Reli-eng-z 发表于 2025-8-15 23:18
BMP561与 BQ27Z561 ESD测试报告对比,哪个更高?
最近有朋友给我推荐了极海的BMP561产品,ESD设计的比TI好,我不相信,于是就从朋友那里拿到了样品,对ESD/LU进行了实测,结果极海ESD更高,具体高在哪里呢?听我一一道来:第一:BMP561-HBM高实验1:HBM人体放电模型测试实验 测试对象:1.Geehy_BMP561单芯片ESD方案,2.BQ27Z561单芯片ESD方案 测试方法:在MK2机台,根据芯片数据手册梳理所有管脚耐压值,电源、IO属性形成pinlist。梳理完pinlist,按照如下组合分配管脚,
HBMtest
All Other Pins To VSS(±)500V~8000V,Step 500V
All Other Pins To BAT(6V)(±)500V~8000V,Step 500V
IO To IO(±)500V~8000V,Step 500V
根据表格pin组合以及步进,pin组合是根据JS-001标准实施,MK2机台执行测试。 调试好自动化测试程序需设置的参数为(以下来源于数据手册,可公开):
Pin GroupTypePin(s)
VSSGROUNDB2
BAT(6V)POWERD2
IP(2.1V)_TSINPUTB1
IP(6.3V)_SRNINPUTC1
IP(6.3V)_BAT_SNSINPUTC2
IP(6.3V)_SRPINPUTD1
IP(6V)_CEINPUTD3
IO(6V)_INTOUTPUTA1
IO(6V)_PULSOUTPUTA2
IO(6V)_SDA/HDQOUTPUTA3
IO(6V)_SCLOUTPUTB3
IO(6V)_NUOUTPUTC3
IO A1,A2,A3,B1,B3,C1,C2,C3,D1,D3
测试结果如下: 1. Geehy_BMP561单芯片HBM结果(ESD结果会有三方实验室报告,可以对外):
GroupPinPin Name1
Zap LevelCriteria
BAT(6V)D2BAT±8000VPassed
IP(2.1V)_TSB1TS±8000VPassed
IP(6V)_CED3CE±8000VPassed
IP(6.3V)_BAT_SNSC2BAT_SNS±8000VPassed
IP(6.3V)_SRPD1SRP±8000VPassed
IP(6.3V)_SRNC1SRN±8000VPassed
IO(6V)_INTA1INT±8000VPassed
IO(6V)_PULSA2PULS±8000VPassed
IO(6V)_SCLB3SCL±8000VPassed
IO(6V)_SDA/HDQA3SDA/HDQ±8000VPassed
IO(6V)_NUC3NU±8000VPassed
VSSB2VSS±8000VPassed
GroupPinPin Name23
Zap LevelCriteriaZap LevelCriteria
BAT(6V)D2BAT±7000VCC (after)±7000VCC (after)
IP(2.1V)_TSB1TS±7000VPassed±7000VPassed
IP(6V)_CED3CE±7000VPassed±7000VPassed
IP(6.3V)_BAT_SNSC2BAT_SNS±7000VPassed±7000VPassed
IP(6.3V)_SRPD1SRP±7000VPassed±7000VPassed
IP(6.3V)_SRNC1SRN±7000VPassed±7000VPassed
IO(6V)_INTA1INT±7000VPassed±7000VPassed
IO(6V)_PULSA2PULS±7000VPassed±7000VPassed
IO(6V)_SCLB3SCL±7000VPassed±7000VPassed
IO(6V)_SDA/HDQA3SDA/HDQ±7000VPassed±7000VPassed
IO(6V)_NUC3NU±7000VPassed±7000VPassed
VSSB2VSS±7000VPassed±7000VPassed
结果上看,打了3颗HBM,1颗可以直达8KV,另两颗6.5KV,那么按照水桶效应,整体判定为±6.5KV2. BQ27Z561单芯片HBM结果:
GroupPinPin Name123
Zap LevelCriteriaZap LevelCriteriaZap LevelCriteria
BAT(6V)D2BAT3000VCC (after Zap)3000VCC (after Zap)3000VCC (after Zap)
VSSB2VSS3000VCC (Zap to BAT(6V))3000VCC (Zap to BAT(6V))3000VCC (Zap to BAT(6V))
IP(2.1V)_TSB1TS±3000VPassed±3000VPassed±3000VPassed
IP(6V)_CED3CE±3000VPassed±3000VPassed±3000VPassed
IP(6.3V)_BAT_SNSC2BAT_SNS±3000VPassed±3000VPassed±3000VPassed
IP(6.3V)_SRPD1SRP±3000VPassed±3000VPassed±3000VPassed
IP(6.3V)_SRNC1SRN±3000VPassed±3000VPassed±3000VPassed
IO(6V)_INTA1INT±3000VPassed±3000VPassed±3000VPassed
IO(6V)_PULSA2PULS±3000VPassed±3000VPassed±3000VPassed
IO(6V)_SCLB3SCL±3000VPassed±3000VPassed±3000VPassed
