1);
for(i=0;i<8;i++)
else {
OLED_Set_Pos(x,y);
for(i=0;i<6;i++)
OLED_WR_Byte(F6x8,OLED_DATA);
字符显示的字符串函数为:
void OLED_ShowString(uint8_t x,uint8_t y,uint8_t *chr,uint8_t Char_Size)
unsigned char j=0;
while (chr!='\0')
{OLED_ShowChar(x,y,chr,Char_Size);
x+=8;
if(x>120){x=0;y+=2;}
j++;
实现显示驱动效果测试的主程序为:
int main(void)
HAL_Init();
SystemClock_Config();
BSP_LED_Init(LED1);
OLED_config();
OLED_Init();
OLED_Clear();
OLED_ShowString(0,0,"STM32C071",16);
OLED_ShowString(0,2,"OLED TEST",16);
EXTI4_15_IRQHandler_Config();
while (1);
经程序的编译和下载,其测试效果如图2所示,说明驱动功能正常,符合设计要求。
图2 显示效果
AdaMaYun 发表于 2025-6-8 21:09
OLED显示驱动
页: [1]
查看完整版本: NUCLEO-C071RB开发板的OLED显示驱动
