AT32F403A的ADC采集为何达不到2MHz?
在使用AT32F403ACGT7的ADC采集时,发现ADC无法达到2MSPS,不知原因在哪里?配置使用的雅特力提供的Work Bench,ADC时钟为28MHz,每路ADC只采集一个通道,ADC1和ADC2使用一路DMA控制。触发使用的是定时器2的CH2。void wk_adc12_init(void)
gpio_init_type gpio_init_struct;
adc_base_config_type adc_base_struct;
gpio_default_para_init(&gpio_init_struct);
/* add user code begin adc1_init 1 */
/* add user code end adc1_init 1 */
/*gpio--------------------------------------------------------------------*/
/* configure the IN2 pinandconfigure the IN6 pin*/
gpio_init_struct.gpio_mode = GPIO_MODE_ANALOG;
gpio_init_struct.gpio_pins = GPIO_PINS_2 | GPIO_PINS_6;
gpio_init(GPIOA, &gpio_init_struct);
crm_adc_clock_div_set(CRM_ADC_DIV_4);
/*adc_common_settings-------------------------------------------------------------*/
adc_combine_mode_select(ADC_ORDINARY_SMLT_ONLY_MODE);
/*adc_settings--------------------------------------------------------------------*/
adc_base_default_para_init(&adc_base_struct);
adc_base_struct.sequence_mode = FALSE;
adc_base_struct.repeat_mode = FALSE;
adc_base_struct.data_align = ADC_LEFT_ALIGNMENT;
adc_base_struct.ordinary_channel_length = 1;
adc_base_config(ADC1, &adc_base_struct);
/* adc_ordinary_conversionmode-------------------------------------------- */
adc_ordinary_channel_set(ADC1, ADC_CHANNEL_2, 1, ADC_SAMPLETIME_1_5);
adc_ordinary_conversion_trigger_set(ADC1, ADC12_ORDINARY_TRIG_TMR2CH2, TRUE); // 定时器2触发
adc_dma_mode_enable(ADC1, TRUE);
adc_base_config(ADC2, &adc_base_struct);
adc_ordinary_channel_set(ADC2, ADC_CHANNEL_6, 1, ADC_SAMPLETIME_1_5);
adc_ordinary_conversion_trigger_set(ADC2, ADC12_ORDINARY_TRIG_SOFTWARE, TRUE);
adc_interrupt_enable(ADC1, ADC_CCE_INT, TRUE);
adc_enable(ADC1, TRUE);
adc_enable(ADC2, TRUE);
/* adc calibration-------------------------------------------------------- */
adc_calibration_init(ADC1);
while(adc_calibration_init_status_get(ADC1));
adc_calibration_start(ADC1);
while(adc_calibration_status_get(ADC1));
adc_calibration_init(ADC2);
while(adc_calibration_init_status_get(ADC2));
adc_calibration_start(ADC2);
while(adc_calibration_status_get(ADC2));
adc_enable(ADC1, FALSE); adc_enable(ADC2, FALSE);
void wk_dma1_channel2_init(void)// DMA初始化
dma_init_type dma_init_struct;
dma_reset(DMA1_CHANNEL2);
dma_default_para_init(&dma_init_struct);
dma_init_struct.direction = DMA_DIR_PERIPHERAL_TO_MEMORY;
dma_init_struct.memory_data_width = DMA_MEMORY_DATA_WIDTH_WORD;
dma_init_struct.memory_inc_enable = TRUE;
dma_init_struct.peripheral_data_width = DMA_PERIPHERAL_DATA_WIDTH_WORD;
dma_init_struct.peripheral_inc_enable = FALSE;
dma_init_struct.priority = DMA_PRIORITY_LOW;
dma_init_struct.loop_mode_enable = TRUE;
dma_init(DMA1_CHANNEL2, &dma_init_struct);
/* flexible function enable */
dma_flexible_config(DMA1, FLEX_CHANNEL2, DMA_FLEXIBLE_ADC1);
wk_dma_channel_config(DMA1_CHANNEL2,
(uint32_t)&ADC1->odt,
(uint32_t)adc_buff,
1024);
dma_channel_enable(DMA1_CHANNEL2, TRUE);
// 定时器2初始化
void wk_tmr2_init(void)
tmr_output_config_type tmr_oc_init_structure;
/* configure counter settings */
tmr_cnt_dir_set(TMR2, TMR_COUNT_UP);
tmr_clock_source_div_set(TMR2, TMR_CLOCK_DIV1);
tmr_base_init(TMR2, 3, 27);
/* configure overflow event */
tmr_output_default_para_init(&tmr_oc_init_structure);
tmr_oc_init_structure.oc_mode = TMR_OUTPUT_CONTROL_PWM_MODE_A;
tmr_oc_init_structure.oc_polarity = TMR_OUTPUT_ACTIVE_LOW;
tmr_oc_init_structure.oc_output_state = TRUE;
tmr_oc_init_structure.oc_idle_state = FALSE;
tmr_output_channel_config(TMR2, TMR_SELECT_CHANNEL_2, &tmr_oc_init_structure);
tmr_channel_enable(TMR2, TMR_SELECT_CHANNEL_2, TRUE);
tmr_channel_value_set(TMR2, TMR_SELECT_CHANNEL_2, 2);
//tmr_counter_enable(TMR2, TRUE);
以上就是ADC相关的初始化,对被采对象采集时,发现,只能达到1MHZ的采样速率,还望熟悉的工程师告知问题,谢谢!!!
将两个ADC的这个语句adc_base_struct.repeat_mode = FALSE;
改成adc_base_struct.repeat_mode = TRUE;
ADC工作在反复模式,ADC只需要触发一次,然后ADC转换速度就可以达到2M
原因是ADC从接收到触发信号到开始转换,会有一点延时,TMR的触发信号间隔刚好时2M,所以在第二次触发来的时候,ADC其实还在转换,所以你速度要跑满2M的话,就让ADC工作在反复模式
改为TRUE后,就是2MHz了,但是改变定时触发就无效了。如果这是改变定时器为500K,他还是2MHz 骑着蜗牛狂奔O 发表于 2025-5-15 17:19
多谢你的回答,知道了为何不能到2M的原因了 触发一次那数据取出来完整么 zjsx8192 发表于 2025-5-17 09:45
触发一次那数据取出来完整么
初始化没问题,数据就没有问题。 ADC 的时钟频率通常是由系统时钟分频得到的。 AT32F403A的ADC在数据手册中标注的最高采样率 12 位 ADC 的建立时间通常是时间常数的 8.4 倍,这在一定程度上限制了其最高采样率 ADC的转换速率通常有一个上限,这个上限在数据手册中有明确的说明。 直接测量ADC_CLK引脚波形,确认实际频率是否达到预期。 ADC 采集需要一定的时间对内部电容进行充电,如果采样时间设置过短,电容无法充满电,导致电压不稳定,会影响转换精度和采集速率。 ADC每个通道的采样时间需足够长以完成信号采集。 硬件限制与IO配置 AT32F403A的ADC可能无法支持2MHz的转换速率。 时钟配置限制 ADC的转换速率受到其时钟频率的限制。 实际应用中,为了保证采样精度和稳定性,可能会选择较大的采样周期数,从而导致实际采样频率无法达到2MHz。 采样时间直接影响总转换周期。
页:
[1]