IO(6V)_SDA/HDQA3SDA/HDQ±3000VPassed±3000VPassed±3000VPassed
IO(6V)_NUC3NU±3000VPassed±3000VPassed±3000VPassed
结果上看,打了3颗HBM,3颗±2.5KV,着实比BMP561低了±4KV. 实验2:CDM带电器件模型测试(ESD结果会有三方实验室报告,可以对外) 1、Geehy_BMP561单芯片CDM结果
Test Model: CDM TESTESD Sensitivity Passed: ±2000V
UnitTest conditionSample QuantityPassed VoltsIV Result Description
C1
C2
C3CDM 250V~2000V,Step 250V FOR ALL 12 BALLS3±2000VPASS
2、BQ27Z561单芯片CDM结果:
C1
C2
CDM二者无差别。
第二:BMP561-LU PASS
实验3:LU闩锁效应(ESD结果会有三方实验室报告,可以对外)1、Geehy_BMP561单芯片LU结果
Test Model: LATCH-UP test 125C
UnitTrigger ModeTest Pin GroupSample QuantityTested ResultV or I Limits
L1
L2
L3I-Test(positive)IP(2.1V)_TS3PASS +200mA+3.150V
IO(2.1V)_NUPASS +200mA+3.150V
IP(6V)_CEPASS +200mA+9.000V
IO(6V)_INTPASS +200mA+9.000V
IO(6V)_PULSPASS +200mA+9.000V
IO(6V)_SCLPASS +200mA+9.000V
IO(6V)_SDA/HDQPASS +200mA+9.000V
IP(6.3V)_BAT_SNSPASS +200mA+9.450V
IP(6.3V)_SRPPASS +200mA+9.450V
IP(6.3V)_SRNPASS +200mA+9.450V
I-Test(negative)IP(2.1V)_TSPASS -200mA-1.050V
IO(2.1V)_NUPASS -200mA-1.050V
IP(6V)_CEPASS -200mA-3.000V
IO(6V)_INTPASS -200mA-3.000V
IO(6V)_PULSPASS -200mA-3.000V
IO(6V)_SCLPASS -200mA-3.000V
IO(6V)_SDA/HDQPASS -200mA-3.000V
IP(6.3V)_BAT_SNSPASS -200mA-3.150V
IP(6.3V)_SRPPASS -200mA-3.150V
IP(6.3V)_SRNPASS -200mA-3.150V
Vsupply Over-voltage testBAT(6V)PASS +9.000 V+600mA
2、BQ27Z561单芯片LU结果:
Test Model: LATCH-UP test@125C
L3
L4I-Test(positive)IP(2.1V)_TS3PASS +200mA+3.15V
IP(6V)_CEPASS +200mA+9.0V
IP(6.3V)_BAT_SNSPASS +200mA+9.45V
IP(6.3V)_SRPPASS +200mA+9.45V
IP(6.3V)_SRNPASS +200mA+9.45V
IO(6V)_INTPASS +200mA+9.0V
IO(6V)_PULSPASS +200mA+9.0V
IO(6V)_SCLPASS +200mA+9.0V
IO(6V)_SDA/HDQPASS +200mA+9.0V
IO(2.1V)_NUPASS +200mA+3.15V
I-Test(negative)IP(2.1V)_TSPASS -200mA-1.05V
IP(6V)_CEPASS -200mA-2.750V
IP(6.3V)_BAT_SNSPASS -200mA-3.15V
IP(6.3V)_SRPPASS -200mA-3.15V
IP(6.3V)_SRNFAIL -200mA-3.15V
IO(6V)_INTPASS -200mA-3.0V
IO(6V)_PULSPASS -200mA-3.0V
IO(6V)_SCLPASS -200mA-3.0V
IO(6V)_SDA/HDQPASS -200mA-3.0V
IO(6V)_NUPASS -200mA-1.05V
Vsupply Over-voltage testBAT(6V)PASS +9.0 V+600mA
总结 1、从整体的ESD测试结果来看,对比BQ27Z561单芯片ESD结果,BMP561在HBM比BQ27Z561的高出±4KV,LU 125°高温下BMP561过了,反而TI没过,这一点要为国产芯片点赞!从未来芯片应用上,抗ESD能力明显强于 BQ27Z561,CDM测试结果一致,两者比较接近。 2、单从HBM/LU来看,BMP561抗静电能力远远优于BQ27Z561,可以支持用户应用于ESD要求高的场景。如:1、HBM耐压高:HBM测试电压越高(如8KV vs. 4KV),芯片在人体静电放电场景下的防护能力越强,减少因ESD导致的失效风险。2、LU抗干扰强:更高的LU耐压(如100mA vs. 50mA)意味着芯片在电源噪声或瞬态干扰下更不易触发闩锁效应,提升系统稳定性。 极海产品通过各类认证是芯片进入各自对应领域的必备门槛,需从设计、制造到测试全链条协同优化。“如果您正在寻找高可靠性的芯片,欢迎联系极海半导体有限公司获取免费样品(www.geehy.comm)。”
“关注Geehy极海半导体 公众号,回复‘认证’获取完整认证指南。”
页: [1]
查看完整版本: BMP561与 BQ27Z561 ESD测试报告对比,哪个更高?
