【Mini-F5265-OB开发板试用测评】1、串口printf输出
测试串口printf输出。一、硬件电路部分
开发板自带仿真器上有虚拟串口,插上USB仿真器可以找到串口设备号。
仿真器串口连接到MM32F5265芯片的PC10和PC11引脚(UART3功能)。
二、串口3功能
看手册串口3引脚的功能映射图
串口3映射到AF7,需要在程序中配置到此映射。
三、程序部分
3.1、usart.c
#include "main.h"
void init_usart(uint32_t Baudrate)
GPIO_InitTypeDef GPIO_InitStruct;
UART_InitTypeDef UART_InitStruct;
RCC_APB1PeriphClockCmd(RCC_APB1Periph_UART3, ENABLE);
UART_StructInit(&UART_InitStruct);
UART_InitStruct.BaudRate = Baudrate;
UART_InitStruct.WordLength = UART_WordLength_8b;
UART_InitStruct.StopBits = UART_StopBits_1;
UART_InitStruct.Parity = UART_Parity_No;
UART_InitStruct.HWFlowControl = UART_HWFlowControl_None;
UART_InitStruct.Mode = UART_Mode_Tx;
UART_Init(UART3, &UART_InitStruct);
UART_Cmd(UART3, ENABLE);
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOC, ENABLE);
GPIO_PinAFConfig(GPIOC, GPIO_PinSource10, GPIO_AF_7);
GPIO_PinAFConfig(GPIOC, GPIO_PinSource11, GPIO_AF_7);
GPIO_StructInit(&GPIO_InitStruct);
GPIO_InitStruct.GPIO_Pin = GPIO_Pin_10;
GPIO_InitStruct.GPIO_Speed = GPIO_Speed_High;
GPIO_InitStruct.GPIO_Mode= GPIO_Mode_AF_PP;
GPIO_Init(GPIOC, &GPIO_InitStruct);
GPIO_InitStruct.GPIO_Pin = GPIO_Pin_11;
#if defined (__ICCARM__)
#if (__VER__ >= 9030001)
/* Files include */
#include <stddef.h>
#include <LowLevelIOInterface.h>
* @briefredefine __write function
* @NOTE for printf
* @paramhandle
* @param*buf
* @parambufSize
* @retval nChars
size_t __write(int handle, const unsigned char *buf, size_t bufSize)
size_t nChars = 0;
/* Check for the command to flush all handles */
if (-1 == handle)
return (0);
/* Check for stdout and stderr (only necessary if FILE descriptors are enabled.) */
if ((_LLIO_STDOUT != handle) && (_LLIO_STDERR != handle))
return (-1);
for (/* Empty */; bufSize > 0; --bufSize)
UART_SendData(UART2, *buf);
while (RESET == UART_GetFlagStatus(UART2, UART_FLAG_TXC))
++buf;
++nChars;
return (nChars);
#else
* @briefredefine fputc function
* @note for printf
* @paramch
* @paramf
* @retval ch
int fputc(int ch, FILE *f)
UART_SendData(UART2, (uint8_t)ch);
return (ch);
#endif
#elif defined (__GNUC__)
* @note for printf
* @paramch
* @paramf
* @retval ch
UART_SendData(UART3, (uint8_t)ch);
while (RESET == UART_GetFlagStatus(UART3, UART_FLAG_TXC))
return (ch);
#else
* @note for printf
* @paramch
* @paramf
* @retval ch
return (ch);
#endif
3.2、main.c
#include "main.h"
int main(void)
SysTick_Init();
init_usart(115200);
init_led();
while (1)
led1_tog();
led2_tog();
SysTick_Delay_ms(100);
printf("mm32F5265_ob_printf_test!\r\n");
四、运行结果
下载程序后,串口输出内容:
原文链接:https://blog.csdn.net/weixin_47569031/article/details/148534073
页:
[1]
